Question about Refrigerators
I HAVE A 1/3hp 5KCP36JN124HX 1ph 230v 50/60hz MOTOR IT KEEPS BLOWING ITS CAPACITOR OLD CAP WAS 25uf 240v IS THIS MOTOR RUN CAP ONLY AND WHAT IS ITS REQUIRED CAP RATING AS A RUN .
3 Suggested Answers
  • 159 Answers
SOURCE: maintenance
there are nothing to service on this type of fride but is almost the best type
Posted on May 16, 2009
john224
  • 1378 Answers
SOURCE: I HAVE A 3 HP
Contact me thru www.arrowpools.net with the model and serial number off the motor and I'll see if AOSmith still has a record of the caps used when the motor was made.
John
Posted on Jul 09, 2011
Band saw manual
They don't have website. Where do they manufacture their band saws?
May 19, 2013 | Powermatic 1791259/Model 2415 3HP 1Ph 230V...
The table saw shutdown where is the restart button
Usually the reset for table saw is on the motor itself
Crawl under the table and check it out & check your motor name plate (use a digital camera to photograph the name plate so you can see it large on your computer and have a record of that information)
Look for oil caps at the bearing ends of motor, to see if your motor can be oiled using 3-in-1 oil
If your saw is shutting down, you may not have enough electricity for the motor
Look at motor name plate for volts amps or watts.
Now figure how much electricity your saw need using the formula Volts x Amps = Watts
Next, look at the circuit breaker and size wire
15Amp breaker = 1440+watts
You can figure the breaker load using V X A = W
Next look at your wire going to table saw
14 gauge wire for 15 amp breaker
12 gauge wire for 20 amp breaker
10 gauge wire for 30 amp breaker
You might benefit by running bigger wire to the saw. And adding some oil in the oil caps.
I oiled my table saw and then ran a dedicated 30Amp wire to it, and it runs real good for a 25-year-old craftsman.
Oct 20, 2010 | Jet 708663PK/JTAS - 10XL50 - 1PK 3HP 1Ph...
I have a180 880--- planer and realised there are
A lot of equipment is built with sealed bearings these days--just a fact of life. Good luck!
Mar 23, 2010 | Powermatic 1791259/Model 2415 3HP 1Ph 230V...
Can't turn planer on
I think that you burned out the start capacitor(s) on your motor.
This is a common problem if the motor is overloaded.
It is also possible that the thermal overload is defective.
Apr 09, 2009 | Powermatic 1791259/Model 2415 3HP 1Ph 230V...
Table saw capacitor heats up and explodes.
The wrong capacitor for one thing. There are starting caps and running caps. The starting cap is in the circuit for only long enough for the motor to get up to speed. If you have a Leeson motor that has a start and run cap then the run cap may not be the correct on. If you have a start cap blowing out I suggest you check the centriifugal switch in the end of the motor. It may have welded the contacts shut. In any case, I would take it to a motor shop .
Mar 11, 2009 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
