Question about GE Advantium SCA2000B Microwave Oven
Ge jvm130 001
Do you have any idea what the closest upgrade by ge to this older model that i need to replace?
Thanks.
How to remove the outter door frame on the GE Microwave
http://www.repairfaq.org/sam/micfaq.htm
for both queries this site would help somethin i think.. tpugh information is very huge please see if it is useful for u
Dec 25, 2007 | GE Advantium 120 Convection/Microwave Oven
Is there anyway that we could replace the internal fuse on model jvm1650sh05. we live over 50 miles from the closest repair.
Unplug mw, remove top grille, remove screw holding display panel, pull up on panel and tilt it down. You should have access to fuse.
Sep 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have an old GE Microwave jvm240av001 and would like to know the specs so I can replace it. It is so old (1995) I can not find anything on line. Please let me know if you can help. Thanks so much!
Hi and welcome to FixYa, I am Kelly
(trim kit required)
For all newer units the dimesnions are
15 & 3/4" high 16 & 1/2" high hole required for vent connection in rear
15" deep
Needs a 30 inch wide hole for installation
or call GE 1-800-626-2005
Use this link for all models OLD and NEW:
http://www.geappliances.com/service_and_support/literature
To get dimensions you look up installation manuals for each model.
Your manual cam up here: (1.51 Mb)
http://www.geappliances.com/search/older-pdfs/49-8621.PDF
Your microwave is not vented externally but your replacement microwave will be capable of being used in a non-external vent and an external vent cofiguration. Personally.... I would recommend the external vent installation. Either will work.
Thanks for choosing FixYa, Kelly
Sep 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
How to replace lights on GE spacemaker Model JVM230 bl ?
most older ge spacemakers have to take cover off cabinet even seen some were whole cabinet come off
Jan 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Upgrading from an old GE XL1400 Spacemaker Microwave
GE Customer Service should be able to tell you if they have a new "drop-in" replacement for your model.
On that page you can also find your model's installation instructions, which make removing the old oven pretty simple.
Jan 29, 2009 | Microwave Ovens
Microwave GE SpacemakerXL JVM 1450
If you need to ask how to do this task, you may have no idea of the extremely high voltages that exist under the cover, even when unplugged. I would advise a competent person changes it for you.
Aug 26, 2017 | Microwave Ovens
In 2004 we purchased a GE Convection Microwave oven (Model JEB1095WB002) along with a stove and cooktop. Well the GE Repairman was here today to replace the Magnatron for the FOURTH time (he said third...
I wonder if the service center is still using the older version magnetrons that were subject to a campaign (not a recall, mind you!) by GE?
This was a well-known issue with the GE/Samsung magnetrons.
Otherwise, unless the cooling fan is failing, your line voltage at the outlet is too high, or you are running the microwave empty or too dry, there's not a lot else that causes magnetron failure.
So for GE to replace the whole microwave is generally not viable or economical.
Your best bet is probably to contact customer service via this page.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 25, 2008 | Microwave Ovens
Broken Handle on GE Spacemaker XL
It looks like the current part number is WB15X335.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Advantium SCA2000B Microwave Oven Logo
133 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
