Question about Maxtor Hard Drive
HOW DO YOU ERASE A HARD DRIVE
HOW TO YOU ERASE A HARD DRIVE
  • rhayes4026 Nov 30, 2008
    i have a virus and want to wipe the harddrive and start fresh
  • 19,396 Answers
Fastest, and most efficient way to erase an hard drive is by formatting it.
If the hard drive is the one in which the system is installed, then you will need to boot the computer using the system install disk (eg. Windows XP disk) to format the hard drive.
Posted on Oct 27, 2008
Wanto erase all data from firelite backup drive
You could try data rewriting software to erase your data, like AOMEI Partition Assistant Erase hard drive feature: http://www.extend-partition.com/help/wipe-data.html first you need to connect this disk on your computer and then download the free version of Partition Assistant to use.
Sep 25, 2012 | FireLite (USBFLB80) Hard Drive
How do I reformat my toshiba canvio 500gb external hard drive for my macbook? If I go to disk utility and erase it, wont it erase the backup software as well?
The disk utility programs should be on the main drive inside the computer...you need to make sure you tell the program which drive you want to erase..Say the external drive comes up as drive "d"..then you want to tell the drive utility software to erase the "d" drive
Dec 25, 2010 | Toshiba Canvio 500 GB USB 20 Portable...
Want to format this drive for Mac
Go to the applications folder and then the utilities folder and double click on disk utility. Once open select your hard drive from the left hand options. In the right hand side of the disk utility you will see the following headings first aid then erase click on erase. Choose Mac OS Extended (Journaled) for the Volume Format and then name the hard drive and then click on the erase button below nad follwo the instructions. Hope this helps
Nov 01, 2010 | BUFFALO 500GB DriveStation Combo 4...
Can you tell me how to reformat my WD Elements external drive for use with a Mac? Thank you
You can use a pc formatted drive with a mac but to format it as a mac drive go to applications then into utilities then go disk utility. Once opened in the left hand side choose your hard drive on the right hand side you will see buttons "First Aid", "Erase", "RAID and "Restore". Click on Erase under volume format choose Mac OS Extended (Journaled) then name your hard drive and then click the erase button down below the name box. Hope this helps
Jul 06, 2010 | Western Digital Elements powered by WD 320...
Hitachi ext. drive formatted for a PC, but now I want to read it
you need to reformat the drive for MAC...
Use Disk Utility To completely erase a Macintosh hard drive that runs OS X 10.3.x or above—not just individual files on the drive—you can use the Disk Utility that is built into the Macintosh operating system.
How to Use Disk Utility to Erase a Macintosh Hard Drive (OS X 10.3.x or 10.4.x)
  1. You must reboot your computer using the OS X system CD that came with your Macintosh. To do so, follow these steps:
  • Insert the CD into the CD drive.
  • Hold down the C key during the startup process.
  1. Select your preferred language. You will then see the Welcome to the Mac OS X Installer window.
  2. From the Installer Menu Bar, click Open Disk Utility. You will then see the Disk Utility window.
  3. In the left pane of the Disk Utility window, click the drive you want to erase.
  4. In the right pane of the Disk Utility window, click the Erase tab.
  5. From the Volume Format drop-down menu, select Mac OS Extended (Journaled).
  6. In the Name field, highlight the existing text and type the name the hard drive is to be called after it's formatted.
  7. NOTE: If you ever plan to connect another computer running OS 9 to this hard drive, you'll want to install the Mac OS 9 disk driver, so that this disk will be visible from an OS 9-booted computer. If you don't know if you will do this in the future, it's best to install these drivers.
  8. The following are the available security options:
  • Don't Erase Data—This option only rewrites the headers on the disk. Files can be recovered by forensics, disk utilities, and other advanced recovery software.
  • Zero Out Data—There are forensics utilities that, albeit expensive and time consuming, can retrieve zeroed-out data.
  • 7-Pass Erase—This is considered sufficient by government standards to erase data from a disk. It writes random data over the disk seven times. It may take several hours or more to complete this process.
  • 35-Pass Erase—This makes it absolutely impossible to regain any data off the drive. This option takes an extremely long time, possibly more than one day.
  1. Click the radio button in front of 7-Pass Erase (recommended by UD).
  2. Click OK.
  3. Click Erase.
  4. Confirm you want to erase. The program will unmount the volume, partition the drive, and rename the volume to the name you typed in step #7 above.
May 19, 2010 | Hitachi Computers & Internet
How do I reformat an external Hard Drive that came with NTFS to work with MAC OS X version 10.4.11? I've gone to Disk Utility but then I don't know what to do. The instructions say to use the Erase...
Disk UtilityTo completely erase a Macintosh hard drive that runs OS X 10.3.x or above—not just individual files on the drive—you can use the Disk Utility that is built into the Macintosh operating system.
  2. Click OK.
  3. Click Erase.
Apr 28, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
I cant erase the files in my hard disk, if i erased it, it's keep on comimhg back..what will i do?
INFO:
Files are never really erased from a hard drive.
At various stages files are always recoverable.
RECOMENDATION:
To truly erase your hard drive take it out and completely destroy it down to many small parts.
Reformat the hard drive.
Hope this tip helps.
r/
David
Mar 11, 2010 | Seagate 250GB Maxtor DiamondMax Plus 21...
I have a 500 go Iomega hard drive and I'd like to delete all stuff on it... done through MACbook...
  1. In Disk Utility, select the disk you want to erase and click Erase.
  2. Specify a volume format and name for the disk.
  3. Click Security Options and select the option you want to use. Click OK.
  4. Click Erase.
If you want to securely erase the info make sure you choose 7-pass or higher.
Nov 24, 2009 | Iomega 500GB Ultramax HD Esata/usb/fw 500...
Erase complete backup from external hard drive. Also, how do I erase individual backups. Thank You.
Just format the drive - unless you have other stuff on it.
Be careful - make doubly sure that the drive you are formating is the extenal drive!!
May 19, 2009 | Western Digital My Book Essential Edition...
Erase and reformat to be compatible with new mac
Think I might have solved it myself. Here's how:
Open Disk Utilities and select the external hard drive. Select the "Erase" tab. Hit "Erase" at the bottom right.
That's all. Just dragged a folder onto it and it worked.
May 08, 2008 | Maxtor OneTouch II external hard drive...
Maxtor Hard Drive Logo
119 people viewed this question
Top Maxtor Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Rick Arnold
Mark Taylor
Mark Taylor
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
