Question about Compaq Presario 700 470024-192 Notebook
No power to lcd
Computer powers on but screen dosent light up , neither did it light up another moniter
  • Lawrence Lavergne
    Lawrence Lavergne Feb 21, 2012
    computer powers on even dvd runs but ni screen
    Habit-Forming:
  • 56 Answers
Does it do anything? Does the power indicator light come on? Try checking the power cord and the cord linking it to the computer, make sure both are in tight and secure. If they are, make sure your power cord has continuity with a circuit checker. If it does, and the screen does not light up, try a different cord.
Posted on Feb 20, 2012
Displaying only 2 secs
Monitor STFC (Self Test Feature Check)
* Turn off the monitor
* Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
* Unplug the monitor video cable from the back of the computer
* Turn on the monitor
* The floating dialog box should appear on screen against a black background. If the issue appears during the STFC, the monitor is defective. Get it replaced.
Oct 31, 2013 | BenQ Computers & Internet
Hello sir i have a broblm in my samsung synicmastr 19" blak, when i switch on the moniter, the moniter is with in 2 or 3 second automitically off the display light but moniter is still on and display...
this problem can occur cause of two cases 1 problem with LCD panel (replacement can solve) 2 power failure in side moniter (repairing moniter can solve)
thanx PLZ vote
Feb 22, 2011 | Samsung SyncMaster 931B 19" LCD Monitor
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again!...
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Sep 09, 2010 | Proview PL926WBi 19" LCD Monitor
Moniter power light blinks purple.
Inspect the power supply and also try it on another PC too.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 30, 2010 | Smart Modular SV3170A
Hp L1820 moniter not on
is the lights on monitor comming on to green,if light and no image monitor tube is gone.
Jun 26, 2009 | HP L1820 18 in. Flat Panel LCD Monitor
Screen black
Take the post (power on self test) disconnect vga cable and connect power cable if monitor shows no signal check signal cable massage then monitor is ok fault is in cpu. open it and clean the dust
by vaccum cleaner you will get the display again
Oct 17, 2008 | X2Gen MG19MY 19" LCD Monitor
15.6 lcd wide moniter (low light)
It's LCD pannel problem
Remove the LCD pannel and checket flowrocent tubes at top of LCD Screen and Bottom of LCD Pannel. If U Find any burning area at end of F tube, please clean it and solder the flowercent tubes in same possion and connect as same.
Oct 03, 2008 | Acer AL2216WBD LCD Monitor
Dell moniter
The power supply has most likely gone out. Check for 12v and 5v output and also the solder arround d903 and d907. The site www.lcdrepair.us sells the part as well as a repair kit and has instructions.
May 24, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Compaq Presario 700 470024-192 Notebook Logo
214 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
