Question about Frigidaire Refrigerators
Model PHS69EHSS2 Frigidaire about 3 years old . 10 days ago water appeared water leak
Model PHS69EHSS2 Frigidaire about 3 years old . 10 days ago water appeared on the floor . Cleaned up and could find no leak . Went a couple days and water again. Called repairman and he checked drains for leaks or plugs , evaporation pan for cracks . He found no leaks . A week later (Friday evening) water again . Sat. noon lots of water . The leaks are random and the volume varies . Twice water has run out into the kitchen other times when we look under the frige we just see a wet spot . Help
4 Suggested Answers
  • 1462 Answers
SOURCE: Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Posted on Sep 07, 2008
  • 56 Answers
SOURCE: 10 year old frige leaking water from the freezer onto the floor
drain tube is plugged the fridge goes into defrost about every 8 hours use a hair dryer to melt the ice and check the drain tube goes to the pan by the compressor
Posted on Jun 30, 2009
  • 25 Answers
SOURCE: Frigidaire plht189sska top freezer fridge problem.
If the defrost heating element, defrost timer or evaporater fan weren't working, you'd develop a block of ice on the evaporator. Is the compressor running? If it is, it might have bad valves from the frost buildup scenario. Liquid refrigerant could have gotten to the suction valves. The sealed system should have a five year warranty. Might be time to call a pro
Posted on Sep 15, 2009
Testimonial: "Thanks for your help. Just looking for direction and trying to troubleshoot ...very frustrating. Thanks again Em"
Frigidaire pld2850rdc1
It is likely that the door seals on an 8 year old dishwasher could be ready for replacement.
Dec 21, 2013 | Dishwashers
What type of refrigerant is used in a Frigidaire side by side it is about two years old?
If you locate the serial tag for the unit, usually inside the cabinet on the inner wall - you will that information. It is different for each model and year produced.
Aug 01, 2012 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
Engine overheating after 10 minutes. leaks small amounts of green coolant after parking. water pump replaced 2 years ago @ dealer. radiator replaced last summer @ dealer.
Greetings:
How many miles on your D, and what engine does it have? The service interval for the cooling system with its oem green coolant is every 3 years or 36K.
When was it last serviced? Where under the car does the green fluid appear when it leaks?
Jul 31, 2011 | 2001 Dodge Durango
I have a Frigidaire Model FRS6R5ESBF that is 3 years old but did not get installed until 4 months ago. The freezer appears to be working fine but the refrigerator side is getting warmer by the day. It...
Could be that the freezer is icing up stopping the air flow coming up into your fridge, try switching it off for at least 12 hours with the freezer door open.
Nov 02, 2010 | Frigidaire Refrigerators
We have water leaking in the fridge and it smells, we have to clean it every day. It is 6 years old. It is frost free.
There is a pan undert the bottom of your ref it has a plastic line apx 3/8 inch around that goes up to your freezer it goes up the back of the ref on the inside or inside the casing. It goes to a pan in the top freezer this line has pulled loose or become plugged try cleaning it out and pour a small amount of 10% bleach water in the freezer grill this is a air vent grill in the freezer it will kill the bacteria that usually has the smell of garlic. good luck
Aug 08, 2010 | Frigidaire Refrigerators
Frigidaire plht189sska top freezer fridge problem. Freezer is cold, fridge is warm. About a month ago, had the problem of frost build up in freezer, water pooling under veggie bins, warm fridge. ...
Sep 15, 2009 | Frigidaire PLHT189CSB Stainless Steel Top...
Refrigerators Logo
52 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
