Question about Sharp Office Equipment & Supplies
Sharp ARM237 copier not working
"Close Paper Feed Tray Cover" but no cover is open. I have tried to open and close every door/drawer
  • 28 Answers
SOURCE: CANON IR2016
hi... try to clean up your copier... usually dust accumulates inside the copier that's why paper inserted will always jam....always see to it that you copier is free from dust and other small particles that would cause your machine to get errors....
Posted on Feb 28, 2008
SOURCE: Woodpecker noise II
Open the rear door above the bypass feed area. Find a small phillips screw on the bottom near the left side. It is located near the door interlock switch. Remove the screw and gently lift the cover starting on the left side. This will allow view of the paper pickup roller. There is a plastic piece over the pickup roller that was jammed in the down position. When it was allowed to move freely it returned to the up postion. Replace the cover and the small phillips screw. Close the door. Try the printer again. When I did this, the woodpecker noise disappeared and the copier returned to normal operation.
Posted on Jun 23, 2008
copiersplusw
  • 136 Answers
SOURCE: Kyocera 3530: Close front cover
OK here is what I like u 2 do
First do u have a meter that Can measure conentuety ? or shorts, well what I like u 2 do is remove the sensor from the copier or remove the connectors from the rear of it, then I like u 2 take a meter and measure the resistances of it, if u get a beep then you know it is closing if not you may have a bad sensor, so do this first then tell me what r your results
Posted on Mar 08, 2009
  • 29 Answers
SOURCE: Sharp AL1631- Paper will not feed through
black lines in the feeder but not on the glass- means there is some dirt on the **** glass just clean this glass on the right side of the main glass and the line will go away , if it does not go away u must clean the optics , p jams can be fixed buy cleaning the moon paper feed rollers inside the paper draw but replacing them would be better, this is a 20 minute jod and should cost no more than $120.00 remmeber this copier toner until can be refilled for $6 and is one of the only units left that can be so keep it. this copier is worth fixing
Posted on Mar 09, 2009
  • 4 Answers
SOURCE: close front cover
THERE IS A PROBLEM WITH ONE OF THE COVER SWITCHES. EVERY COVER HAS A SWITCH, ONE OF THEM MAYBE STUCK, BROKEN, OR MISSING. GOOD LUCK.
Posted on Apr 24, 2009
Misfeed in copier and total counter 463898
Your information too general. But base on your meter reading counter, I assumed a lot of your copier's parts might worn out.
1) Check any paper jammed remaining in the copier. You might accidentally tore the paper and the other tore remaining paper still in the copier.
2) Open and close all the covers. its all on the right side.
-fuser cover,side cover (T/S block section), duplex cover, drawer 1 cover (just below bypass), optional drawer cover (if there is LCT or LCF)
2) Replaced the feed, separation rollers for the drawers,
3) Check the fuser condition. Replace them if condition is not good.
Mar 08, 2015 | Toshiba e-Studio 350 Copier
Tip
Main Error MINOLTA DI 1611, DI 2011 Messages and Their Remedies
PAPER JAM A paper misfeed occurred in the
main unit.
Open the cover at the indicated
location, and then remove the
misfed paper. (“When the Message
(Flashing alternately)
OPEN XXX SIDE COVER
All misfed paper was not removed
from the main unit.
Check the message in the display
for the location of the paper misfeed,
and then remove the misfed paper.
ORIGINAL DOC.JAM A paper misfeed occurred in the
Document Feeder.
from the Automatic Document
Feeder.
Open the Document Feeder Cover
and the Document Feeder, and then
OPEN DOC.FEED COVER
∗REMOVE PAPER IN
BYPASS TRAY∗
Paper is loaded in the Manual
Bypass.
Remove the paper from the Manual
Bypass.
FRONT COVER OPEN The Front Cover of the main unit is
open or not securely closed.
Securely close the Front Cover.
CLOSE FRONT COVER
DUPLEX COVER OPEN The Duplex Unit Cover is open or
Securely close the Duplex Unit
Cover.
CLOSE DUPLEX COVER
DOCUMENT COVER
OPEN
The Document Feeder is lifted up
(while a document is loaded into
it).
Securely close the Document
Feeder.
CLOSE DOCUMENT
COVER
DOC.FEED COVER OPEN The Document Feeder Cover is
open.
Feeder Cover.
CLOSE DOC.FEED
COVER
TONER EMPTY The toner is empty. Copying and
printing cannot be performed.
Replace the toner bottle with a new
one.
SUPPLY TONER
PAPER EMPTY The selected paper tray has run
out of paper.
indicates the paper tray, and
“XXX” indicates the paper size.
Load paper of the specified size into
the specified paper tray.
on Dec 18, 2009 | Office Equipment & Supplies
Bizhub 500
There is another cover at the down right side of machine.Below the side door.Open it and then close it.Then bring out the tray and close it.Machine will start working.if not then tell me...
Nov 15, 2011 | Konica Minolta Office Equipment & Supplies
Sir I have canon IR2016J that some of days paper jam tray not working properly message shows paper jam open left cover but there no paper in machine.
first, do you copy from second drawer or bypass tray or first drawer?
Open the left door, in lower section open the paper cover. Now remove drawer. If You look from the left door side beneath the drum unit, you will see axis with 2 rollers, CLEAN them with alcohol or water by rubbing them, and dry them with dry cloth.
Also if you look little closer beneath the axis with rollers you will see the two rollers ( grey, one above the other ) clean them also or replace them if the rubber on them are too smooth.
If the problem appears when copy from second drawer, i.e. A3, you need to replace the pick-up clutch!
If the problem appears when copy from bypass, clean the bypass feed roller.
Hope that something of these helps you!
Mar 30, 2011 | Canon iR 2016i Black and White Copier
Ricoh SPC400DN Getting frequent "Press A
It sounds as if it is not picking up the paper from the tray. It might need new feed rollers. Another thing to check is the lift arms on both sides of the tray. Make sure the springs are still attached to them. There is also a little switch on the left side front of the tray that adjusts the bottom plate pressure. You can try adjusting that to see if it helps.
Mar 12, 2011 | Ricoh Aficio CL4000DN, SPC400DN, SPC410DN,...
THE PRINTER IS INDICATING A PAPER JAM, THERE IS NO SIGN OF PAPER, THE DRAWERS ARE ALL CLOSED TIGHT
Paper light flashing could mean a few things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 05, 2010 | Brother HL-2040 Laser Printer
My copier AR-M208 won't pick up paper from tray 2 It starts too then nope it says its jamed but not really, we open side door and tray close both then it will copy one or two pages the stop again
It may be that either the feed rollers in that drawer are dirty or worn out and need replacement. You might also want to ensure that there is no dogeared paper in that drawer. Meaning that the edges of the stack are all nice and even, no corners bent over.
Jun 29, 2009 | Sharp AR-M208N Copier
Display says "Close feeder 1 Cover"
close the back door of the paper tray 1. the paper tray for this printer actually has a "door" that opens up. silly but true
May 20, 2009 | Dell 3110cn Laser Printer
Woodpecker noise II
A technician should look at this. There could be a gear going bad on it. Ive see a fee cases where the drum gets bad and cant turn any more.
Are there error codes on the screen?
Make sure the right door where the bypass tray is closed all the way.
Jun 16, 2008 | Sharp AL 1631 Copier
Cd tray error Canon Pixma MP810
Sorry a little late only just read your problem.
The location is not the bottom tray feeder but the disk tray. In settings change your media type to "Printable Disk" the paper scource should automatically change to "Disk Tray" and hopefully every thing will work OK.
May 19, 2008 | Canon PIXMA MP810 All-In-One InkJet...
330 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
