Question about KitchenAid KEYS850LQ Electric Dryer
Dryer will not start at any setting, with or without door closed
  • 1,344 Answers
You will have to remove the back panel to access this part. Be sure that you unplug the machine before starting. Once the back panel has been taken off and placed aside the thermal switch will be located on the left lower side near the blower housing . It will be thin and long and located near the cycling thermostat that has for prongs on it. On certain machines, the thermal fuse is located in the front. To access this you must remove the kickplate, which can be done by pushing the clips, one on each side jsut above the top of the kickplate, in between the top and abottom portion. The part numbers are the same for either style dryer. To test this part you can either take the wires off it and tie them together then plug the machine back in and see if it starts, or you can use a multimeter and check to see if there is continuity, if there is its good, if not, bad. The thermal fuse will usually be white, and if located in the back, be thin and long with two wires on it, left and right. If in the bottom front, it will be front center on the exhaust duct. Another possible problem is that the door switch isn't functioning properly. You can visually check this by open the door and pressing the switch and listen for a click sound upon pressing and releasing .
Posted on Jun 05, 2012
Have a GE electric dryer model DJXR433EC2WW. Whenever I select the dryer mode/time option, the dryer turns on by itself without turning the start switch (door closed). The dryer only stops when it...
I have seen that in those dryers before and it has always been the motor that is causing it to start without engaging the start switch.
GENE
Sep 16, 2011 | GE Dryers
Dryer will not start, yes the door is closed and set correctly
take the kill switch off the door jamb and jump the wires.
if it starts when you close the door and set the timer and start switch as normally done the switch is bad
Feb 23, 2010 | Dryers
Won't start
if the door is not tight as in you can move it slightly when its closed,the door strike and door catch need replacing and can be done without dryer disassembly at the front door,open the dryer door and in the lower right hand corner theres a small plunger switch push this in with your finger you will hear a click,then start dryer with door open being careful,this test will rule out switch problem,then just replace door parts
Jan 09, 2010 | Danby DCD5505W Electric Dryer
The dryer starts up automatically without having to press the start button. will not turn off at the end of cycle, buzzer does not stop, only at the end of one of the 4 cycles.
you have a door switch that is bad, the circut is close so the dryer thinks that the door is still closed. replace your door switch. let me know the model and i will help you through that.
Oct 13, 2009 | Kenmore Dryers
Dryer starts on it's own - won't shut off
TRY DISCONNECTING THE START BUTTON WIRES AND SEE WHAT IT DOSE WITH THE DOOR CLOSED,IF IT DOES NOT START IT YOUR START SWITCH-MIKE
Feb 16, 2009 | Whirlpool LER5636P Electric Dryer
Dryer beeps twice when you push start and doesn't start
I had the same problem. Don't know if it will help you but, I closed the door and banged the door hard with the palm of my hand twice. A couple pennies fell out and it started without a problem!
Dec 21, 2008 | GE Profile DPSB620GCWW Gas Dryer
Indesit IC70C Condensor dryer
We experienced a similar problem and corrected it by closing the drying door and then hitting "OPEN" followed by closing. Sometimes we use a tool to release the catch and then close the door. We have not seen this problem return.
Nov 26, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Dryer light stays on , won't start just keeps beebing....
Your door switch is broken (push button switch on the door frame). Without the switch engaging properly, the dryer light will continue to stay on and the dryer will not start. You will need to replace your door switch.
Oct 15, 2008 | KitchenAid KEHS02RMT Electric Dryer
Maytag Dryer
are you sure the door is completely close?
if the door is not closing the door switch, nothing will happen when you press the start button.
drcool
Sep 17, 2008 | Dryers
Signal
Kenmore 70 series. Model/Stock 66702692 Serial MG2402832
Cycle Signal works but then won't shut off until I open up the dryer door - it just keeps buzzing for hours. Also the dryer will turn on if I close the door ( and arrow is within a number and not on off) without pressing the start button. So if door is closed - the dryer will run or buzz (depending on arrow). How do I fix this?
Thank you
Jan 04, 2008 | Kenmore 64892 Electric Dryer
KitchenAid KEYS850LQ  Electric Dryer Logo
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
