Question about Home Security
Garage door opener manual 139.655300 - Home Security
geemarie
  • 876 Answers
SOURCE: craftsman garage door opener instruction manual
Have you tried the manufacturers site at either craftsman or sears. You should be able to find it there. You will need your model #.
Posted on Aug 01, 2008
  • 548 Answers
SOURCE: garage door opener won't open garage door
did you use the manual release to unlatch the door from the opener? You may have a problem with the door binding and opening it manually will confirm that. You may also have misaligned the sensors at the base of the door so check that too.
Posted on Feb 06, 2009
  • 43 Answers
SOURCE: Need to change keypad code, but lost instruction manual
The key code transmitter for your unit should be 53776 multi key panel:
you must have access to the operator to reset. The programming keys are as noted below:
1. Open the Touch C.ode Transmitter cover to access the keypad.
Decide on a 4-digit code number using numbers from
0 to 9. You can use a number more than once. (For
example, 4, 0, 4, 1).
2o Press the 'SR' code button on the opener panel. The
indicator light atongside the push button will turn ON.
3_ STAND AWAY FROM THE DOOR. Press the selected code
numbers on the keypad and then press the ENTER key.
The indicator light on the opener panel wiil turn OFF and
the door witl begin to move, The opener receiver has been ._
programmed with your code selection. (_
NOTE 1" If the indicator light turns OFF before the code _ . "_ _'
digits and ENTER key are pressed, repeat Steps 2 and 3. _._t,_-_ J t_
NOTE 2' During programming, be sure the,k/_ca_i_n push :---'-"_"
button (if your opener has that feature) is OFF and the
Infrared Sensor (if you have installed that accessory) is
free of obstruction. THE DOOR WILL NOT MOVE AND THE
INDICATOR LIGHT WILL NOT TURN OFF in either case.
To change your code at any time, repeat Steps 1, 2 and 3.
Hope this helps
Posted on Apr 12, 2009
  • 3197 Answers
SOURCE: owners manual for Craftsman garage door opener
This is available from Sears. The part number is 114A1930 and it sells for $4.99.
Posted on Oct 05, 2009
  • 3197 Answers
SOURCE: garage door opener won't close. travels 6-8 in.,
If you cannot get the light on the sensor to come on by tweaking it,making sure it is pointed at the other sensor and your wiring is not broken or shorted then your sensors need to be replaced.
Posted on Jan 08, 2010
Cannot open my garage door manually after I disengage it from the garage door opener (chain drive)
They are not light weight but there is no reason if the motor can raise it, then you cannot raise it by hand.
Feb 05, 2016 | liftmaster chamberlain 1/2 hp chain drive...
Don't know Mod. No. lost installation manual, approx. 5 yrs. old Need installation manual.
About 496,000 results (0.43 seconds) Search Results
    [PDF]GARAGE DOOR OPENER Model 3265 1/2 HP ... - LiftMaster
    www.liftmaster.com/.../en.../tucmanuals/114a3044.pdf Chamberlain GroupFasten the manual near the garage door after installation. .... This garage door openerhas been designed and tested to offer safe service provided it is installed, ...
    Manuals Download Craftsman Garage Door Opener Model ...
    www.craftsman.com/search=manuals%20download%20crafts...
    CraftsmanCraftsman has the best selection of Garage Door Openers in stock. Get the Garage Door Openers you want from the brands you love today at Craftsman.
    Craftsman 1/2 HP Chain Drive Garage Door Opener - Sears
    www.craftsman.com > ... > Garage Door Openers
    Craftsman1/2 hp Chain Drive Garage Door Opener Opens by Remote, Inside and from Car Enjoy a great end to every day by ... Owners manual - English (Warranty).
    Free Craftsman Garage Door Opener User Manuals ...
Feb 03, 2016 | Building Materials
How do I update software
Feb 03, 2016 | Kenwood DNX-690HD eXcelon DVD Receiver...
How to open the door if no electricity
Almost all garage door openers have a switch mechanism that will allow you to open the door manually. It is usually a pull cord on the motor or track. Pulling it down usually deactivates automatic mode. Just pull it up into position when the electricity comes back on.
Garage Door Repair in Jacksonville FL American Garage Doors LLC
Mar 17, 2015 | Building Materials
How do I program the garage door opener receiver on the garage after programming the garage door openner on the vehicle?
after you do the programing for the car you have to go back to the opener and press your learn button once. Then go back to your car and press and HOLD the button you just programmed your should see your light bulb blink on your opener after about a second or two.
Jan 27, 2015 | Building Materials
Craftsman 3/4 hp garage door opener
not sure, but see the users manual here:
http://www.manualslib.com/manual/32293/Craftsman-139-5399.html
Aug 14, 2012 | Craftsman 3/4 Hp Garage Door Opener System...
Garage door will not open manually or automatically/normally
The color of the sensors is normal and have nothing to do with your problem. If you cannot raise the door manually and it is released from the opener then you have a door problem. If you mean the door won't open and you cannot get into the garage to release the opener then you are going to have to call a door technician for help. He will get in.
Feb 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Manual for Sears
You need first to get the correct model number of your opener. It is on the end of the opener closest to the garage door and starts with 139.
Then you can go to this site and download a free manual.
http://www.manualsonline.com/
Sep 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener won't open garage door
Feb 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener instruction manual
Aug 01, 2008 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
286 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
