Question about Philips 42PFL5603D - 42 IN. LCD HDTV
NEW XFINITY hd BOX NOW HAVE DISTORTED COLOR AND CONTRAST ON MY PHILLIPS 42 IN LCD TV
GOT NEW XFINITY hd BOX WITH hd CONNECTIONS NOW HAVE DISTORTED COLOR AND CONTRAST
  • 90 Answers
SOURCE: no sound on the hd setting on my lcd phillips hd tv
look in the owners manual about installing devices or components--- sounds like you have something hooked up wrong that is not allowing the video and sound to work--- if that doesnt work--- try using a combination device and hooking the two items to it--then run that device's wires to the television
Posted on Feb 24, 2009
  • 4234 Answers
SOURCE: phillips 42 inch tv
The stand base part number is 310430814621 and is available for $71.58 from tritronicsinc.com
Dan
Posted on Jul 30, 2008
Highdefjeff
  • 124 Answers
SOURCE: need help with TV calibration for philips
Try these, Contrast: 53 Brightness: 56 Color: 45 Tint: 2 Sharpness: 2
Color temperature: Off
Dynamic contrast: Off
Digital Natural Motion: Off
DNR: Off
Color enhancement: Off
Active control: Off
Posted on Mar 03, 2009
  • 17 Answers
SOURCE: Phillips 42 inch LCD 42PF9730A Redlight flashing
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Posted on May 13, 2010
SOURCE: screen is black but we have sound
The problem is a faulty inverter kit (2 boards).
I live in the Netherlands and had it twice, tv is 2 and a half years old! In the Netherlands Philips replaces the inverterkit without any
costs for the consumer (even after warranty time) cause they have
admitted that it is a production fault.Philips made a new inverterkit
which should solve the problem indefenit.Be sure the kit is Version
1.3! I had 1.2 after the first problem, and that went wrong after 7 months again. Today got revision1.3 installed which is Philips final solution.
Posted on Jul 21, 2010
Testimonial: "Thanks very much for your help. I will contact Phillips Ireland and see what they can do.Thanks again"
Phillips 42
The most common way to connect a PC to a TV is with an HDMI cable. Most new TV's have this input, however not all computers have this output. Does your PC support this connection? If so, you can get an HDMI cable either online (I recommend monoprice.com) or from any local big box store (Walmart, Target, Best Buy)
Jan 09, 2012 | LG 42PC3RA 42 in. HD-Ready Plasma TV
Sanyo lcd-32k40 features
  • Model: Sanyo 32K40 Multi System LCD TV
  • World-Wide NTSC/PAL/SECAM Color System - Watch any video signal on this TV!!
  • World-Wide NTSC M, PAL BG, PAL I, Secam BG, DK/ PAL DK TV tuners
  • 32 inch LCD TV with 3 HDMI inputs and PC input
  • USB input for direct media playback
  • 45,000:1 Dynamic Contrast: While viewing either very bright or very dark scenes, it can be difficult to distinguish main images which blend into the background.
  • Dynamic Contrast dramatically mitigates this problem by adjusting the backlight intensity, providing up to a 4X improvement in contrast.
  • 6.5ms Response Time
  • Widescreen 16 X 9 Format
  • World-wide Dual Voltage 110-240 volts 50-60 hertz
  • HDTV monitor (HDTV tuner required for HD reception)
  • This is a multisystem TV. All Multi System TVs in the market do not have a digital TV tuner: What does this mean?
  • To watch digital channels (ATSC Broadcasting in US and DVBT broadcasting overseas) you need a digital source/tuner like a cable box, digital tuner, satellite service, etc.
  • To get the best quality video on this TV you need a source that has a digital connection like HDMI or component.
  • Wide Screen Mode allows you to watch conventional 4:3 aspect ratio broadcasts in wide screen (16:9) mode.
  • Steady Sound® equalizes volume levels so there is consistent output between programs and commercials.
  • Built-in hidden speakers includes 2 (5W x 2) speakers to deliver dynamic sound.
  • Component Video Input offers the best video quality for DVD (480p and 480i), and digital set-top box (1080p, 1080i, 720p, 480p and 480i) connections.
  • PC Input allows you to connect your PC and display the PC screen on your TV.
  • Surround Sound Audio Effect
Mar 04, 2011 | Sanyo 42 in. LCD TV
How do u set your tv to hd
depends on what you want to configure settings for video has to enter the video option menu you can adjust the brightness 75 contrast 50 color 50 definition 50
in the case of channels can use the automatic search
Dec 05, 2010 | LG 42LC2D 42 in. LCD HDTV
How can I connect my non hd direct tv box to this tv?
Use the AV connections : the yellow, red and white round sockets on the back of both devices and make sure they are correctly joined, color to color.
Nov 30, 2010 | Vizio VW42LF 42 in. LCD HDTV
My 42 lcd phillips tv colur turns red and zig zag lines then turns itself off why is it doing this
You are not the only one I can tell you that. I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Oct 21, 2010 | Philips 42 in. Plasma TV
RE; NS-LCD42HD-09 THE COLORS ARE TERRIBLE. THE
Here are some preferred settings for the same model in 32" It should get you close enough to fine tune from.
  • Picture Modes
    • Picture Mode : N/A
    • Color Temperature : Warm
    • Aspect Ratio : Wide
  • Precision Settings
    • Contrast : 60
    • Brightness : 50
    • Color : 52
    • Tint : G1
    • Backlight : 3
  • Advanced Video Menu
    • Noise Reduction : Off
    • 3DYC : Off
    • Dynamic Contrast : Off
Dec 25, 2009 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Need help with TV calibration for philips
DNR: Off
Active control: Off
Feb 14, 2009 | Philips 42PFL3603D 42 in. LCD TV
Philips 42PFL5603D - 42 IN. LCD HDTV Logo
85 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
