Question about Hannspree 28" Widescreen Flat-Panel LCD HD Monitor
Hsg1075 picture settings - Hannspree 28" Widescreen Flat-Panel LCD HD Monitor
Hi!My problem is with lcd tv Hannspree HSG1075 ,this red ,green ,blue and white flashing screen.Now my question is how to turn off this mode ,i guess is in "test mode" or do i nedd firmware.Please hel
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 23, 2015 | Hannspree Televison & Video
We have a Hannspree HSG1075 LCD TV. Having problems get all channels wanted. Have autoscanned SEVERAL times but no results.
Check and replace its tuner. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 25, 2014 | Televison & Video
Settings for taking pictures
What kind of picture do you want to take? What do you want that picture to say to the viewer?
There are a lot of different settings because there are a lot of different types of pictures. You don't want the same settings for a landscape picture as for a portrait picture. You probably wouldn't want the same settings for a portrait of a young girl as for a portrait of her grandfather.
If you're not comfortable choosing the settings yourself, set the camera to the appropriate scene mode. For taking pictures of people use the Portrait mode, for taking pictures of where you are on vacation use the Landscape mode, and so on.
If you want to learn more, your local library probably has some introductory photography books that tell you how the various settings such as aperture and shutter speed affect your pictures.
Apr 01, 2013 | Canon PowerShot A520 Digital Camera
Hannspree 28 Inch Lcd Tv Model Number HSG1075
Check its Chroma section circuit for fault. Most possible cause is damaged chroma IC.
Aug 09, 2012 | Hannspree Televison & Video
I need a table stand for a Hannspree Model HSG1075 28" LCD HDTV
Did you need the table stand anymore? Where do you live. Im from germany and have wrecked a HannSpree HSG1075 today. The stand is o.k with minimal scratches of usage.
greetings of
Michael
Dec 23, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
How doi reset the picture after replacing the bulb and housing
It is not required to set the Picture after replacing the Lamp and Housing. To change the Picture Settings press the MENU button on the Remote, highlight PICTURE and press OK. There you'll get the option to select Picture Preset Mode, Picture Settings, Screen Format, Advanced Picture and Screen Adjust mode. You can customize the settings by selecting the each Picture Menu options.
Click here to download the manual of the TV. View page # 39 for the instructions to change the Picture Menu.
Good Luck!
Thanks for using FixYa
Dec 01, 2010 | RCA M50WH185 Television
My Sony Bravia has no colour, and the black and white is so dark you can't see the picture. It is less than 1 year old model # KDL-46S5100
If the picture has no color or appear as black and white only, please reset the picture setting. To reset picture setting please follow the items below:
  1. Press MENU button on your remote.
  2. Press arrowtb.png to select setting.jpgSettings, then press ok.png.
  3. Press arrowtb.png to select picturemenu.jpgPicture Menu, then press ok.png.
  4. Press arrowtb.png to select Reset, then press ok.png to reset all the Picture Settings except Picture Mode and Display Mode to the factory settings.
If this does not not work, then change the picture board in your TV.
Please rate my solution.
Good luck.
Jun 27, 2010 | Televison & Video
Where can I find the latest Driver for My Hannspree HSG1075 28 inch LCD Monitor? The Box says Model ST281MKB Thanks! ~Jim~
go to the device makers website and download the latest driver for it. or http://www.hannspree.com/global/product_detail.aspx?id=25887&advancedkey=Size%3d28%22+Wide%2cCategories%3dLCD+Monitors&PID= copy paste
then click on downloads. scroll to bottom and click on driver
Mar 20, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Camera still possessed
There is something wrong with the settings of the camera.
When it is on setting or view mode is fine. It is not supposed to take pictures.
Go thru the Menu and pick the way you want your pictures, size and all those details, switch them take pictures and keep switching the settings until you get it right.
My camera was taking 3 pictures at the time, and it was because of the setting was set to do that. Don't be afraid of changing the setting for pictures, you can always change and try different things, digital pictures can be erased right away. So you can try as much as you want.
Try all options in the setting for taking a picture, change a setting, try to take a picture and see what happens. Then try on another setting and so on.
Artgirl
Jul 08, 2008 | Nikon Coolpix 2100 Digital Camera
Picture adjustment questions
*The brightness control setting determines how bright your picture will be. *The contrast control sets the gain of the video circuit. This determines the difference between dark and light scenes. Low contrast settings make the picture "hazy". High contrast settings make the picture more distinction between dark and light scenes. *The sharpness control determine the frequency response of the video circiut. High sharpness settings give better resolution but also shows more noise in your picture. Lower sharpness settings smoothe out the picture removing noise but also fine detail. It needs to be set for the best all around picture. *Picture Enhancement is pre-set adjustments which give you different picture qualities. You just select the one you like. Stargazer
Mar 03, 2007 | Zenith B25A02Z TV
Hannspree 28" Widescreen Flat-Panel LCD HD Monitor Logo
85 people viewed this question
Top Hannspree Computers & Internet Experts
tomar33
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
