Question about Samsung WF448AAP Front Load Washer
Samsung model wf448aap will not start when you turn on the power and set cycle.
The washer is over two years old.
  • 2468 Answers
SOURCE: My Samsung WF448AAP just stopped in mid cycle and
check the electronic control board for a defective(open) fuse or burned components as this board operates the motor and powers the led readouts,before replacing the board,unplug the whole unit,sometimes the board will reset itself
Posted on Oct 26, 2010
SOURCE: samsung WF448AAP maybe clogged with feathers.
dont put expensive pillows into a washing machine.
Posted on Mar 08, 2009
SOURCE: my samsung wf448aap washer leaves clothes smelling
How much detergent are you using? Try using less detergent and softener in your loads. Too much detergent can leave clothes smelling similar to a wet dog, like you described.
Posted on Sep 05, 2009
rickyrt441
  • 4399 Answers
SOURCE: i have a samsung front
Thanks for choosing FixYa and welcome. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging. This noise is heard in the spin cycle.
Posted on May 07, 2011
rickead1
  • 1998 Answers
SOURCE: How to manually unlock my
You would remove the front lower panel and then reach up along the side that the door lock assembly is located on and you will feel a pull cord that when you pull will pop open the door. Most likely after you do this you should unplug the machine for 7 minutes which causes the control to reset if at that time you once again experience the same situation where the door will not unlock you will most likely have to replace the door lock assembly in the unit. If you have any further questions message me back I await your reply Thanks Rick
Posted on Jul 17, 2011
Samsung Washer model WF448AAP/XAA fills up with water but will not start cycle
That could be the lid switch is open or not engaging.
Check the continuity of the lid switch
Mar 07, 2016 | Samsung Washing Machines
Drain pump continuously running on Samsung Model WF448AAP/XAA
do pull the plug out first
not funny dancing with the machine
have you checked the pressure pipe for any cuts
look near the pressure switch area first
Feb 05, 2014 | Samsung Washing Machines
Samsung WF448AAP chimed and read to check filter. I drained the water out and cleaned the fillter. It had 2 quarters and a bunch of junk. I cleaned it and restarted machine and the washer starts of...
I would believe that the water pump has given out. If it is going thru the spin cycle after you drain the tub of water it is almost certainly the pump.
Nov 12, 2010 | Samsung WF448AAP Front Load Washer
I have a Samsung WF448AAP/XAA washer. I have had it for a year + and have never cleaned the filter on the bottom of the machine. Tech support told me to clean the filter. Dumb, I know, I just didn't...
There is most likely something stuck in the rubber hose between the drum and the pump, Unfortunately this is not easy to get to as it requires tilting the machine back and climbing underneath to remove the hose and check it. Make sure you disconnect the power before doing this.
May 08, 2017 | Samsung WF448AAP Front Load Washer
Our samsung wf448AAPXAA washer will not drain or spin. Its only 2 years old!
The usual problem of this is the pump being broken or blocked. The way it works is that until the bowel is drained or pumped completely The next order to spin will not be received by the control board. Check to make sure the drain hose is at the right hight it could be to high which will cause this malfunction in some machines.
Mar 28, 2010 | Samsung WF448AAP Front Load Washer
Samsung washing machine gives Low Water pressure error message and interrupts cycle. Checked inlet filters. Sometimes gives leak/flood warning message. How can I turn off these messages?
You get these messages turned off by fixing the problem.
Low water pressure is basically one of the valves is not letting water pass through.
1. Do as you already did and clean the inlet filters. Any kinked hoses?
2. Adjust the water pressure in the house. Is it too high or too low?
3. Replace the valves in the unit.
4. Main board.
Dec 29, 2009 | Samsung WF448AAP Front Load Washer
Samsung WF448AAP maybe clogged with feathers.
Dec 12, 2008 | Samsung WF337AA Front Load Washer
Samsung WF448AAP Front Load Washer Logo
121 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
