Question about Acer Veriton 5200D PC Desktop
Acer 5200-E5521A desktop with no video out
Checked Pwr Sup. tested ok. Checked HD tests OK. Installed PCI Video card still no video.
  • 166 Answers
Try restoring the BIOS defaults
Posted on Feb 20, 2012
2 Suggested Answers
stergiou88
  • 66 Answers
SOURCE: UNIT: ACER ASPIRE T180-I970 (AM2SEMPRON) ISSUE:
check your mobo. somewhere in the down right corner is a round silver battery. unplug it for 10 minutes and make sure that the power supply cable is unpluged. then plug them back. your bios should be reset to factory settings.
Posted on Oct 25, 2009
Acer aspire 5535 powers up but no screen display have had the screen tested that is ok , have hade the mother board tested and they said the fault is aparentley with the graphics card but if i slacken the...
If the motherboard has integrated video, it can be disabled and another addin video card can be installed into an available pci-e, agp, or pci slot if your computer has one. This is not something you can do with a laptop, only a desktop computer. For example, when i put a video card in one of my extra slots it automatically disables the integrated video.
If your video card is ALREADY in one of the ADD_IN slots, it can be removed and replaced.
Regards
Aug 22, 2010 | Acer Computers & Internet
S video output Does not work on my Gateway GM5472 computer
Here are some things to try...
You may need to install some software and/or drivers for this hardware to work. Look on the manufacturers web site.
I see that the card goes into your PCI-Express slot. Is it intended to power both your monitor and a TV? If so, and the software/drivers are already installed, you may need to open a configuration/settings window or a control panel in order to redirect the video signal to the NTSC port.
It may be that you need to enable the card in your computers BIOS settings.
Apr 06, 2010 | Gateway GM5472 PC Desktop
E-machine t6212 won't boot. I actually have two e-machines that are not sending a signal to the monitor. One is a t6212. It is booting up because I can shut it down using the windows key + up arrow +...
If you get only one BEEP at boot then the computer is working..
Do you have a 2nd monitor to test with?
if it BEEPS more then once...
pull out your mem chips and test,,
If itt works them one of the mem chips are bad if not..
pull out all pci cards and test.. if it works its a bad card...
if not unplug all HD and CD roms and test.......
If not fixed yet it maybe a onboard video problem...
But IF you put a video card in b4 the problem started then your bios may have auto set it sellf to PCI/AGP mode.
Check bios setings,, look for onbord setings for the video
Feb 21, 2010 | E-Machines T6212 PC Desktop
Acer AM5641-U5520A will not
If you removed the memory modules and there is no change then I would start disconnecting one device at a time to see if that is causing the problem. Start by disconnecting the cd/dvd rom and then try booting the computer. Then try disconnecting any floppy drives or pci cards(except for video card). If it has a pci/agp video card then you will need to remove it and test it in another computer or test a working one in the problem computer. If it has built-in video then you will need to test a working video card in the problem computer. It could also be an issue with the power supply so remove it and test it in another computer or swap it out with a known working power supply. Also check the mother board screws that hold the board to the chassi are tight(the board uses them as a ground). Blow any dust out of the case and verify that there are no loose connectors. Also verify that the monitor is not the problem by testing it with another computer. Usually when a CPU is defective the computer will not respond to anything and will act "dead" so it does not sound like the CPU. If everything else checks out then it could be a bad motherboard.
Dec 28, 2009 | Acer AM5641-B5560A Desktop PC & Monitor...
Setup did not find any hard disk drives installed in your system for acer power f5
Can be HD cable, pwr to HD or HD it self. i have purchased new HD before and it was defective. Make sure all wires are tight and are going from to right spot. if this is ok check the HD cable.
Dec 12, 2009 | Racer AcerPower F5 PC Desktop
No signal appears everytime I turn my PC ON. Blank screen appears. I checked my RAM module and its OK. Seems like theres a problem on the VGA port.
There is one of 2 problems here. first check the video card, since you mentioned port this sounds like its an on board video, so get a generic pci video card...nothing fancy just checking for video, if your out of pci slots either 1 remove one to test video or if your motherboard supports agp then get an agp video card. there like 20 bucks just go to a local repair shop. if that doesnt solve the problem then its the monitor.
Nov 15, 2009 | Acer Aspire M1641-U1521A PC Desktop
I took pc into office depot to get it checked as monitor has no signal display, even after buying new monitor. They got the same thing, said need a video card, after purchasing it I put it in and still has...
there is a possibilty that the pci slot isnt working on your motherboard. try a different pci slot with the new video card.If all are occupied then swap one to test. if your using agp, well you only have one agp slot so go to pci. just use generic first dont get anything expensive when your testing.
Nov 15, 2009 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
EMACHINE T6534 COMP. WANT BOOT . TRYING TO CHANGE V-CARDS
This could be a few things though if you have already checked the memory and HD. The next thing I would tell you is that you should check the cpu. Also make sure that everything in the BIOS is set to the default settings when you start it.
Feb 04, 2009 | eMachines T6534 PC Desktop
Hi sir i have an acer aspire 5101 which bips when i swtich it on and nothing shows on the screen.i have checked the ram an hard dive and they both ok
1st step you can check how many bips you hear, if continous bips , checks your vga by change with other if you sure that your ram and hd is ok, 2st if problem isn't solved ,remove all your card and clean all contact part all card with liquid cleaner, pci slot vga slot ram slot and processor socket after that you can try to assemble your card again , ok good try
Sep 26, 2008 | Acer Computers & Internet
Acer Veriton 5200D PC Desktop Logo
105 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
