Question about Casio PX3 Privia 88Key Digital Stage Piano
My Casio PX3 On note g4, works normally then the note intermittently plays with full velocity
I'm playing normally, not very hard (I'm classically trained and have good technique) when the note G4 will suddenly play at 127 (full velocity) The problem seems to be getting worse. What does Casio use in the action to achieve velocity sensitivity? Also, any instructions on taking the keyboard apart?
  • 1138 Answers
SOURCE: MIDI Keyboard note delay problem, not latency problem PLEASE HELP
You are suffering from midi latency. There is a good article about this at www.thewhippinpost.co.uk/latency.htm There is also some good advice there.
Posted on Jun 23, 2009
  • 5603 Answers
SOURCE: My Casio Privia PX-110 is playing two notes at
IF every key sounds like it is doing that, you may have two voices selected with one of them being transposed.
You may have an "effect" turned on that generates a chorus, layered or multiple voice sounds.
Posted on Dec 10, 2009
  • 5603 Answers
SOURCE: Casio CTK-651 keyboard wont switch on
An internal fuse is UNLIKELY.
More likely is either a bad connection/connector at power input or a bad or intermittent power switch.
Posted on Jun 25, 2010
SOURCE: Casio CTK-671 No Sound
phylomedusa, I have the exact same problem???
Posted on Oct 17, 2010
  • 5603 Answers
SOURCE: My Casio Px 330 keyboard
This is a problem with one of the two contacts for that key. The contacts close at different times as the key is depressed and the time it takes between is measured as velocity which is used to control the loudness as in a regular piano. The contacts are conductive rubber pills. After a lot of dis-assembly you can clean them with 99% isoprphyl alcohol and Q Tips. Clean both the pills and the circuit traces on the board they are pressed against. Be very careful of the ribbon cables between the halves of the case.
Posted on Jun 02, 2011
Casio ctk 611 keyboard error
Turn off "Casio Chord" &/or autoaccompaniment
Dec 08, 2013 | Casio CTK5000 (61Key Portable Keyboard)
Ensoniq kt-88 quirk
those bubble contact strips will have to be completely cleaned, when dirty
the keys will be at max velocity(loud).
May 05, 2012 | Music
My Privia PX-3 will run fine for about an hour. After that, for example, if I am playing a piano sound and want to switch to organ, I press the organ button and the LED shows that I have chosen the organ...
This problem is NOT DIY and will likely require a trip to the repair shop... One possibility is a static discharge... Try running it for hours with no clothes on that can produce a static buildup and see if it behaves. If so, take maeasures against static... no rubber soled shoes, no wool fabrics, gound yourself to something else before touching the unit...
Aug 16, 2011 | Casio PX3 Privia 88Key Digital Stage Piano
I have a priva PX-410R, when I turned it on today just one of the keys is playing at full volume like I was pressing the key really hard. The rest of the keys are playing normally. If I put it on say a...
Each key has two contacts. One closes first and then the other. This allows the processor to measure the key velocity which is then used to control volume. The key contacts are conductive rubber "pills" pressed onto circuit board traces. Clean them ONLY with 99% isoprophyl alcohol and Q tips. The disassembly of the unit to access these is NOT for the inexperienced so you might want to take it to a repir shop. Here is a service manual for a Casio 811 which is totally different packaging than yours, HOWEVER the keyboard itself will be similar and you will get an idea what is involved with getting into one of these things:
http://elektrotanya.com/casio_ctk_811_ex.pdf/download.html
Scroll down to "get manual" and click to download... IGNORE other download links.
The keyboard exploded view is around page 32 in this manual.
Aug 03, 2011 | Music
Casio Privia px 130 One of the keys (e4) sometimes playes at full velocity even when pressed lightly. It happenes vary regularly which means I can no longer rely on the key playing softly. It is...
One of the two contacts for that key is not working. This could be dirty or damaged contact. They use a conductive rubber pills that the key presses against circuit board traces. One contact makes before the other and this is how velocity is sensed. Unless you are adept at this repair, I would recommend you take it in for repair. Chances are any part cost is negligible... mostly labor to open and access the contacts for cleaning. Clean ONLY with 99% isoprophyl alcohol and Q TIps... VERY GENTLY.
Jul 02, 2011 | Casio Privia Px-130 Px130 88 Key Digital...
I've recently purchased a Roland foot pedal for my casio privia px-300 keyboard. When playing a note, even though the pedal is not pressed, the note sustains. When I press the foot pedal down, it cuts...
Sorry, but Roland uses the opposite sense switch. They use normally closed where Casio requires normally open contacts. SOMETIMES one can rewire the pedal internally, but you have to be mechanically and electrically inclined to do that.
Jun 04, 2011 | Casio Privia Keyboard Case
My Casio Px 330 keyboard is about 1.5 years old. After the instrument has been played for 20 minutes or so, one note (D above middle C) sounds very loud regardless of how hard it is struck. The problem...
Jun 02, 2011 | Casio Privia Px330 Px-330 88 Key Digital...
Hi, when I play a chord on my Casio-656 keyboard it sometimes sounds out of tune - if you hit the chord again it plays correctly. Is this a fault or a setting? It seems to be intermittent so that would...
I would check your fingering... You MAY be late in hitting a particular note and the using auto chord... this can cause the problem. Another thing is if notes are hit with different velocity that can affect the sound. Sometimes certain voices have VELOCITY switching which actually changes the voice depending on the velocity you hit a note.
May 19, 2011 | Casio Music
I have a Casio WK-110, when I play Major chords 2 octaves below middle C, an extra note is "played". For example, when I play C-E-G together, a B "plays". What can be done about that?
Verify that one of the automatic chord modes is not active. If you find other combinations triggering other notes, download this scvhematic showing TYPICAL Casio key matrix scanning:
http://elektrotanya.com/casio_wk-1200.pdf/download.html
The matrix is shown on page 5. It could be one of the disconnect diodes has failed. These diodes shown below the matrix on page 5 prevent crossing between multiple notes held during scanning so each can be individually scanned. Not there are TWO contacts per key and this is used to sense key velocity as one closes before the other.
Jan 19, 2011 | Casio Music
I fixed the dead keys on my Casio WK-200 keyboard. Now some...
Most of these have VELOCITY sensing and that involves two contacts per note. If the velocity sense on those notes is somehow not working, broken wire or trace on the board or short that MIGHT cause your problem.
Aug 12, 2009 | Casio Music
Casio PX3 Privia 88Key Digital Stage Piano Logo
29 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
