Question about Nu Mark Numark Cdn36 Dual CD Player CD Player
Not reading cd
After incerting a cd into the right side tray sometime on several atempts i will get a no disk reading
  • dennvill Dec 03, 2008
    The left side disc player of mu numark cdn-36 is not reading any cd
    Problem Solver:
  • 6 Answers
Either needs a manual cleaning of the laser or the laser needs to be replaced. Cleaning Cd's generally will not work in this situation
Posted on Dec 14, 2008
Xbox disc reader does not think a disc is in tray for xbox 360 games
This is a common issue.
1. Make sure your disk is clean. Dirty disk can cause disk reading issues.
2. Clean the drive with a CD/DVD laser cleaner.
3. Replace the laser. You can get a replacement from Ebay for $10-15. Make sure you get the right one for you drive. There are several different models.
May 09, 2010 | Microsoft Xbox 360 Console
I incert cd and it will not play auto as set up
Hi ambmarks, use this guide http://www.fixya.com/support/t3063410-tsstcorp_cd_dvdw_ts_l633a_combi_drive to resolve it. It's as simple as ABC.
Till next time, take care of your pc/laptop
Feb 07, 2010 | E-Machines emachines (emachinees) CD-ROM...
The player only intermittently recognizes CDs inserted; it does not seem to make any difference whether they are commercial, recorded at home, etc. Sometimes it says "insert disk," sometimes "no disk." ...
A CD tray is usually powered by a rubber strap, the belt can slip through, causing the electronics to miss the input timing, including a microswitch or copper contact which is activated at the closed disc tray so that the laser is focussed to read the table of contents Due to the fact that the spindle motor is activated. And in some players (interchanges there is also a selects witch that can be contaminated. a suggestion to help in the link
How to Fix DVD or CD Player That Won Open
Jun 30, 2017 | Philips CDR950 CD Recorder
MY CD TRAY KEEPS MOVING IN AND OUT WITHOUT MY PROMPTING.IT DOES NOT READ ANY CD I WISH TO VIEW.I HAVE TRIED SCANING FOR VIRUSES BUT IT DOES NOT HELP. THE TRAY MULFUNCTIONS RIGHT FROM SWITCHING ON THE...
The drive is malfunctioning -- when it cannot read the CD-disk, it opens the tray. For less than $40, you can buy a brand-new CD/DVD-writer, and responsibly recycle the malfunctioning device.
Nov 13, 2009 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
CD drine issue
To manually open the CD Drive, straighten a paper clip and insert it into a tiny hole in the front of your CD drive and push the paper clip gently into the drive and the tray should then pop open.
Open and close this several times, then insert a disc into the drive and see if it will read the disc.
If not the drive is dead and needs to be replaced.
Nov 18, 2008 | Acer (KV.16X04.007) DVD Drive
Disk reading error
Hi Tyrell,
What kind of disc is it? The PS2 can sometimes have a dirty lens and not read discs. It does not matter if the Disc is new and unscratched.
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. REmove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the REset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the Cd tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the Cd area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. REmove the little white disc from the Cd tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and your in business.
If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact Repairtech@playstationclinic.com
Nov 04, 2007 | Sony PlayStation 2 (PS2) Console
Nu Mark Numark Cdn36 Dual CD Player CD Player Logo
161 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
da surgen
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
