Question about Bosch Dishwashers
Bosch door latch won't stay closed
Hi-
We have a one year old Bosch. This is our first problem. When going to start a cycle, I closed the door and the cycle started just like always except this time when I let go, the door opened and the cycle stopped. Our warranty has expired (just days ago). My husband is on floor trying to figure how to fix the latch. Any ideas?
Thanks a bunch!
5 Suggested Answers
  • 1073 Answers
SOURCE: door won't latch
replace the door latch part number 8193830 it will fixya
Posted on Apr 22, 2008
SOURCE: Can't close Bosch Dishwasher door
My Bosch wasnt balck but had a white bit that stuck up on the door that stopped it closing - to fix and it might work here use two screwdrivers to pull on both sides from behind as such - recreates the latch on opening!
Posted on Aug 30, 2008
SOURCE: Bosch SHY66C05: interlock broken, dishwasher rinse-aid leaks, and soap does not open (sometimes)
don't know what you did with the spring but it only needs replacing if it is broken
Posted on Sep 11, 2008
  • 423 Answers
SOURCE: Bosch SHX46A (6 years old) Selected
From your description, I doubt that the problem is door latch is the cause.
The first thing that a modern dishwasher does before it begins to fill with water is run the drain pump.  It appears that this DW is not progressing to the next cycle (inlet water) and because the pump runs even when the door is open, I agree that the controller card may have failed.
If possible, inspect all the wire connections (remove main power before you do this) ... if there is a loose connection, the controller could do odd things.
Good Luck!  Please report back what you find, OK?
Posted on Apr 14, 2009
SOURCE: Kitchenaid Dishwasher door wont latch
I have a brand new whisper quiet dishwasher model kudk02crbs4 I hook everthing up but the door does not lock what is worng I have no clue what wrong
Posted on Jun 12, 2009
Bosch dishwasher door pops open during cycle
Latch needs adjustment or replacement.
Jul 07, 2015 | Bosch Dishwashers
Less that 2 yrs old..door wont latch. As a consequence machine won't start.
It is possible the door latch is faulty or the springs at base of dishwasher are soft and need adjusting. the springs keep the door in position. refer this site for parts.
Dec 31, 2012 | KitchenAid KUDS30IXBL Builtin Dishwasher
Bought a 3 year old unit for my son in law, picked it up at a storage unit. Unit panel will only turn on when the door is open. When we close the door the lights go off and it won't start. HELP
Hi
Thanks for using FixYa. This issue can be either due to a faulty door latch or door lock switch which is not engaging itself. And, if the door latch will not engage the dishwasher will sense it as open door and will not start. You'll need to check & replace the part that has gone bad with a new one. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 23, 2010 | Bosch Integra® 500 SHX46A0 Dishwasher
Bosch dishwasher, SHE43M 30" built-in, door won't latch closed, yet can still start cycle.
check latch on dishwasher side of the unit to make sure it has `nt got loose they make them so you can remove them when the unit is discarded so children can`t get trapped in side
Nov 06, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch 4002 detergent door will not lock shut at start of cycle
You need to open-up the door sections by removing the screws around the perimeter. This is not easy since it takes three hands to hold and disassemble. Please disconnect electric so you do not short any electric parts within the door shell.
The release mechanism may be no good for the soap dispensor tray, or you may find a corroded wire connection to the release. In many cases if the soap tray does not release (but closes) it can be a faulty signal from control panel,however you say the tray will not stay closed; this is most likely a faulty release/latch mechanism which you will see when you open the door shell sections.
Many models have star head screws and will need a star screwdriver (there are 4 or 5 sizes).
Good luck, MACGIVOR
Oct 24, 2009 | Dishwashers
Opened door during cycle, latch now stuck in closed position, can't re-close
twist a paperclip around some pliers so you have a circle opening. then hook the paperclip around the latch and pull outward with the pliers. once the latch is facing outwards the door should close again
May 30, 2009 | Bosch Evolution 500 SHE45M06UC Built-in...
Bosch SHX46A (6 years old) Selected regular cycle, pressed On and closed door. Cycle did not start normally. Pump runs, but no water is coming into the DW. I confirmed the water supply line is turned on....
Apr 14, 2009 | Bosch Integra® 500 SHX46A0 Dishwasher
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
The Rinsing aid door keeps opening in my Bosch dishwaser
I believe paddy55 is correct about the rack position affecting the rinse agent door. When the top rack is moved to the higher position, the rack hits the latch on the rinse agent door, causing it to pop open.
Move the rack back to the lower position and see if the door stays closed.
Apr 06, 2008 | Dishwashers
Open Questions:
My Bosch 800 series won't start when I close the door, instead it flashes the InfoLight on for half a second and then powers off. The unit is a SHXN8U55UC/07. Everything seems normal, I open the door, press the power button and the display lights saying 2:09 and the light under Auto is on. The Auto light, InfoLight, and display are flashing once a second. The InfoLight is the red light that shines on the floor while it is running. I press the start button for a second until it beeps, then close the door. The InfoLight will light up for half a second and then it turns off. Normally it would turn on and stay on while the cycle runs. When I open the door, all lights and display are off. If I press the power button, it will come back on. I called Bosch technical support and they had me go through a reset cycle. This involved, IIRC, holding the power button for 3 seconds, then closing it and waiting a minute. When this didn't solve the problem, they said I needed a repair visit. Two points of interest: I did the troubleshooting with Bosch at 10pm, then gave up and went to bed. Around 6pm the following evening I opened the washer up and the display was on and showed clean. The dishwasher had obviously run, and was still a little warm like it had finished running in the last couple hours but not hot. I have been unable to replicate this, though I've only waited ~12 hours so far. This was working fine for 6-9 months, then we had a contractor in who pulled out the flooring and cabinets. They left the dishwasher powered on and connected to the power supply, but not water or drain. Since re-installing the dishwasher, it has not worked.
Feb 09, 2017 | Bosch Dishwashers
Dishwashers Logo
194 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
prem mathew
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
