Question about Polaroid FLM-3732 Television
Polaroid Bad Caps
Stiv0 I followed your tutorial about replacing the bad caps and it worked perfectly. However since my television has tuned back on the screen is multi colored flurescent and has no audio. Do you have any ideas what could have caused the color and audio to go? Thank You
    Problem Solver:
  • 7 Answers
Same thing that made the Power Supply go in the first place. something is shorted most likely
Also, make sure that you replace the protective cover or parts will short and cause this
Or, you have a bad processor board which is very common in these sets
Jonathan
Posted on Nov 04, 2008
My TV screen just went black, i have had some problems with it freezing in the pass but i thought it was temporary. so tonight i was watching football and it just went black! so i was wondering if i could...
This solution is for a Polaroid flm-373B 37 inch LCD TV. I noticed your TV is the flm-3734B. Hopefully this solution will work for you too.
I suspect you may have 2 capacitors in your control module that need to be replaced. When these caps start to go bad it will often show up as a problem with the sound. However, when they get really bad they can prevent the TV from turning on. Please see the link below, posted by stiv0. It gives detailed instructions on how to replace these caps and to tell if they're getting bad. If you follow these instructions you can take the back off the TV and check out the caps. If the tops of the caps are bulging they need to be replaced. Just be sure to replace them with the correct value (1000uf) and use caps that are rated at a higher voltage than the originals. I replace the 10v caps in my flm 373B with 25V caps just to be on the safe side. If you know how to solder this is an easy and inexpensive fix. If you don't know how to solder find a friend who does. These caps have positive and negative terminals. It's important you solder the new caps in with the correct polarity. Stiv0 gives instructions on this. Even if the caps aren't bulging this fix is so inexpensive, less than 10$, that you may want to try it anyway. I hope this helps you out.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Sep 27, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
I turn the TV and nothing. A black screen. The
I suspect you may have 2 capacitors in your control module that need to be replaced. When these caps start to go bad it will often show up as a problem with the sound. However, when they get really bad they can prevent the TV from turning on. Please see the link below, posted by stiv0. It gives detailed instructions on how to replace these caps and to tell if they're getting bad. If you follow these instructions you can take the back off the TV and check out the caps. If the tops of the caps are bulging they need to be replaced. Just be sure to replace them with the correct value (1000uf) and use caps that are rated at a higher voltage than the originals. I replace the 10v caps in my FLM 373B with 30V caps just to be on the safe side. If you know how to solder this is an easy and inexpensive fix. If you don't know how to solder find a friend who does. These caps have positive and negative terminals. It's important you solder the new caps in with the correct polarity. Stiv0 gives instructions on this. Even if the caps aren't bulging this fix is so inexpensive, less than 10$, that you may want to try it anyway. I hope this helps you out.
Feb 08, 2010 | Polaroid FLM-3732 Television
When I turn on the TV it has a loud squeal for about 10 minutes until it seems to warm up.
Feb 01, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
Polaroid tv wont come on
user stiv0 has the solution-go to tips and there is step by step on how to change capacitors-i fixed mine today and took me less than an hour and supplies costed approx. $10.00. I used 1000uf 35v caps since i could not find 10v or 16v. Works perfect-just like new and no loud noise. Just be careful when removing old caps-the wires are thin so try and make sure you get each piece out so you can put in the new ones. Good Luck
Apr 01, 2009 | Polaroid FLM-3732 Television
Polaroid hdtv flm 3732 37''
the noise is probably due to bad caps-stiv0 has tips on how to change capacitors. I had the same noise and tv would come on after plugging and unplugging but eventually stopped coming on. I just changed the caps and now it works perfect and took approx. an 1hour and supplies cost approx. $10.00. Good Luck
Mar 11, 2009 | Polaroid FLM-3732 Television
Televison & Video Logo
134 people viewed this question
Top Polaroid Televison & Video Experts
Dave Naylor
Dave Naylor
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
