Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
I have a SimpleTech Pininfarina 320GB External HDD, however when I have it all hooked up and powered on, the computer does not acknowledge it. HELP?!
The red light on the back is on and when I initially power it up the blue ring on the top flashes. After that, nothing.
  • 93 Answers
They are quite a lot of different formats that hard drives can be run in. Fat 32, NTFS has several formatsof its own. Then there are the Linux and UNIX and Apple formats. By rights many are supposed to be compatible but the some reason they don't always work together.Have you tried running the new hardware installation wizard?I will have a look and see if I can find any information on this problem as I find it to be quite common.Hope this helpsregards
Posted on Feb 22, 2012
5 Suggested Answers
TomSolomon
  • 50 Answers
SOURCE: SimpleTech SimpleDrive Pininfarina 320GB Power up problem
It could be that it's internal power supply burnt out,
in which case the drive itself could still be fine.
Try opening up the external case, and removing the drive.
Once you do, plug it in to your computer directly using its SATA cables, and see if that works.
Hope I helped,
Tom
Posted on Jun 21, 2009
  • 10406 Answers
SOURCE: i lost my start up disc for my simpletech
From the manufacturer's web-site:
http://www.simpletech.com/commercial/products/simpledriveportablepininfarina.html
follow the link:
http://www.simpletech.com/support/support_downloads_storagesync1.42.php
for the "StorageSync Backup Software Ver. 1.42" software.
Posted on Apr 05, 2010
prashant2012
  • 1127 Answers
SOURCE: lost power cord for simpletech
Hi
Please the the adepter for the mention below Inputs
Input 1000-240v-1.0aMAX
50-60Hz
Output +12v 1.5a
that's help u
Posted on May 05, 2011
  • 22 Answers
SOURCE: SimpleTech SimpleDrive Pininfarina 320GB, I
http://www.hitachigst.com/support/index-files/simpletech-legacy-downloads. I am unsure which SimpleDrive version you have, but if it's the regular (not deluxe, mini, or 3.0), it should be the first driver on that page, assuming that Windows XP doesn't install the drivers itself when you plug it in.
Posted on Jul 18, 2011
I have a pininfarina simpletech 500GB usb external harddrive that does not show up in the My Computer folder of Windows Explorer. Tried hooking it up to a different computer with the same results; no...
If it is a new hard drive then it needs to be formatted. You can do this by going into your start menu - control panel - administrative tools - computer management - disc manager. I could be a little off on the wording as I don't have my computer handy, but in the disc management you should be able to right click on the drive in here and choose format. This will format the drive to be used. I hope this helps.
Sep 10, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
Lost power cord for simpletech pininfarina 320gb external hard drive. Where can I buy a replacement?
Hi
50-60Hz
Output +12v 1.5a
that's help u
May 05, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
I pug in my simpletech pininfarina 320 GB and muy computer doesn't recognise
I had the same problem some time ago. Have a look at these tips on how to fix external hard disk problems, maybe it helps you too.
http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Dec 28, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Changed internal harddrive and now, computer cannot recognize the simpletech pininfarina external hard drive
If you loaded a driver for the Ext HDD with the old HDD, simply reload it or download off the net.
Dec 23, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Simpletech External Drive now failing to connect with USB 2.0
Hello sir, let me give you some tips, you can dismantle it and get the HDD unit, buy a cheap external SATA usb hdd enclosure with USB 2.0 . Well all of them are 2.0 compatible (the unit without the HDD) and put it there. you can always keep the old one for posterity. hope this helps.
Aug 06, 2009 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
The power adapter does not work
open plastic case and pull out the sata hdd and put it in a comp with sata support
Jul 13, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Hope I helped,
Tom
Jun 21, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
USB not recognized
Sometimes it helps to reinstall the drivers for the USB hub/controller in the Device Manager.
For other ideas, have a look at these external HDD troublshooting tips.
Hope it helps.
Jules
Jun 13, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
SimpleTech 320GB Not Found by PC
Very simple solution. Your external storage cabinet for the drive is junk. I opened mine up and its just fitting loosely in it. You will void your warranty if you do - but who cares, the cost to send it in for an RMA is equal to the cost for a 2.5" SATA enclosure. When you open it up, the SATA and Power connector is not all the way in - push it in and then tape it so it holds together. Plug it in and you should be fine. Fixed two of them that way.
Dec 17, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
63 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
