How do i hook my dvd player to my jvc 32 inch flat screen tv
When i hook my dvd player up to my jvc 32 inch flat screen all i see is snow and no sound what am i doing wrong
  • Angela Crews Feb 20, 2012
    The dvd plays but it seems as though its not connectin to the tv
    Problem Solver:
  • 9 Answers
U might be putting them in the wrong places or the wrong channel try and go through the channels but make sure they are hooked up right cause it will mess the TV up I did it on time and had to go get me another one cause I messed the sound up Hope this helps ya
Posted on Feb 20, 2012
SOURCE: No Audio on 32 Inch LCD Flat Screen
We have the same issue with our Insignia HDTV. The solution (which is not a solution) on our set is to switch the input to any of the other choices then switch back to Component 1 which is where the cable box is input.
Posted on Sep 21, 2007
SOURCE: lamp going out on jvc flat screen tv 52 inch,how do you change
Versed, you have to open the back panel (cover) to access the lamp. replacing is easy as soon as you can see it. loosen the mounting bolt and pull to unplug the lamp from the SMPS Lamp power supply. Thats it.
Posted on Dec 29, 2007
  • 142 Answers
SOURCE: dvd player
SOME dvd players have a small hole in the front... just large enough for an opened up paper clip to fit into. If yours has this, unplug your machine and insert an unfolded paper clip into this hole and gently press the mechanical eject switch. If you don't have this feature, your only hope is to disassemble the bottom of your set and spin the eject motor by hand to remove your disk.
Posted on Mar 10, 2008
pra0099
  • 153 Answers
SOURCE: My LG 32 inch tv will not pik up signal from DVD
check using other player ..
to conform wether the tv line is clear...
Posted on Sep 28, 2009
  • 21 Answers
SOURCE: how do I hook up my dvd player and WII system to
Allot depends on your DVD player and WII. Since the TV is a color one unless the movie your watching on the DVD player is B/W it will play in color, same with the WII. If your DVD player supports HDMI then select one of the HDMI ports on the TV (there are 3) same for the WII depending on what outputs it supports select one of the corresponding inputs on your TV. The user manual shows several options for various components and should be of some assistance in your connections.
Posted on Dec 24, 2009
White space above and below picture
Thirteen Retailers Recall 32" Coby Flat Screen Televisions ...
www.cpsc.gov/.../Thirteen-Re...
U.S. Consumer Product Safety CommissionDec 12, 2013 - This recall involves black Coby 32-inch flat screen televisions with model number ... AmTRAN Video Recalls to Repair 42-Inch JVC Flat Panel ...Missing: space
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the ... Just match up the sticker, and also add a space and n8lk, then search on amazon. .... LCD & LED TV Repair - No Image & BlankBlack Screen Flashlight Test ...
Coby DVD-209 Ultra Compact DVD Player Troubleshooting ...
https://www.ifixit.com/.../Coby_DVD-209_Ultra_Compact_DVD_P...
iFixitNot Compatible With Coby DVD Player; Disc Types Compatible; Problem Message Displayed On Screen. "WRONG ... Follow the repair guide to replace the fuse inside the device. ... The same goes for the white and yellow plugs and ports.Missing: space
Top 139 Complaints and Reviews about Coby Electronics
www.consumeraffairs.com > Electronics > Televisions
Dec 21, 2015 | Coby TFDVD2284 22 LCD TV
Cannot get speech from my DVD player
you are trying to reverse the dvd and it will not work
Apr 08, 2015 | Panasonic VIERA TX-L32E5B 32" LED TV...
How do I hook up a DVD player to a proscan 32 inch flat screen tv?
to connect your TV to your DVD, you will be needing a RCA wire (Yellow, white and Red wire). The yellow stands for video (visual/display), while the read and white stands for audio (sound).
Look at the back of your DVD, look out for Video Out, connect the yellow wire there. Also look out for Audio Out L & R, connect the white and red wire there.
Then turn the back of your TV, you will find Video, and Audio IN, Connect the other part of the wires from the DVD to the DVD, that is, Video for video and audio for audio.
Once you have connected the wires, turn on your TV, and your DVD player, press source on your TV remote to AV, and you will see your DVD displaying on your TV.
That's to hook up your DVD to your TV. Follow instructions carefully and you won't have any problem.
Good luck.
Apr 17, 2010 | Proscan 32LA30Q Television
No signal from my dvd player
Can you tell me how to connect my dvd player to my 42 inch proscan hdtv ? There are no yellow,its blue and there are two rows of the same colors.
Feb 03, 2009 | Proscan 32LA25Q 32 in. LCD TV
Can't play dvd player on JVC tv; I don't have a JVC remote.
I hooked up a Pioneer DVD player to my TV and when I play a DVD the volume cannot be controlled by the TV. It just plays at one level and on the louder side. When I'm watching regular TV and the DVD player is on and playing a disc I start to hear the DVD soundtrack at the same time as the whatever I'm watching on TV. I should not be able to hear anything until I switch over to Video 1. Any suggestions?
Dec 31, 2008 | JVC AV-32F476 32 in. Television
No signal
can you double check the signal cable that its going to the right place?
I beleave its hooked up wrong.
Jun 09, 2008 | Insignia IS-LCDTV32 32 in. Television
JVC DVD player problem
You have set the DVD to progressive output for your big tv. The little one will not accept this. Your manual will tell you how to reset it. The remote may be needed. Reconnect it to the big tv and check the menus.
Sep 01, 2007 | JVC XV-N422S DVD Player
Televison & Video Logo
112 people viewed this question
Top Televison & Video Experts
Electro Med Services...
