Question about Electrolux Dryers
How to remove the drum on model number wer211eso
2 Suggested Answers
Controlfrk
  • 304 Answers
SOURCE: need to know how to change heating coil in white
The link below discusses disassembly of models similar to yours. The main difference is that the manual covers models with front controls whereas yours has top controls.
Unplug dryer. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Looking down inside dryer on left and right see a screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior.
Continue with "Removing the drum" on page 69. Having removed the drum exposes the heater behind it and safety thermostats above the heater shroud. The heater is generally purchased and replaced as a coil only not as a complete assembly as described in step 4 of page 72. Look for a break in the coil by touching all sections until found. If the break is not found check thermostats, motor switch at back of motor and heat contacts in timer for open circuits. Repair as necessary.
Reverse above process to reassemble.
Dryer Service Manual
Posted on Oct 01, 2009
Location of fuse model WER211ESO dryer
The fuse is probably related to the mains plug fuse and unlikely to be this as the machine switches on. Possibly the heater or heater thermostat. You may need a engineer to confirm which one.
Jan 17, 2014 | Electrolux Dryers
Maytag ensignia
follow this steps and fix it. God bless you
Drive Motor
The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer stops the motor might be defective. If the dryer stops and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. Also try rotating the drum by hand with the belt off, it should rotate freely. If the drum doesn't turn freely, determine what is causing it to bind. The dryer motor can't be tested easily. If the drum turns freely and the blower wheel is clear, and yet the dryer still keeps stopping mid-cycle the motor may be defective. it will need to be replaced. It is not serviceable.
Enter your model number to see parts for your dryer.
Help me find my model number
Drum Roller Axle
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely which can overload the motor and the dryer stops. If the dryer stops mid-cycle, remove the belt and spin the drum, it should spin freely. If not, check the rollers and roller shafts.
Drum Roller
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If they are worn out or start binding the motor can get overloaded and the dryer stops. If the dryer stops mid-cycle, check to be sure the drum turns freely with the belt removed. If not, check the rollers. Do not lubricate the rollers or roller shaft, lubrication will attract lint and cause the roller bearings to wear out faster. If the rollers don't turn freely, replace them. The roller shaft can often be reused, unless it has worn down. Clean the shaft thoroughly before installing the new rollers.
Drum Support Roller & Axle
This dryer has drum support rollers.There will always be two supporting the rear of the drum and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely. If not, check the rollers and rollers shafts. If they are worn or do not turn freely they will need to be replaced.
Drum Slide, Glide, or Pad
The front of the dryer drum is supported by small pieces of plastic-like material. As the drum rotates, it slides on these plastic pieces. If the dryer stops mid-cycle, it may be that one or more of these plastic slides or glides has worn out. When they wear out the drum can start binding and put strain on the motor. The motor then shuts down and the dryer stops. Check the glides for wear and replace as needed.
Drum Bearing
The drum bearing supports the rear of the dryer drum. Over time this bearing will wear out and may cause several different problems. If the dryer stops during the cycle it may be that this drum bearing has worn out and is putting too much strain on the motor. If the belt is removed and the drum spins freely, the drum bearing is probably not worn out. If the drum bearing is worn out, there may be some grinding or squealing, and the drum will be hard to turn.
Drum Support Bearing
Dryness Control Board
The dryness control board shuts off the dryer when the clothes have reached the level of dryness selected by the user. If the dryer stops too early, the dryness control board might be defective. This is not very common and other possibilities should be checked first.
Jul 21, 2013 | Maytag Dryers
Hi, I have LG washer and dryer combo WM3431HW. How can i remove lifter (part#4432er2004a) from drum, and is there a substitute part? Thanks.
When I check your model number, the lifter comes up as part # MFE38265101
Changing one,...... oh, you really got to want to. On a difficulty scale of 1 - 10 for repairs on this washer / dryer combo, I would rate it about a 10. Basically, you have to remove the motor, remove the entire outer drum, seperate the halves of the outer drum allowing removal of the inner drum, and eventually removal of the lifter from the back side of the inner drum. If you can do the job in under two hours I think you would set a world record.
Mar 13, 2011 | LG Washing Machines
I need to know which color to connect to which connectors on the timer of a wer211eso dryer. george
here is a wiring diagram:
http://www.applianceaid.com/images/swfedwd.jpg
Oct 27, 2010 | Dryers
Fin on gas dryer loose.
The model number is generally inside the door or door jamb area. The top must be removed to access the drum to tighten the screws to the fin
Apr 15, 2010 | Maytag SDG4606A Gas Dryer
I have a frigidaire dryer model#crer5700ASO and im trying to locate the heating element . Which is the best way to get to it.
it's behind the drum,the drum is on a rear bearing,it slides down into the holder so to remove the drum you have to lift the drum up in the rear and you'll see the heater on the back wall part number 131553900
Parts & Accessories | Shop & Find Lawn & Garden, Appliance Parts at Sears PartsDirect | SearsPartsDirect.com go here put your model number in and you can see dryer
Nov 27, 2009 | Frigidaire GLER642A Electric Dryer
Need to know how to change heating coil in white westinghouse dryer model number wer211eso
Sep 30, 2009 | Electrolux Dryers
Cracked drum on the DLE3777W model
The drum is a part number 3045EL1002F which will set you back at least $135. Still well worth the repair, especially if you can install it yourself. You have to remove the top by removing 3 screws in back and sliding top back about 2 inches and lifting off. Then, remove front panel. Remove 4 screws holding the front bulkhead. Remove belt from drum. Remove drum. First time might take a hour, second one you do will take about 15 minutes.
Now, don't rate me down because you don't like having to repair your dryer. I didn't manufacture it. I'm just giving you a bunch of free advise.
May 18, 2009 | LG DLE2512W Electric Dryer
Bra wire stuck in the drum
Are you from outside the United States? I tried running the model number in our system and it does not come up as submitted. In the GE/Hotpoint Look-up there are only three models listed...Without a good and verifiable model number, I cannot help further.....
Feb 14, 2009 | Hotpoint Aquarius WD63 Front Load...
Water leak under the rotating drum
Have you removed the front panel?
If not remove front panel two screws 5/16 on bottom
Start the washer in a cycle. look with a flash lite and look for leak.
It maybe the rubber boot.
Please let me know if you have any other questions.
I will also need model number, because a AWS52NW is a top loader model number not a front loader.
T
Jul 27, 2008 | Speed Queen AWS52NW Top Load Washer
Dryers Logo
82 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
