Question about Garden
What would have caused my talon whipper snipper to seize?
I had the pull rope replaced on my whipper snipper and I have used it twice and now it is seized, there is no give in the cord at all. Is this likely to be a problem with the cord, or has the engine just given up?
    Sergeant:
  • 316 Answers
Hello, lack of lubrication will make engine seize up,and also when the trimmer is hung up with the engine down the cylinder will fill up with fuel to where you cant pull rope,found this out myself,hope this helps,,
Posted on Feb 21, 2012
2 Suggested Answers
evwood
  • 50 Answers
SOURCE: pretensioning starter cord on ryobi whipper snipper.
This was answered in a previous solution
Posted on Jan 03, 2009
How to change a pull cord on STIHL FS51 whipper snipper
here's a nice vid on the FS55 which may help a little: How to Replace Starter Rope in Stihl FS 55 Trimmer Hunker
Here's another vid of a gas powered weed wacker.
https://www.youtube.com/watch?v=hdtbsjb9saQ
Best wishes.. I hope this is at least a little helpful.
Nov 21, 2017 | Stihl Garden
Victa Tornado Whipper Snipper 2-stroke. Why doesn't it start?
Rebuild or replace the carburetor. Whichever is cheaper and that should solve the problem
Feb 04, 2016 | whipper snipper Garden
Restringing a talon hawk whipper snipper
There may be a latch that has to be released in order to rotate it.
Jul 19, 2014 | whipper snipper Garden
Pope whipper snipper starter cord problem
The first thing you need to do is take the recoil cover off. There are several parts to a recoil and one or more parts may be worn and coming out of place then jamming.Replace worn parts if this is the case. If the cord pulls freely when removed then you may have a problem in the engine, try turning the flywheel by hand with the spark plug out. If it does not rotate there is something inside the cylinder or broken in the crankcase. If it is a 4 stroke engine you may have fluid above the piston,you will find this out when you remove the spark plug. drain the fluid from the cylinder and replace the plug you will be good to go. Good luck
Feb 09, 2014 | Garden
Whipper snipper wont start
when you pull the rope with the plug out do you get any gas coming out of the plug hole? It sounds to me like you have a faulty carburetor that is causing the unit to load up on gas stopping the piston from being able to move all the way with the plug in it
Jan 25, 2013 | Ryobi Garden
Sthil whipper snipper fs38 won't engage the starting pull mechanism, it turns but won't grab drive coupling
remove the recoil cover and check the dogs that engauge the starter to the flywheel
Jul 28, 2012 | whipper snipper stihl fs 38
What is the spark plug gap on a Talon 25cc blower vac (AB320325)
The same engine on a Talon 25cc whipper-snipper has a plug gap of .025" according to the owner's manual.
Dec 11, 2010 | Garden
Talon Whipper Snipper won't start suspect fuel not getting through
I have the same problem. The plastic primer has broken into pieces. i have emailed the Talon help desk - 'customer.service@husqvarna.com.au' but no reply as yet
Dec 13, 2009 | Talon Electronics - Others
How do I replace the pull rope on a Talon Eagle Classic whipper snipper? I have tried but am unable to recoil the spring thing.
This can be very tricky.
You have to turn the assembly clockwise to put tension on the spring and hold it in this position while you attach the new rope. Then release the tension and let the spring release pull the rope back into the assembly.
DO NOT let the spring get out of the cavity in which it fits. Getting these things back where they belong can be a real headache.
Oct 19, 2009 | Garden
Garden Logo
259 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
