Question about Zebra LP 2844-Z Thermal Label Printer
I am able to create the details I need in word and sized down my output to fit on output of Zebra LP 2844, I scan a barcode (2400, 1800 or 800 dpi) into the word document and the output from the Zebr
The scanned barcode coming from word into zebra is fuzzy...but the barcode on any other printer looks fine. there is a setting on the zebra I just*cannot** find. please help!
5 Suggested Answers
  • 4 Answers
SOURCE: Zebra LP 2844 printer will not print anything but the test page
possibly not a real LP2844 but an LP2543, a printer mass produced for and used by UPS. refurbishers change the label and sell as LP2844 because they are almost identical.
if it has an AC-AC adapter, it is an LP2543. LP2844 uses a AC-DC adapter, and all LP2844's have USB ports.
Posted on Apr 10, 2009
  • 298 Answers
SOURCE: Zebra LP 2844 spitting out blanks
Look at the stocks tab in the driver. There is an area in your print driver to adjust the width/height of the kind of label you are trying to use.
Posted on Apr 23, 2009
  • 35 Answers
SOURCE: Zebra LP 2844 Printer Error, Cannot Print
Try this
START
SETTINGS
PRINTER/FAXES
in the pop up window go to
FILE/SERVER PROPERTIES
DRIVERS
SELECT THE MFC5440 DRIVER AND REMOVE
SELEST THE LP 2844 DRIVER AND REMOVE
Now go to www.seagullscientific.com and download the Zebra driver pack, once downloaded run it and install the Zebra Lp2844 to with the USb port.
This should solve the problem, if not please come back.
trevor
Posted on Feb 16, 2010
  • 35 Answers
SOURCE: how do I restore factory settings to a zebra
The ^default command has been added to the EPL2 commands, starting in firmware version 4.39. This command will set the printer back to factory settings as long as the printer is in page mode. The command is not supported in line mode at this time. The command is case sensitive.
Syntax: ^default.
You can send the command to the printer via the parallel or serial port.
Parallel:
Open command prompt (DOS prompt) See windows instructions for details.
At the prompt type:
ECHO ^default>LPT1 <enter>
Serial:
Assuming standard communications on the printer of Baud 9600, No parity, 8 bits, 1 stop bit and use of COM 1:
At the prompt type:
Mode Com1:9600,n,8,1 <enter>
ECHO ^default>COM1 <enter>
I have Zebra LP 2844-Z printer and the barcodes
Here are 3 suggestions.
Check that your label size definition is correct, measure your label height in mm and check that your printer driver settings match.
Perform a calibration. How?? when printer is on labels loaded and green light, hold feed key and wait for 2 blinks then release feed key. (If you release it after 1 flash you will print a configuration label)
If you are using Zebra Designer, download latest version of Zdesigner V2. Install latest printer driver V2.63. This driver & Zdesigner allows you to calibrate the printer directly from within Zdesigner. Go to File/Printer settings/ advanced options and click calibrate at bottom of page. when printer calibrates then tick the box USE PRINTER SETTINGS and printer will now work properly.
Jul 01, 2010 | Zebra LP 2844-Z Thermal Label Printer
Will the Zebra LP 2844 work in Quickbooks with Windows 7? I cannot get it to work. My computer is also 64 bit.
Quickbooks uses a DOS backend, you will need to set it up as a serial connection. If using a USB to Serail converter, you will need to find software to create a virtual Com Port to make it work.
Oct 29, 2009 | Zebra LP 2844 Thermal Printer
Hi my zebra printer can print but when I scan it doesn't read. It only read nummer but don't read any letter. And all the barcode of mine is in letter en nummer. Can u solve this
If this is a normal LP2844 and you can't scan the barcodes it is printing, you will have a faulty printhead with a pixel or two blown.
Oct 02, 2009 | Zebra LP 2844 Thermal Printer
Create my own barcode, barcode doesnt read
All barcodes have start and stop characters, maybe these are missing.
Dec 15, 2008 | Zebra LP 2844 Thermal Printer
Barcode Printer's Ribbon Installation demo
I can forward you the user guide, this will explain in detail how to install your ribbon, please reply with an e mail address which will accept 4.42mb
Jun 07, 2008 | Zebra LP 2844 Thermal Printer
Zebra TLP 2844 Controlling the font size w/iSeries??
Hi Burgymon,
The font that is used under the barcode will use the last font properties described prior to the barcode in the output. You may want to suppress the human readable option and create a separate text field to display the text version of the barcode contents.
Mar 25, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Open Questions:
See all Zebra LP 2844-Z Thermal Label Printer Questions
Zebra LP 2844-Z Thermal Label Printer Logo
139 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
