Question about Apex Digital DRX-9200 DVD Recorder
Transformer The PC mount power transformer has burned out the number is AM871B-T1 trying to find another.
  • GARY D. BARNARD
    GARY D. BARNARD May 16, 2007
    The Apex was made to burn out and you can't get parts for them unless you go to ebay and find one for parts only the transformer is made just for the company who builds the units. I had to fix meny of those, but you can make them last longer by installing a second cooling fan pointed at the power board and when not in use unplug it from the wall.
  • Anonymous Jan 04, 2008
    The power supply has burn marks on the pcb. The unit shows no lights when plugged in. Several capacitors show signs of melting.
Can you tell me how to connect regular computer power supply with this unit?
Posted on May 30, 2007
The Power supply was made to fail on this model. I would recommend using a Regular Computer Power Supply. It would cost $20 to $30 dollars for a brand new supply if you don't already have one to use.
Posted on Mar 27, 2007
Can the two transformers be hooked in parallel to service a 500 W zone?
If you are talking about low voltage light transformers, then answer is probably NO... but you could try it and see if it works... but I am almost certain that both transformers will probably burn out.
Output is 12 Volt AC... the transformer coils will probably burn out because the waveform from each transformer cannot be guaranteed to be the same.... even if both transformers are seemingly identical and plugged into same outlet.
For additional information, read transformer installation tips on following page.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#install
Power company transformers can be wired together in specific ways to produce 3-phase waveform, but these transformers are specifically engineered for the task. And the transformers do not combine the output (as you would be doing with yard transformer), instead each power company transformer produces 1 leg of power in a 3-leg power supply.
http://waterheatertimer.org/What-is-3-phase-electric.html#transformer
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 14, 2015 | Hardware & Accessories
How do i rewire a broomwade 3 phase compressor 1970
Rewire for ?? High voltage motor wiring is L1-T1, L2-T2, L3-T3, T4-T7, T5-T8, T6-T9. Low voltage is L1-T1-T4, L2-T2-T5, L3-T3-T6. The motor protection overloads will need to be sized accordingly, to the motor's FLA ( full load amps) for the voltage used. The control needs to be looked at also, if there is a control transformer, the transformer needs to be wired or repaced for the new supply power voltage used.
Mar 12, 2015 | Air Tools & Compressors
Hello! I have a Malibu transformer for my outdoor lighting. Last night, we had a severe rain storm. During the storm, my outdoor lighting went out. When I went to check the transformer box this...
My malibu transformer has a reset button on the back near the terminal connections. If the transformer is on (time displays on the panel) but the light fixtures are not lit, look for the reset button on the back and depress it.
Oct 07, 2010 | Malibu Hardware & Accessories
New t1 transformer needed
you shuold have used a power converter a transformer may not work as you also have a different working hertz as in 60 cycles.
Mar 15, 2009 | ElectroVoice...
Blown transformer
I also have the GPX under-counter TV, same problem. I believe the transformer is AC-AC, because both wires out are red... I actually have two of these units, one doesn't work at all, the other has enough power to play the radio, but not the TV. I swapped the transformer from 1 into the one that was completely dead thinking #1 had a bad tuner, but the same symptoms exist now in #2, making me think that one transformer is completely gone and the other is malfunctioning. I'll try the VX 79NP on both and try to remember to post the results back here....
Jan 16, 2009 | Curtis KCR2610 7 in. Portable Television
36" RCA- loud whine/squeal when it is plugged in, otherwise no power.
The HOT Hortz output transistor has gone home, 99% of the time from a faulty IVHT (Flyback Transformer), very common on the ctc187cl* chassis. The factory Flyback is no longer available, I have had problems finding an aftermarket one to replace it with.
The HOT is a BUH517, but you can also use a 2SD5129. It is the transistor mounted on the siler heat sink with a metal clip rather than a screw, just in front of the flyback.....
If you replace just the HOT, most of the time you will get a rapid arc (27,000volts - BE CAREFUL!!!) from the lower (yoke) post on the flyback. If the flyback is shorted, It may also just burn out the HOT and go right back to "squealing"....
Good luck finding the flyback!!!
Oct 06, 2008 | RCA F32450 32" TV
ViewSonic VX910 19" LCD...
I had the same exact problem. I pulled the power supply/inverter board out and found what alot of people have seen. The T1 transformer has blown. Replacement board link here.
Apr 22, 2008 | ViewSonic VX910 19" LCD Monitor
ViewSonic VX910 - what parts i'm looking for?
PSU- Board, Rev.C
Item: B-PS-0204-0076
Compatible with: VX710 VX910 VX912 VX924
BER-2 Number: D9 SCRAP NOT AUTHORIZED
(This item has been discontinued and not available to order.)
Please order B-00002481 instead. Your Price: US$45.00 Each
Apr 03, 2008 | ViewSonic VX910 19" LCD Monitor
Viewsonic vx924 LCD burnt transformer - T1
I did find a source for ccfl inverter transformers.The site is www.bourns.com
Oct 21, 2007 | ViewSonic VX924 19" LCD Monitor
Apex Digital DRX-9200 DVD Recorder Logo
245 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
