Question about GE JVM1870 Microwave Oven
Mmv5000baw maytag over the range microwave lights up will not accept any numbers from keypad.
2 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: MMV5000BAW maytag over-the-range microwave
Found this in the GE section instead of Maytag, but we're happy to answer it anyway.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doen't fix it.
If not, you may have a shorted keypad or bad control panel, either of which we can repair economically.
Please write back with more details if you need further help.
Posted on Nov 25, 2007
Error code SE on Maytag Microwave
The error code SE stands for " Systems Error " which indicates there is a short in the keypad membrane causing the system to lock up. The only option is to have the keypad replaced for normal operation.
Mar 27, 2011 | Maytag Appliances Over-the-Range Microwave...
Screen displays -SE- , none of the keypad buttons work
The word -SE- , means systems error, the cause is a short in the membrane of the keypad. The only solution is the keypad must be replaced.
Mar 05, 2011 | Maytag Appliances Over-the-Range Microwave...
My maytag over the range microwave will only work in seconds and doesnt heat probably because its timing in seconds
Hi, Keypad is going bad, but there may be other problems also...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 18, 2010 | Maytag Appliances Over-the-Range Microwave...
The touch pad on the microwave lights up, but will not respond when any of the keys are touched.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it still will not accept key input, your membrane keypad has failed.
Depending on your specific model number, the membrane keypad may be available separately, or you may have to order the control panel frame, which comes with a new keypad.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Let me know if I can help further.
Aug 20, 2010 | GE Profile Spacemaker Over-the-Range...
Locked timer/keypad
Try unplugging it for a few minutes. If that fails, read the owners manual for instructions on how to unlock.
Jun 26, 2010 | Maytag Appliances Over-the-Range Microwave...
Maytag over the range microwave won't start
It sounds as if your keypad has failed.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & DIY help and/or an estimate.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Dec 05, 2009 | Maytag Microwave Ovens
Maytag over the top microwave keypad some keys are dead
You have a failing membrane keypad.
So until it is repaired, please leave it unplugged or leave the door open.
NOTE: FixYa's Web site is currently not notifying us when replies to our Clarification Requests are posted.
So please reply back directly to me with your brand and full model number from the tag in or on the unit for more help or free do-it-yourself tips or an estimate if required.
We're happy to help you with free advice and once we have given you our final answer, we'd appreciate your thoughtful rating of our answer.
William E. Miller
prototech@usa.net
Sep 26, 2009 | Maytag 2.0 Cu. Ft. Over-the-Range...
I have LG over the range microwave and the keypad will not let me enter 0's. Such as 2:00 minutes cooking time. I can enter 2:25 but the keypad will not accept 0's.
Its just a problem with that button on the touch pad, gonna have to take panel off and check the connections could be a burnt wire or broke wire.
Sep 03, 2009 | LG Over-the-Range Microwave
Keypad does not always work
HI. you will need to replace this malfunctioning key pad asap. this will require you to disassemble the unit, in order to reach the actual touch pad board. It is not an easy task, and i recommend a professional tech, if possible.
Aug 26, 2009 | Maytag MMC5000 Microwave Oven
Nov 25, 2007 | GE JVM1870 Microwave Oven
GE JVM1870 Microwave Oven Logo
35 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
