Hp d110 printer control reads paper jam and will not clear on reboot
leroyal
  • 2120 Answers
SOURCE: HOW DO I CLEAR A PAPER JAM, IN MY HP PHOTOSMART 7960 PRINTER
Look in the rear of the machine for a large knob that releases a door.
Posted on Dec 28, 2008
SOURCE: ERROR: Paper Output Jam
HI i just recently 5 min ago fixed this problem.....I tried for days. Most likely something like in my case a small bobby pin fell in the back tray and went into the machine. Some people turn the machine upside down and shake it to get whatever it is out.. nothing fell out of mine when i tried this.. I had to take off the left side of the machine panel ,,,2 screwss in the back and pry down and outward there are 2 screws in the front as well under the silver corner push downward on edge.
I held a piece of paper in front of the front roller and revese fed it into the machine by turning the exposed "wheel " on the left side. You have to guide it through lift up top to see in there as the paper goes under the white rollers. At this point the paper may jam so look inside top at the white rollers about an inch from the right there is a small rectangle shaped hole in there is a black plastic part that part needs to be lifted with a paperclip so the paer can be feed under it,,,,at that point is when the paper i was reversing pushed out a bobby pin.....now mine works great again......main thing here is there mostlikley is something clogged in there,,blocking the paper.........also check you paper that gets stuck my paper kept having a bend in it where it jammed and thats where the pin was in there.
Posted on Jan 02, 2009
SOURCE: HP 7680 paper jam
I spent 21/2 hours with the HP tech support - with their recomendation to upgrade my 14 month old computer to the bigger model because the screen reads "paper jam". I have had this printer replaced once already, 1 week after I received it for a defective doc feeder. I decided to take things into my own hands - First of all, no paper was ever located in the paper jam area. Several soft resets by shutting down for 20+ seconds, then pressing #6 at start up resulted in any improvement - the screen continued to read "paper Jam....." the HP tech was unable to offer any practical suggestions.
I turned the machine upside down after removing the document feeder and examined the rollers at the back of the rear tray where the paper jam was supposed to be. I noticed that there was some black residue on the gears and although the machine was off and unplugged - the rollers / gears would not roll freely and seemed to get stuck. I cleaned them thoroughly with an old but clean toothbrush and water. (don't grease the gears - I've heard it eats the plastic) - until the rollers would freely roll when I moved the gray rubber rollers.
Returned the machine to correct position - and turned it on - "paper jam" message returned but the machine was sounding different than it had - so I did another soft reset (unplug from wall and printer for 20 seconds, then holding #6 for a few seconds while plugging back in and now I can print. The printer went through its maintenance cycle and did a realignment. I can print and everything is working fine at this time.
I hope that this will help someone. I couldn't find any information on how to repair the printer and HP seems to be all about producing junk and convincing you to "upgrade" at a cost of $2-300. When this one does finally go - I won't be buying an HP!
The 7680 jams a lot and the document feeder has a lot to be desired. It has trouble feeding straight and if there is a jam anywhere in the machine - it is always difficult removing the paper without tearing it and creating more problems and waste of time.
Posted on Apr 10, 2009
RPFinney
  • 385 Answers
SOURCE: HP 6200 all-in-one --paper jam problem
Check side ADF grips are correctly setup, paper tray is not mis-aligned, remove if poss, and replace to check.
check you printer's properties paper size is set correct for the paper used,
open the back door check for loose particles or paper,
remove slowly.
4 x Feed rollers in the back, revolve and clean with distilled water.
wait till dry, try printing again
Disconnect the power cord from the product.
Press and hold # and 3 while reconnecting the power cord.
When reset displays, release both buttons.
Try printing again.
Hope this helps
Regards.
Posted on Apr 16, 2009
ChineseCrap
SOURCE: HP j4680 all in one printer constant Paper jam message
Based on encouragement from olsnake above, I fixed it easily. It definitely WAS the encoder wheel (a thin clear plastic disk printed
with timing marks) on the left side of the paper-feed roller, as you look at it from the front. This wheel provides motion feedback to the paper feed control software. If the disk is detached/loose, the device thinks the paper feed roller is stuck or impeded, and thus gives the annoying error.
What I did:
1) Remove the scanner assembly (it comes off with a few screws, and is a totally separate unit; The printer works with it completely disconnected (after it complains that the scanner is malfunctioning). Beware that you don't break off the little control panel. Or you can be safe and remove the one screw holding it on, by prying off the 'HP OfficeJet...One" plastic cover.
2) Once you have removed the scanner assembly:
at the left side you will see three white plastic gears meshed together; the farthest one is covered in a circular black
plastic cover. With some care you CAN remove this cover without any additional screwdriver work.
3) in my case (and most others I bet) the thin disk was detached from the gear to which it should be attached. I just shoved it back on, so it was tightly mated to its white gear. You should also ensure that the clear disk goes through the optical sensor at the bottom (mine was).
4) I did not bother to replace that cover, if you can do it, good for you.
5) Test, and reassemble.
This is about the WORST product engineering imaginable. But I have a working printer again!
Posted on Jan 17, 2010
Help My hp photosmart d110 is showing clear paper jam and i have checked there is no paper inside
There might be a small piece of paper somwhere in the rollers, also try switching off for 10 seconds and switch on again
Sep 04, 2015 | HP Office Equipment & Supplies
Paper Jam errror
Jam in output bin - duplex area
Error message
Jam in output bin
alternates with
Open door and clear jam
Description
Paper jam in duplex reversing area
Action
  1. Clear the jam.
  2. Press the (SELECT) button on the control panel.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Jam in output bin - fuser area
Error message
Jam in output bin
alternates with
Description
A paper jam has occurred in the output bin near the fuser area.
Action
  1. Clear the jam.
Goodluck..
May 14, 2008 | HP Color LaserJet 2600n Printer
HP PSC 1610 All-In-One paper jam 1/2 sheet
Throw this thing out as it is clearly rubbish. HP inkjet printers will **** the life and money out of you. Get a Brother HL-2170W and you will have care free printing for cheap.
Cheers old chap.
Mar 19, 2010 | HP PSC 1610 All-In-One InkJet Printer
Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
HP PSC 1310 reads paper jam in control panel. There is no paper i
Click this link to solve your paper jam problems with your HP printer:
http://bit.ly/9ShIi2
Mar 12, 2009 | HP PSC 1315xi All-in-One Printer
Hp 8250 printer paper jam?
If you've unplugged the printer and restarted the PC, you may have to uninstall the driver and reinstall it.
Jan 04, 2009 | HP - HP Photosmart 8250 printer
HP 5610 Paper Jam Error Won't Clear
http://h10025.www1.hp.com/ewfrf/wc/document?product=79488&lang=en&cc=us&lc=en&dlc=en&docname=c00042573
Dec 18, 2007 | HP PSC 2110 All-In-One InkJet Printer
469 people viewed this question
jasbo
jasbo
