Question about Waterwise 9000 Water Distiller
Fan cycles on and off continually on my waterwise 9000
After boiling point is reached, the fan cycles on and off every 10 seconds or so. It distills the water just fine, but why does the fan not continue to run?
2 Suggested Answers
SOURCE: My Waterwise 9000 shuts off only halfway through a
Jeff, call Waterwise at 1-800-874-9028 and speak to a technician, Mon-Fri 9-5. They should be able to help you
Posted on Jan 21, 2011
Why does the Water valve keep running water when bowl is full?
Because the shut off point is above the overflow tube. You will need to either adjust the arm or bend the float end of the arm downward to make the arm end swing higher to reach the shut off point prior to water overflowing into the tube.
Apr 27, 2014 | Korky Waterwise Toilet Fill Valve 528Z
Inner 6-inch element on the 12 inch/6 inch Dual Radiant Element cycles off too long
Sounds like the file is corrupted. That doesn't mean the footage is irretrievable. I believe the file type is .mov on that camera? You need to find a .mov repair program, there are lots out there. I don't want to give you a link since I haven't used any of the .mov ones and don't want to accidentally give you malware, so I'll leave that part up to you. But you should be able to get your file repaired, just google ".mov repair."
Nov 15, 2013 | Whirlpool Kitchen Ranges
Waterwise 8800 Water Distiller Troubleshooting
Our distiller has been leaking water out the bottom. We have ordered a new lid for the kettle, got it today and started the pot up. Well, it is still leaking. Do you have any suggestions?
Sep 05, 2012 | Waterwise 9000 Water Distiller
I have an Everstar portable air conditioner Model MPA-08CR but when it is working for 10 minutes...it is working fine cooling the desired space but the next 10 minutes it is only working like a fan...then...
The problem may be that you don't have the temperature set low enough and the unit reaches the set temperature quickly and then only the fan runs. Try lowering the set temperature.
Thanks for choosing FixYa.
Aug 05, 2011 | Heating & Cooling
My waterwise distiller light turns on for a few minutes and then just shuts off.
possible deffect on mother board try to replace then conduct observation of unit.
Feb 24, 2011 | Waterwise 9000 Water Distiller
I have WaterWise 8800 since 2004, and now when I start it up - it keeps shutting itself off. Tried to clean out dust through the slots at top of machine where fan is. Still not work. What's wrong?...
Have you used Kleenwise to remove scale from the boiler? YOu can call Waterwise and they have technicians that can help you. I have had my Waterwise 7000 for many years, and love it! It makes the BEST tasting water, no chemicals or biologicals in it. I keep my machine clean and when I have questions, I call the tech guys for help.
Dec 23, 2010 | Microwave Ovens
I have a 2004 jeep grand cherokee. when the car runs for a short time 5-10 min. the coolant fan turns on and does not shut down until the car is shut off. plenty of antifreeze. what is keeping the fan from...
Sounds like you may either have a thermostat that is not fully opening or a radiator that is partially obstructed (externally or internally). If I'm correct, what may be happening is that when the engine reaches operating temperature, it is continuing to get hotter but at the point you are at, the fans are able to compensate by remaining on.
Only other possibility is that the temp sender is bad and sending incorrect info to the computer, causing it to turn the fan on.
The concentration of antifreeze in a system does not change the operating temp. What it does is prevent the coolant from boiling at a temperature above what plain water would. Your radiator cap also helps with that as a liquid under pressure will boil at a higher temp. Proper concentration is 50/50. Normal operating temp is about 210 degrees(f). (+ ) (- ) 5 degrees)
So, I'd test the coolant sensor and replace the thermostat. Hopefully the radiator won't need to come out but you may need to have it checked if neither other options work.
Aug 04, 2010 | Jeep Grand Cherokee Cars & Trucks
Simac Stirelli 9000 steam iron spews rusty steam and smells like burnt apples
Your steam iron has been filled with 'tap' water that may have been contaminated (thus the smell). Rust develops more rapidely in Steam Iron chambers when distilled water is not used: to clean the 'enclosure' of the steam iron from rust and smell, over a sink or outdoor, fill 'cold iron' with a 50/50 water/vinegar and a teaspoon of bicarb, let it stand for about 10 mins, then turn the iron on and let it steam the mixture out while shaking the iron gently (DO NOT BURN YOURSELF! STEAM IS HOTER THAN BOILED WATER!). Refill and Steam flush again with Clean water (distilled preferred). Repeat the steps until the rust has been completely dissolved (check by steam ironing on clean pieces of disposible kitchen paper towel. Use the Power steam or Flush function of the Iron if available. Hope it helps!
Dec 17, 2009 | Irons
Waterwise 9000 Water Distiller Logo
Top Waterwise Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Waterwise Kitchen Appliances - Other Expert? Answer questions, earn points and help others
