Question about Maytag MGR6772 Gemini Gas Kitchen Range
Maytag Top oven safety concern (gas flow excessive?)
Our Maytag Gemeni works well most of the time but, occasionally when using the upper oven, it begins making a strange sound as if the gas is flowing but it's not igniting. I can see flame burning but the sound is crazy and I worry that it'll explode! To solve, we cancell and start the oven again...works most of the time but occasionally have to restart a few times to get rid of the trouble. Any thoughts?
  • 76 Answers
SOURCE: After first Ignition cycle igniter stays on too briefly to open gas valve gas.
Valid Most likely the problem with your dryer is the coils for the gas valve. Remove the access door (on the bottom right side on the front panel) and you can see the gas valve with three coils on top of it. They are coming as a kit with complete instruction. The part number for this kit is AP2669614.You can buy it here http://click.linksynergy.com/fs-bin/click?id=SrmyP8LkIos&offerid=92089.542517043&type=10&subid=
Posted on Jan 16, 2007
jsrock516
  • 5911 Answers
SOURCE: After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Posted on Apr 29, 2007
fridgetech
  • 473 Answers
SOURCE: Maytag Gemini Electric stove fault code F 1-2 when using the oven(s)
The oven temp sensor has gone bad.  F1-2 would be for the lower oven and F1-1 would mean the upper oven.  If you give me the model # from the sticker on the oven I can direct you to a diagram, part #, and price.  These are very easy to replace.  Should be located inside the oven in the upper right or left hand side.  It looks like a silver rod about 4-8 inches long and crimped on the end.  Most of them can be removed from inside the oven by removing the two screws, pull out the sensor (harness and all) plug in the new sensor, put the screws back in and your done.  Some have to be removed from the back of the oven by removing the lower, larger back panel and follow the same process as mentioned above.  Hope this helps.
Posted on Oct 19, 2007
SOURCE: crosley gas oven will not heat up
That's my mom!!! Go Sheila!!! Hehe.. -RET-
Posted on Jun 04, 2008
ngfam1
  • 639 Answers
SOURCE: problem with oven preheating
Hi, I'm Neil
It is a fire hazard! Be Careful!
It's a gas regulator or thermostat
This time you will have to call the the manufacturer for service!
If it's under a year old ,your under warranty and it will not cost you anything!
Please give me a solution rating here!
Thank You
Neil
Posted on Aug 24, 2008
My Gemini double oven needs to heated to 550 degrees before the broiler will ignite. I've been dealing with this for years. How can I fix this issue? Jim
This repair you had done was to repair and prevent the door to the upper oven from building with gas as the broiler was know to do. This was a safety issue for the time period UL required. You can select the low broiler to speed up you preheat time but there is no known fix to by-pass this mode. Sorry for the bad news, good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Apr 06, 2016 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Top oven does not work...
measure the resistance on the valve if you have continuity its good if not replace it
May 27, 2008 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag Gemeni double oven stovetop stopped working
Thats the controller, you'd need to call a professional no quick fix for that one sorry. besides attempting to fix it your self will cause more damage than good
Jan 02, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag oven will not heat, no gas flow. Broiler works, clock and timer works.
You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface igniter will not come on - check igniter with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new igniter time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface igniter problem. The hot surface igniter often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the igniter. See this service sheet for the proper way and amp readings for the hot surface igniter system. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar igniter can glow orange-red and still be bad!! How a common gas valve works - click here.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 13, 2011 | Maytag Microwave Ovens
I have a Maytag (Magic Chef) gas oven model CGR3730ADH. The oven will not heat up. The ignitor will glow/heat up but there does not appear to be any gas flow. The top burners work normally. After...
HI,
First of all, thank you for all your information. A rule I live by, even if an ignitor glows does not mean it works. The ignitor works on the flow of electricity through it not how bright it glows. If you can use a amperage meter, hook on one of the two wire to the ignitor directly. You need 3.2 to 3.6 amps to open the safety valve. If lower than 2.6 amps, it will not allow gas to enter the burner. If you have no clue what I am asking you to do, you can purchase and replace the ignitor and life will be better. P# 12400035. Its not difficult to change, the screws holding the ignitor in place sometimes strip out, when you get them off, you can replace them if needed.
Good Luck
Jul 23, 2011 | Maytag Ovens
Hotpoint gas stove. burners work, oven and broiler do not.
Probably the safety valve. This unit broils and bakes off the same gas burner. A spark ignitor lights the pilot and this save gas because no standing pilot is needed. It takes a few minutes for the thermocouple bimetal combo to release the gas. When the temp gets to the desired rate then the bulb on the oven control closes off the flow of gas. To recap: The flow of gas comes from a regulator along a rail which supplys the gas to the top burners and the oven control. older models had pilot light tubing going down to the oven and to the top burners. This newer style uses a spark module to light off the top burners and the oven. So when yall turn the the oven on the spark ignitor lights the pilot first and then after the mercury bulf thermocouple heats up the bimetal inside the valve opens allowing gas to flow out to the pilot and ignite the gas burner. the temp rises and the mercury bulb oven control expands closing off the flow but not the gas safety valve. I would suspect the safety valve on this one.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 09, 2011 | Hotpoint RGB528 Gas Kitchen Range
Oven slow at starting, there is smell of gas before oven turns on
If there is a smell of gas PLEASE STOP USING IT you risk fire or explosion or both. Please get a registered Gas-fitter to look at this. If you can Turn OFF the Gas at the Wall/Outlet. Until it can be looked at. If you smell gas it is very dangerous.
Feb 11, 2010 | Ovens
Oven takes a long time to heat up.
Hello. To go 12 years without issues is excellent. Now however you will have to make a decision to repair or replace. Be sure to get a firm estimate before you repair and compare that to the cost of replacement.
here is what may be causing your problem:
Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
Aug 15, 2009 | Maytag MGR5750 Gas Kitchen Range
Maytag gas oven doesn't heat, but oven's pilot light is on.
Get the oven checked out by a professional, if you have a gas leak you can easily blow up the entire house and you with it. I think you have a faulty gas valve based on what you wrote
Mar 03, 2017 | Ovens
Maytag gemeni oven
This sounds like a faulty igniter in the oven (about $45,00) online and you can replace it yourself. Look inside the oven and remove the bottom. You will see a long tube where the gas comes out. At one end of the tube is a coil of wire that is suppose to get white hot and yours is bad, probably only turning red when you turn on the oven. Good luck.
NSSMS
Jul 04, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Open Questions:
Maytag MGR6772 Gemini Gas Kitchen Range Logo
66 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
