Question about Gateway Computers & Internet
I cannot connect to the internet because no wireless networks show up as being available. My wireless device is onmbut when I go to the place where it should show wireless available networks, no networks show up on the list. My model number is CX2619.
    Scholar:
  • 195 Answers
I had a power failure while I was sleeping one night and the computer shut down along with my wireless. I had to setup my wireless all over again. If you still have your installation manual, just install it again and it should work. its a hassle but sometimes you have to. Good Luck.
Posted on Oct 28, 2008
Cannot accress WiFi on Sylvania SYBET7WIC-BK-Z
The Sylvania Netbook is an inexpensive 7-inch device that is convenient for accessing the Internet on public or private Wi-Fi networks. It is not intended to replace a regular computer for daily tasks; its purpose is to provide a lightweight unit to access social media and perform small tasks. The netbook defaults to mobile websites, but it does a good job at what it is intended to do. Connecting to Wi-Fi networks with your Sylvania Netbook requires configuring the device properly.
Boot up the Sylvania Netbook by pushing the manual switch below the screen. Push the F9 key to turn on the Wi-Fi on the device. Select the little wireless icon in the toolbar at the bottom; it looks like a small computer. Choose the "Wireless Information" tab. This will show the online status of the device, as in whether it has connected to the Internet. If you have checked the box beside this option, this tab also notifies you when new networks are available. If the status shows that you have connected. You may need to add your wireless router manually in the setup. Do this by choosing, "Add New." Obtain the necessary setup information from your wireless Internet provider. If you have an encrypted network, you will need to fill in that information about your router. To configure the wireless setup further, click on the name of the wireless network. Click on "Advanced Settings" and adjust your connection choices; this tab determines the order of connection if there is more than one network available. Another important setting on this tab is the "Allow Windows to configure my wireless settings" option. Check that box. Click the "Internet Explorer" icon on the desktop. If you are online, you will pull up the Google homepage. Hope this helps.
Dec 27, 2012 | Sylvania Synet7wic-bk-z2 Netbook
How do I connect my Sylvania scrapbook to wifi
Step 1:
Boot up the Sylvania scrapbook by pushing the manual switch below the screen. Push the F9 key to turn on the Wi-Fi on the device.
Step 2:
ignore this step my bad
Step 3:
Select the little wireless icon in the toolbar at the bottom; it looks like a small computer. Choose the "Wireless Information" tab. This will show the online status of the device, as in whether it has connected to the Internet. If you have checked the box beside this option, this tab also notifies you when new networks are available. If the status shows that you have connected, skip to Step 6.
Step 4:
Step 5:
Step 6:
Dec 26, 2012 | Computers & Internet
I have an acer aspire one laptop that will not connect to internet thru wireless connection. System shows that wireless connection strength is excellent but internet explorer cannot display webpage. ...
1.- Try to find the wireless card switch (or button). Look the wireless led indicator, must be on.
You should surf if the led is on.
2.- If not works, go to device manager and look to your wireless device and turn the switch on and
off again. Look if the device is accepted without any sign. If the device get any sign then you
have problem with your wireless driver. If no sign. Open My Computer and then open networks
or my network places, and try to access to any other computer you have.
3.- If the device is ok in device manager and the led indicator is on and you can access other
computer thru network places, then open Internet explorer, go to tools, then go to internet
options, then go to connections and there click on Lan settings. In the proxy section uncheck
the box. Restart your Internet Explorer and it must surf now.
Good Luck and remember to rate my answer.
Feb 16, 2011 | Acer Aspire One PC Notebook
Dell axim x51 will connect to to wifi hotspot i need detailed instructions to get it to work
Hi, follow the steps found in your owners manual. That can be downloaded at this link.
http://support.dell.com/support/edocs/systems/aximx51/en/om/om_en.pdf
Using Wi-Fi (802.11b)
Wi-Fi provides your device access to WLAN (Wireless Local Area Network.)
Short for wireless fidelity, Wi-Fi refers to any type of 802.11 network,
whether 802.11b, 802.11a, or dual-band. Wi-Fi certified products from
different manufacturers are interoperable.
NOTE: Mid and High configurations of the Axim have Wi-Fi 802.11b built in and the
drivers factory installed. For a Low configuration device, you must purchase the
802.11b SD card, insert it in your device, and load the drivers.
NOTE: The default Wireless Networking Client utility for your device is the
Dell WLAN utility. The following configuration steps are for the Dell WLAN utility.
Configure wireless networking for your device in one of the following
scenarios:
• Network Card is set up
• Wireless Network is broadcasting SSID
• Wireless Network is not broadcasting SSID
If the Network Card is Set Up
Normally the internal wireless card is already set up. There are times when
you must choose the network card. On the Axim X51/X51v configurations
that have built-in wireless, the network card is associated with the enabled
wireless. If wireless is not enabled or you are using a socket card for
wireless connection, then choose the network card:
1 Tap Start → Settings → Connections.
2 Tap Network Cards.
3 Choose either Internet or Work from the menu.
4 Choose the network card to connect to the network. For the
Axim X51/X51v with built-in wireless, choose Dell Axim X51/X51v
WLAN Wireless Adapter.
5 Choose whether the network card assigns an IP address or receives an
IP address automatically.
6 Enter the Server IP addresses if required and tap OK.
If the Wireless Network is Broadcasting SSID
1 Press the wireless button to enable wireless capability. The green LED
in the right top corner of the device indicates that the wireless
is functional.
2 Tap Start → Settings → Connections.
3 To add, edit, or delete a profile, select the corresponding action and
tap Network Cards.
4 In the Configure Wireless Networks window, select one of the available
network names and tap OK.
If the Wireless Network is Not Broadcasting SSID
The Configure Wireless Networks window only shows wireless networks
that broadcast a Network Name (SSID) and those that have been added.
Add the network if it is not listed. Contact your network administrator for
the following information:
• SSID (network name)
• Authentication
• Data Encryption
• Keys (if the key is not provided automatically)
• Log in if necessary
To configure the wireless network:
1 From the Configure Wireless Networks window, tap Add New.
2 Provide the Network Name (SSID).
3 Select either Internet or Work in the Connects To box.
• Selecting Internet allows you to connect to your network but you
will have to manually start a VPN connection, if needed.
• Selecting Work automatically starts a VPN connection any time
you connect to the network.
• If you are having trouble connecting to your network, change the
Connects To box to Internet.
4 Tap the Network Key tab.
5 Enter the Authentication and Data Encryption information. If a key is
required, enter the network key.
6 Select the 802.1x tab.
7 The Authentication and Data Encryption chosen on the previous
screen determines whether this screen is available. If available choose
the EAP type used on the network.
8 Tap OK.
9 If more than one network is listed, tap and hold the stylus on the
network name you want to connect to. A pop-up menu appears.
Tap Connect. After a few seconds you should see Connected next to
the wireless network you selected.
Thank you,
lee
Mar 09, 2010 | Computers & Internet
Unable to wirelessly connect anymore
Click on the network icon in the task bar. Show the networks available and right click on the wireless network if it shows up. Try the 'repair' network selection.
You can also 'remove' the wireless device and re-install it. If you use the command: "ipconfig /all" it will display all the connections and their settings. Normally windows will use the auto config 192.168.xx.xx series of IP addresses if it cannot find a DHCP server to issue it an address. That should show up in the ipconfig output in the wireless network device section.
If the ipconfig does not show the wireless device, try the uninstall/re-install tactic.
If this is a PC-card [PCMCIA] that you can physically remove, power down, remove the device, power back up. Power down again, install the card, power up. Windows might then 're-find' the device and reinstall all the necessary drivers.
tom
Jan 18, 2010 | Dell Inspiron 2200 Notebook
My laptop finds wireless router but will not connect to internet
Hi there. You may need to connect to the wireless network manually. What is the operating system running on your computer? If XP, you may follow these. (This is also applicable in other operating system, it may just vary a little) Right click the monitor icon showing on the system tray near the clock. Point the mouse in the icon and it will display the name if it is wireless network connection or network connection. Right click the icon and look for view available wireless network. If it is not showing, look for network connection. Right click and select "open network connection". Right click wireless network connection and select "view available wireless network" . Look for the wireless network you're trying to access or have connection.Highlight and click connect. If encrypted, you need to supply the pass key or security key twice and hit connect. It should allow you now to go online wirelessly. Please remember these, you should be able to go online wired. Make sure that there are other wireless computer connected to the wireless network you're connecting with and can go online wirelessly.
Hope this help :)
May 16, 2009 | Dynamode (R-ADSL-C4-W) Wireless Router
I can't connect to internet via wireless router. My computer doesn't show my wireless network adapter in device manager, even though I have used this computer, router, and DSL modem for over 3 years. I...
Hello! I very much doubt that Memory will cause the problem you have. Are you using a secure network? if so you may have to pair it again with the p.c. try this! hover over the internet icon on the taskbar (2 computor monitors) it should show wireless networks available, if not right click on it then click set up network or search for available networks, if this fails uninstall the wireless router in the device manager and reload after re booting.
Hope this helps!
Paul 'W'
Onyer~EDson(:0)~[><
Dec 04, 2008 | Computers & Internet
My Laptops Internet switch has stopped working
Then install your USB device with your CD
Then do this
Click your Start Button
Select and click Control Panel
Select Network Connections
Select Wireless Network Connections
Right click
Select View Available Wireless Networks
5. Highlight the network you want to connect to
Click Advanced
6. Select the wireless network tab
7. Highlight the network in the available networks window
9. Click configure
9. IN the Properties Window
Double check the SSID (network name)
Enter the WEP KEY provided to you by the office
Click OK
Nov 17, 2008 | Compaq Presario 700 470024-192 Notebook
Connection
You have to set the wireless connection
Check if you have the wireless card ON or check if your wireless card is installed
My computer >> right click >>Properties>>Hardware>>Device Manager>>Network
If yes,
Right click
Click Advanced
9. Click configure
Click OK
Nov 09, 2008 | Linksys WRT54GL Wireless-G 54Mbps...
No internet access
disable the other adapters and try agan...
then use use the set up Home or small office networking wizard in the left to complete it
hope it worked !
Mar 10, 2008 | Computers & Internet
Computers & Internet Logo
51 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
