Question about Sansui VRDVD4005 DVD Player/VCR
I would get my money back if I were you!
Your laser lens is probably just dirty , so try and run a cleaning disk in the dvd player, if none of your dvd's play then the lens is dirty and may have to be cleaned manually
but also some dvd players will only play certain formats ( i don't believe yours won't play them but check in the manual to see what formats it does play
electech
  • jason Oct 27, 2008
    this is the lens , and the laser is just under the lens , and i just wanted to help you because its not about the money or ratings , its about helping
  • jason Oct 28, 2008
    some dvd players "can only play certain formats" some can play high definition( HD) and alot can not
    it should say in your manual what ones its capable of playing
    also get a good cleaning disk that has many brushes on it for a good cleaning , otherwise it may have to be cleaned manually
    electech
  • 3 Answers
Hi I do Thank U but the only cleaner I ever knew about was the cleaners that u wipe off DvD with I never new of any that go in the machines Thank U very much
OH & I never had this problem we never got a manual with this or we cant find it
Posted on Oct 26, 2008
  • Sue Roberts Oct 27, 2008
    I think that is Probably what is wrong with it its probably Dirty & as far as playing DVD's it wont play any of them so it cant be that it doesnt play cirtain formates I just had to replace a DVD that was broke & it would play that but it played the other one I had witch was the same Thank U very much for giving me this Idea as far as im concerned u solved my problem it must be dirty so I will see if I can get a Disc that actually cleans in side the Machine
Whenever i put a disk in my mxt dvd player it loads and just comes up with no cd.
You said disk. If you have tried different dvd movies then I would suspect a dirty or weak laser. If it plays dvd's ok but wont play certain cd's then I would suspect a compatability issue. You can try one of those laser cleaners at most dept stores or if you take it apart (with it unplugged) the laser is located where you put the disk in and it has a small plastic lens you can clean with a q-tip and alcohol. If that doesnt help the laser is probably bad, depending on the player it would probably be cheaper to purchase a new player.
Oct 17, 2010 | Televison & Video
FUNAI DVD/VIDEO CASSETTE RECORDER WITH HDD (HDR-B2735D)
Based on your reply on #3 I suggest that you dont even bother going forward. These type of DVD player recorders tend to be picky in the disks that it accepts. There is no way around that or fix for that so the best and simplest solution that I can honestly give you is to return the unit this early and save yourself the headache. (honest opinion) but if you want to work at it we can do so too.
Sep 24, 2008 | Funai PY90VG DVD Player/VCR
Incert dvd read out sats NO
Hello
This usually happens when the DVD or laser lens pick-up has become dirty.All you need to do is
1. Check the disk for scratches.
2. Make sure the disk you are using fit the correct format specified by your DVD player.
3. Clean the laser lens with a DVD laser cleaning disk.
4. Insert a correctly formatted undamaged disk into your player,listen to see if it begins to read the disk,if it continues to make no sound.
5. Open the DVD player carefully and clean the lens with isopropyl alcohol and cotton swab.
6. If none of these solutions works out then a professional repair technician will be able to tell you if fixing your DVD player is worth the money.
BEST OF LUCK
Jul 13, 2010 | Toshiba SD-K760 DVD Player
The dvds are not detected - No Disc or Disc Error
Hi. These steps should help.
  1. Check the disc you're using for scratches and dirt. If the disc is damaged it won’t play properly, regardless of the DVD player’s ability to function. You can use a DVD repair device like the "Disc Doctor" to repair the DVD or purchase a new DVD.
  2. Make sure the discs you're using fit the correct format specified by your DVD player. For example, if your DVD player doesn’t support home-burned DVD-R's, then you can’t use a DVD that you made at home. You may need to upgrade to a newer model, most of which accept the latest DVD formats.
  3. Clean the laser lens with a DVD laser lens cleaning disc. DVD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  4. Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  5. Turn the device off and unplug it. Take off the outer casing by removing the three or four screws and lifting the top piece off. This will allow you to see if anything is simply stuck or jammed. If this is the case, a simple nudge back to the correct position will fix the problem.
  6. Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  7. Take your DVD player to have it professionally fixed only when none of these other solutions solves the problem. A professional repair technician will be able to tell you if fixing your DVD player is worth the money.
Nov 22, 2009 | Aiwa HT-DV90 System
Message ''disc is dirty'' appears
now u need to clean the player:
Be careful how you use this, but u can utilize canned air to blow out the debris from your player.
get a laser lens cleaner kit from walmart or something, it will cleans your laser lens inside the dvd player for you, if the canned air and laser lens cleaner doesn't work, your last resort is to completely unplug the player to see if it resets itself, if none of those works i would turn the player in under warranty or take it back to the store.
Nov 13, 2008 | Sony DVP-NS315 DVD Player
How to do DVD burning which does not complete? Why it is not finishing ?
the laser eye lens is probably dirty and a cleaning disk may correct the problem but if not then the unit will have to be opend up and cleaned manually ( there are creases in the laser lens that the cleaning disk won't get , but manually can be cleaned
Oct 27, 2008 | Televison & Video
DVD player
My Smasung DVD/VCR Combo stopped reading DVDs because of a dirty read head. It started by only playing disks sometimes, and progressed to never playing disks. I assumed it was a dirty laser lens so I bought a lens cleaner set. Unfortunately my player wouldn't play the cleaner disk.
So I took it apart and cleaned the laser lens manually with some isopropyl alcohol (the clenser that came with my cleaning disk), and a lens cloth (that came with my glasses). Just open the case (starting with the screws in the back) and remove the snap in cross panel that obscures the lens of the DVD portion. Put a drop of cleanser on the lens and gently wipe it with the cloth.
Oh and by the way, I take no responsibility if you break your own player while following my instructions. My own DVD player was far out of warranty at the time I cracked it open.
Dec 30, 2007 | Samsung DVD-V3500 DVD Player/VCR
Dvd won't read
My friend this could be caused by many things everything from a dirty OR damaged disk, or wrong zone or wrong tv mode disk ie, NTSC instead of PAL OR VICE VERSA! Or the laser unit could be stuffed or a cable connecting the dvd drive to the motherboard could be broken or out of place. Or the reader lens could be dusty or dirty. Some DVD disks need a damn good clean with warm soapy water to have any cleaning effect. clean and reins like you do the washing up! Check these things first. A word with a friendly local tech is the next step.....but we all know thats a money trail often more than the cost of a chepa new player!
Sep 08, 2007 | Samsung DVD-VR330 VCR and DVD Recorder
Dawoo DVD Player showing No Disk error
you have dirty lens, try to cleaning with 100% cotton buds. or you have damage laser eye, or broken flex ribbon wire, but first you have to do is to cleaning the lens with cotton buds.. if not reading after you clean the lens! change the laser eye and flex ribbon wire.
Aug 31, 2007 | Daewoo DVDS151 DVD Player
Samsung DVD-4600 DVD/VCR Player
Aug 16, 2007 | Samsung DVD-V4600 DVD Player/VCR
Sansui VRDVD4005 DVD Player/VCR Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
