Question about Refrigerators
My hoover contour fridge (bottom freezer) suddenly isn't cold enough. I went to the freezer and the ice cream had melted & food started thawing out. The fridge isn't very cold either. I
My hoover contour fridge (bottom freezer) suddenly isn't cold enough. I went to the freezer and the ice cream had melted & food started thawing out. The fridge isn't very cold either. I have turned the dial to
  • 4 Answers
SOURCE: Nextra Hoover Fridge Freezer, Fridge not cold enough.
I would turn the thermostat up towards number 4.
Posted on Dec 12, 2007
SOURCE: Refrigerator and freezer not getting cold enough
If the problem just gradually started happening, it's possibly the defrost cycle that's not working right. Fridge doesn't defrost, the cooling system ices up, and the cold air can no longer travel through the fridge.
You can tell that's the problem if you fully defrost the fridge (turn it off for a day), then start it up again. If it works OK for a while, then does the same thing after a few weeks that's what it is. Either way, you need a repair person to fix it, or you need to defrost it regularly, but then what do you do with your food while you do that???
Posted on Nov 17, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Posted on Feb 12, 2009
woodchuck789
  • 4059 Answers
SOURCE: hoover contour fridge leaking
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 30, 2009
Testimonial: "thanks, all fixed!!"
  • 396 Answers
SOURCE: Food in the freezer on my side-by-side GE Profile
It's hard to understand how the refrigerator compartment would be okay, but the freezer is not. The evaporator coils are normally behind the freezer. The cooled air is moved from here to the freezer and refrigerator by the evaporator fan. Is this the fan you are saying is going on and off? Or the compressor fan underneath the refrigerator.
The necessary conditions for proper cooling are:
1. Compressor is running; 2. Compressor fan is running; and 3. Evaporator fan is running.
Posted on Oct 18, 2009
Testimonial: "Great info and incredibly timely! I'm a new fan. Thank you."
My whirlpool fridge isn't cooling but freezer is
check if it has iced up around the air vents between the two halves as that will block airflow and warm up fridge. if it is is give it a good defrost to melt the ice and stop it from reicing
Feb 08, 2012 | Whirlpool Refrigerators
Freezer is not freezing some items and not freezing some. Ice Cream is not freezirng, sausage & hotdogs are not freezing. Ham is not freezing, etc. There is no food blocking vents. I tried to...
Hi, The freezer is not staying cold enough...ice cream takes colder temps...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 02, 2011 | Whirlpool Refrigerators
My freezer frosted over everything because the door was not shut tight and now it will not clear.
take out all the food out of the freezer,unplug the fridge and get a hair dryer and start melting out all the ice in the freezer,then blow the hot air into the vent holes on the back wall until you don't see any more water dripping down through the slots in the back wall.turn the machine back on,open the fridge door after around 5 or 10 minutes and if you feel cold air blowing into the fridge you fixed the problem,if you don't feel cold air keep hitting the inside back wall with the hair dryer and keep blowing the hot air into the holes in the back wall.all that it does is the freezer gets cold and there's a fan behind the back wall in the freezer,the fan blows the cold air into the fridge side,if the air ducts are frozen the air can't circulate into the fridge section so you have to melt the ice out so the cold air can blow from the freezer to the fridge.good luck,if you have another fridge remove the food and unplug it and leave the doors open for a day and it will melt out.good luck
Jun 16, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
Hi all My fridge freezer seems to have a problem.
increase the thermostat to a more cooler one, ideally at -5 F
Jan 02, 2011 | Freezers
Hoover Contour Refrigerator - not holding temperature
Possibly a re-gass after repair may solve the issue.
May 13, 2017 | Hoover Refrigerators
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Freezer not freezing food even at highest setting
If the unit is running continuously and not maintaining the temperature cold enough the system may have a leak. If it is NOT running continuously the problem could be in the temperature control.
May 12, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
