Question about Sony UPDR150 Thermal Photo Printer
Mecha trouble problem cutter pos - Sony UPDR150 Thermal Photo Printer
- in my case I received the error "mecha trouble cutter pos"
I removed both side panels and the panel directly in front of the cutter
this gave me access to the cutter assembly where I found that the cable that runs the cutter had fallen off of the pulleys.
I was able to get the cable back onto the pulleys and now the printer works perfectly
Posted on Jul 21, 2012
How to fix mecha error on sony mhc-gx555
https://us.en.kb.sony.com/app/answers/detail/a_id/38877/~/the-stereo-system-malfunctions,-stops-responding,-or-displays-mecha-or
Jan 09, 2012 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
I'm getting a "Mecha Trouble
checking the gear by taking off both side panels and the panel directly in front of the cutter helped me - in my case I received the error "mecha trouble cutter pos"
problem was, the cable that runs the cutter had fallen off of the pulleys and after a bit of fussing, I was able to get the cable back in place and a working printer.
Sep 15, 2011 | Sony UPDR150 Thermal Photo Printer
Mecha error shows on the dashboard and goes off. Normally shows when the engine is first started in the morning.
I presume the "Mecha error" is in actuallity the "Check Engine" light? If so, the engine (powertrain) computer (PCM) would have stored a Diagnostic Trouble Code (DTC) in its memory. Find out what, if any, codes were recorded/stored in memory... we can take it from there.
Jun 10, 2011 | 2006 Hyundai Tucson
MECHA ERROR 003
i need best solution for mecha error 03 kodak printer 6800
Mar 15, 2010 | Kodak 6800 Thermal Photo Printer
Troubleshoot tm u220 printer
CUTTER WIRES
The printers come with a fine wire to the cutter motors, when the cutter engages, sometimes the motor screw is loose and movement of the motor does not help, the movement cuases this weak link to detach or barely detach causing this issue. The blade is in the correct position for this to happen. If the blade is not in the correct position determined by the sensor you will get no action.
Feb 12, 2010 | Epson TM-U220B Dot Matrix Printer
Kodak printer 6800 mecha error 11
this is error created at ur printers cuter unit , so open the frot cover and clean the all 3 sensors
Jul 03, 2009 | Kodak 6800 Thermal Photo Printer
Mecha error o3
Mecha error 03 is a malfunction of the main pinch motor. Ninety-Five percent of the time the problem is that the motor has failed. The machine will more than likely have to be sent in for maintenance.
Nov 27, 2008 | Kodak 6800 Thermal Photo Printer
E-Mecha...what does it mean?
Hi
What brand and model! and can you specify the trouble you encountered!
Jun 22, 2008 | Nakamichi SoundSpace 5 Shelf System
Sony up-dr 100 error 0007
This may well be a failure of the cutter switch sensor to reset. This worked for me.
Turn Off the Printer.
Remove both side panels and the plastic panel on the INSIDE of the DOOR on the right hand side. Then close the door and remove the plastic panel UNDER the door. This is held in place by two screws.
You will see a white gear on the bottom right hand side of the door. It is on the underside of the door. Turn this gear untill you can see the cutter move smoothly across the bottm of the door and return to the right side of the door. Listen for a click. This is the switch resetting. Close the door and power up the printer if you still get an error code 0008 or 0007 repeat the resetting process by turning the gear. BE SURE TO TURN OFF THE PRINTER!!
Dec 11, 2007 | Sony UP DR100 Thermal Photo Printer
Error message
Problem: The Printer does not detect the home position of the cutter during initialization.
Either there is a scrap piece of paper obstructing the path of the carriage that houses the cutter blade or there has been an impact on the lower side of the printer causing a bend in the metal that holds the home switch. This switch will trigger a sensor telling the printer that the cutter has reached the home position(right side)
Solution:Remove the paper scrap or Remove the door panel and check for damage on the right side of the cutter blade path and bend the metal piece to realign the switch so that the plastic carriage makes contact when reaching the right side.
Nov 30, 2007 | Sony UP DR100 Thermal Photo Printer
Sony UPDR150 Thermal Photo Printer Logo
297 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
