Question about Canon Selphy CP510 Thermal Photo Printer
Selphy cp510 ink roll won't eject
Eject ink cartridge
  • Lisa M Feb 20, 2012
    I need to replace the ink cartridge but the release button won't let go. I used to hit it and the roll would pop out automatically. I've tried forcing the old cartridge out with a screwdriver but it isn't budging. Ideas?
My ink cartridge is stuck. I tried to turn it off and on again and to push the paper leveler down but nothing helps.
My Canon Selphy CP740 start to jam ink ribbon and ink - Fixya
www.fixya.com/support/t10013530-canon_selphy_cp740_start
Jan 4, 2013 - My Canon Selphy CP740 start to jam ink ribbon and ink cartridge is blocked and cann't be removed from printers. ... Question about Canon SELPHYCP740 InkJet Photo Printer .... SOURCE: CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7.
Selphy CP740 - Catridge Eject Solution - YouTube
? 0:46
https://www.youtube.com/watch?v=9TqHINBmbgQ
Sep 11, 2013 - Uploaded by Mahadhir Shaarani
Selphy CP740 - Catridge Eject Solution. Mahadhir Shaarani ...Replacing Ink for Canon Selphy - Duration: 6:23. Jenuine Crafts... How to Print Different Sizes with the Canon Selphy Printer - Duration: 12:08. Janet Wakeland ...
Color ink cassette stuck in canon selphy 'Canon SELPHY ...
Feb 03, 2016 | Canon Selphy Cp800 Compact Photo Printer -...
Can't remove ink cartridge selphy cp750 ink cartridge
I tried winding the gears and as soon as the gear reaches the correct alignment, you can eject the cartridge
Apr 22, 2013 | Canon SELPHY CP750 Printer
Printer says remove and check right cartridge
Turn the printer on.
Face the side of the printer that has the controls, or is the side where the printed-page ejects.
Lift the lid that covers the print-head mechanism.
Wait for the print-head to slide to a position where you can see the ink-cartridges.
Remove the RIGHT ink-cartridge.
Replace it.
Jun 12, 2011 | HP PSC 1610 All-In-One InkJet Printer
I will change ink cartridge but the problem is. I do not know to eject. My printer is HP Deskjet Ink Advantage 2060 all-in one k110. Please help me. Thank you.
Replace the cartridges
To replace the cartridges
1. Check power. Make sure printer is on
2. Load paper.
3. Remove cartridge.
a. Open cartridge door. Wait for print carriage to move to center.
b. Press down to release cartridge, then remove it from slot.
May 30, 2011 | HP Office Equipment & Supplies
How do I change ink cartridges onEpson Stylus SX425W printer. Apart from lifting the scanner I cant see any buttons to press and the present cartridges wont move along to enable me to eject the black one.
In a few seconds, the print-heads will slide to a position where the ink-cartridge can be removed.
Then, "unlock" the ink-cartridge from its socket, and gently remove it.
Replace it.
Then, "lock" the ink-cartridge into place, and close the lid.
Print a test-page.
Apr 11, 2011 | Epson Office Equipment & Supplies
How do u change ink cart
The process of changing ink cartridges varies slightly by the make and model of your printer. Open the cover to the area where your cartridges are installed while your printer is turned on. If opening the cover automatically prompts the inks cartridges to move and center in a position where they are accessible, then all you have to do is remove and reinstall new ones. If the cartridges do not automatically move and center themselves where they can be changed, then your printer requires an additional command that you do manually to make this happen. Some printers require the user to push the power button down and hold it for 10 seconds to have the machine move and center the cartridges in a position that can be reached easily by your fingers. Some even have an extra button to push that has a little picture of an ink drop next to it which brings the cartridges forward for replacement. If you cannot reach the cartridges easily, or opening the cover does not automatically move and center them then check your manual for the procedure or repost your question inlcuding the make and model number so that we can locate this information for you.
Lets move forward.
Once the cartridges are in an area that is easily reachable, the next step is to eject the cartridge which needs to be changed. This procedure can also vary by make and model. Look at your cartridges and check for a plastic ejection lever in front that can be pushed down by a finger tip. If you see one, push downward and see if the cartridges is ejected outward towards you. If it is ejected, then replace with new cartridge and push downward to lock it into place and your done. If there is no plastic ejection lever in front of the carriage which holds your cartridges, then place one finger on top of the cartridge you wish to remove and push downward slightly and pull it towards you until it unlocks and releases it. Then remove and replace and push down and forward to lock the new one by into place and your done.
I can give you specific instructions pertaining to your make and model printer if you supply this information on the website. Good luck!
Oct 26, 2010 | Office Equipment & Supplies
Cassette has paper in it; fresh ink cartridge; can hear the engine running, but I get a paper feed error Canon Selphy CP510
This is sort of scenario is usually caused by dust inside the printer. Dust has a way of preventing the sensors from detecting paper. Also it prevents the rollers from having a firm grip on the paper while picking paper. I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). If you have a blower you may also use it to blow well into the interior of the printer (If you do not have a blower the brushing will still do if you do it well.) This, if properly done should do it. Brush especially the rollers etc.
Dec 21, 2009 | Canon Selphy CP510 Thermal Photo Printer
Changed cartridge--now paper gets stops by cartridge carrier. turned on and off, reinstalled cartridge, cleaned roller.
Press the OK button.
- If paper is being fed at error occurrence, the
error is indicated after the paper is ejected.
- If the error occurs, the print head alignment
values are not changed.
- After exit from the error by the OK button,
the automatic print head alignment will not
be re-done.
The error will occur when the print head
alignment pattern is not printed due to no ink
or non-ejection of ink.
Oct 11, 2009 | Canon PIXMA iP1800 Photo Printer
Canon Selphy CP510 Thermal Photo Printer Logo
116 people viewed this question
old marine
old marine
