Question about Saws
Need motor for sears table saw 11329930 . Motor is # 62317 but Sears no longer has avilable
Where can a replacement motor be found?
Thermal overload protector
Use the first part of the model number to fid who the manufacture of the saw/ motor is. Example: 110.123456- 110 is Whilpool. Then cal the manufacture direct. Also sometimes Grainger has direct replacements.
Jan 25, 2014 | Craftsman Sears 10" Table Saw Motor 62505
Where can I buy a replacement motor for my craftsman 10"table saw. model number 137.2711400 2.5H.P. moter modelRM871 5000Rpm. From Chatham,On.
Sounds like WAY!!!! overloaded use of the saw. Feed your material MUCH SLOWER and you will NEVER burn out a motor.
You can get replacement from Sears parts.
Feb 18, 2011 | Craftsman 10" Table Saw
Want to replace under powered saw motor on sears 10"table saw
u can put a 2 and above if u want just need to have the correct rpms
Jan 26, 2010 | Craftsman 10" Table Saw
Wiring diagram for a Sears Craftsman 110/220V motor
I found a local small motor technician who was able to help with the wiring configuration for the 110/220: I had wanted the motor to run on 110V
Dec 03, 2009 | Craftsman Saws
Manual for #103.0205 circ. saw
Earlier comment 103.0205 Table Saws does not need lubrication is simply wrong.
The103.0202, 103.0203, 103.0305 Craftsman Companion Table Saws main Arbor axle DOES have to lubricated or else the axle bearing will quickly loosen side-to-side or vertically and fail to provide accurate saw cuts.
FWIW, Sears no longer sells Arbor Axle replacement parts... The Table Saw Arbor axle and Bearing Housing cannot use sealed bearings unless the saw case is re-milled and extensively modified. There are 2 Oil Hole Plugs (part# 475-32) that need to be opened and oil applied so the Arbor axle shaft does not get scored or worn.
I use 30wt motor oil to relube the Arbor Axle Shaft depending on amount of use, temperature, and axle rotation stiffness.
Remember, the higher the RPM speed of the table saw motor and/or the longer the use, the more frequently you may need to relube the Arbor Axle Bearing!
Nov 19, 2009 | Sears Saws
I have recently replaced my 29 year old craftsman 10" table saw with a new switch. In trying to turn it on, the motor hummed, slightly oscilated and tripped out the wall breaker. I checked the Sears parts...
You may find a replacement motor on ebay. I deal in Craftsman Belt drive table saws, yours looks to be a direct drive. Sorry I wouldn't be much help with those, Jim
Oct 21, 2009 | Craftsman 10" Table Saw
Motor has started t0 smoke and trips circuit breaker
On the motors I deal with there is a series of numbers that identify the shaft size, hp and all other requirements. I would try and contact a local Grainger and see if they can help, if not try in the yellow pages for a motor repair shop in your area and sometimes they can get you one. Good luck
Jul 18, 2009 | Craftsman 10" Table Saw
New or used motor for a Craftsman 10" table saw
You can try Sears but they can be a bit pricey. I use to send out motors for a factory I worked in to a rebuilder who would even do new windings. Check in your area for a rebuilder, As for the replacement being a Sears unit they may have a similar motor in stock. Good luck.
Apr 16, 2009 | Craftsman 10" Table Saw
Saws Logo
137 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
