Question about Samsung LN52A530 LCD TV
Samsung ln52a530 - cannot turn tv off, but has no picture.
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: I had Samsung LCD Series, 530 Model LN52A530 52"
Does it look like this?
http://s807.photobucket.com/albums/yy352/budm/Samsung%20LN-T3242H/
If you tap on the main board, it may come back on.
Posted on Feb 04, 2011
My TV is turning on an off itself with loud noise
The problem is most likely BAD OR DAMAGED SOLDER JOINTS between components and PCB...
it may be in power supply or motherboard..
please carefully check each and every solder joints, please use a magnifieng lens to observe the pcb for dry solders.
you must re-solder all the damaged joints..
May 03, 2016 | Samsung LN52A530 LCD TV
RRght 1/3 of screen had vertical lines, now solid black.
that is most likely going to require a new display. what is the model, version, and serial number for the tv? I may be able to help.
Mar 11, 2014 | Samsung LN52A530 LCD TV
Samsung vertical lines
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 22, 2012 | Samsung LN52A530 LCD TV
Screen is washed out and bleeding green
Hello
A defective power supply switching regulator board can cause this fault. Check your TVs power regulator board [mains] for any leaky or bulged capacitors in it. If there is some, the voltage regulation will be poor and all other circuit boards won't get sufficient voltage to work on.
I hereby attaches two pictures. On the first one you can see a good capcitor with flat top and the same type of bulged [damaged] one. On the second picture, you can see two bulged capacitors [arrow marked] and goond ones by its side.
This is the picture of the mains power switching regulator board of your Samsung Tv. Check whether there is such damaged capacitors, I've described above. If there are, repalce them with same type in capacitance. All of its details will be printed on its boady. You can buy them from any electronic spare part selling shops at your town. If this does not help you, replace the board as card basis. There is no other repair can be done with these type of power supplies, other than replacing damaged capacitors if any. OK.
Sep 29, 2011 | Samsung LN52A530 LCD TV
I have samsung lcd LN52A550P3FXZA There is 1 blacks vertical lines on the screen i thinking to replace the LCD Controlleror Buffer Upper left
If this tv LCD screen panel have not cause by any person or object truma to LCD screen panel. This problems it is alway the causes of the T-Con decoders board sit in the middle bottom of the LCD screen panel.If it is causes by a person or an object causes truma to it,this LCD screen panel is radiations are dead for that area,this LCD screen panel can't be fixed.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con decoders board for the replacement.
Feb 17, 2011 | Samsung LN52A530 LCD TV
My tv wont turn on the indicator light blinks on and off but the tv never comes on
Hey there! Your circuit board inside the TV is dead. Depending, it could be the whole board, or its just one little circuit. I had the same problem 2-3 weeks ago, the customer care came into my house and changed it for me in 2 min. They told me exactly what I knew they'd tell me, something is wrong with the cord and the plug in, so, you should replace the plug in you have, because it can cause the board to die off again.
It costed me around $100, and everything is perfect now. I wish you the best of luck!
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Arial}
Thank you for using FixYa!
I hope that I helped you & that this post is helpful to you at most!
Don't forget to rate! :)
Jan 17, 2011 | Samsung LN52A530 LCD TV
I have 52" hd lcd TV.. And when I press the remote
Please navigate to this page ...click here
It is an articol about .Samsung tv strange clicking sound!
Dec 11, 2010 | Samsung LN52A530 LCD TV
Tv won't turn on. Stuck in loop of red standby light clicking on /off.
sounds like the unit has entered a protection mode where a short has developed somewhere inside the tv. This response is the power supply in the tv trying to start up - seeing the overload and shutting down to protect itself, this loop will continue until the short has been resolved - best to get it repaired by a technician
Aug 13, 2010 | Samsung LN52A530 LCD TV
Can't seem to add HD channels to Mitsubishi WS-65513
You need to run an external antenna feed to the air DTV input jack, bottom left. You can use your loop out if you already have an antenna connected to your antenna A input jack. Create a DTV device, then run your antenna setup for DTV.
Mar 14, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Samsung LN52A530 LCD TV Logo
76 people viewed this question
Henry  Thomas
Henry Thomas
