Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Keypad only works when closing door
My keypad now will only work when closing my garage door. I replaced the battery and made sure the door lock was not on. When I try to open the door from the keypad it flashes for about 10-15 seconds but does not open the door. Any solutions?
  • 504 Answers
MANY OF THE NEWER UNITS WILL CLOSE FROM THE KEYPAD WITHOUT PRESSING THE CODE - OR USING THE WRONG CODE.
WHEN YOU REPLACE THE BATTERY YOU MUST REPROGRAM THE KEYLESS TO THE OPENER.
HOPE THIS HELPS
Posted on Jun 10, 2010
When I leave the garage, I can use the keypad to close the door.......but when I return and try to open the door with the keypad....it won't open.
Make sure the battery is good. A weak battery can cause this problem. If that is not the case and your other remote units work your keypad may be going bad and need to be replaced.
Dec 24, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 HP Model 139.53914 The wireless outdoor keypad will not open the garage door but it will close it. The two garage door openers work just fine and the indoor keypad works fine. Replaced the...
Sounds like it has lost signal strength and the door cuts it down to the point that the receiver never gets the signal when the door is in the way. If it did that before you replaced the battery then you will have to replace the keypad.
Dec 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
My wireless keypad stopped working. I replaced the battery. It worked 1x and hasn't worked since. I'm able to program remotes. The keypad is backlit and flashes when I enter the code or try to program it....
I would make sure the battery contacts are clean and not corroded. Otherwise a new keypad is most likely the answer. Just FYI the keypad will still work when the wall control is locked.
Sep 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Hi my remote works the wall button works but the keyless keypad will close the door when code is entered but it won't open it
It sounds like the keypad has lost signal strength. Make sure the battery is good. If it acts the same way with a good battery you will have to replace the keypad.
Jul 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote Control closes garage door but does not open
It sounds like a case of your keypad losing signal strength enough that it cannot transmit through the closed door. If a new battery doesn't do the job a new keypad will.
Sep 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster wireless keypad closes but won't open the door
If you are sure the battery is good you have a bad keypad. The signal strength is so weak it will not penetrate the door.
Aug 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wireless keypad will close door but open
WHEN YOU CHANGE THE BATTERY YOU NEED TO REPROGRAM THE UNIT.
IF THAT DOESN'T WORK YOU PROBABLY HAVE A BAD KEYPAD.
HOPE THIS HELPS
Apr 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad outside not working Properly
Have you replaced the battery in your keypad? That should take care of the trick.
Jul 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
76 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
