Question about Coby MP-610 MP3 Player
Why won't my mp3 coby player won't charge
I'll leave my mp3 player to charge and when i take it out of the computer i have no battery a pictue keeps popping up of like an red X i don't know what's wrong with it..i used the reset button but it seems to do nothing
  • 59 Answers
Your coby is not charging anymore..The battery probably needs to be replaced with a new one..Please check your connection when you charge it..There should be an icon that shows your battery is charging. If it does so that means your coby is charging but your battery cant store the energy anymore.
Posted on Feb 20, 2012
I put a sdcard in the mp3 player & it still won't hold a charge or save pictures that I take, why?
If you charge the MP3 player using the USB cable and the battery will not charge up then the battery is worn out and needs replacing.
Jan 01, 2013 | Audio Players & Recorders
My battery for my mp3 won't last long
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 16, 2012 | Coby Audio Players & Recorders
My coby mp705 wont turn on but when i plug it to my computer it works.. what kind of assistance shall i do to make my coby back to normal? any kind of answer would be wonderful
sounds like the battery is the problem if it wont start wothout a power source
Check the system requirements for the MP3 player.
Most Coby players require Windows XP or higher and at least 1 GB of RAM to function correctly.
Check your Coby owner's manual to ensure that your machine meets all the required specifications before proceeding.
Charge the MP3 player fully.
Often, a player will act unexpectedly if it has a low charge.
A charge can also help reset the MP3 player if it has frozen or locked up.
Once the player has finished charging to 100%, see if the problem persists.
Re-sync your player.
Plug the MP3 player back in to the computer and then remove all the files.
If you have not done so already, make sure they are backed up to your hard drive.
Unplug your MP3 player and then re-load all of your files.
Check for corrupted and wrong format files.
Most Coby MP3 players only play back MP3 files, and will perform unexpected operations
if files of other formats are uploaded to the device.
Go through your uploaded files and check the extensions.
Anything that does not say ".mp3" or is not listed in your owner's manual needs to be deleted from the device.
hope this helps
Sep 30, 2012 | Coby MP-705 Digital Media Player
How do you charge the delstar ds 821, & down load music?
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Mar 08, 2012 | Audio Players & Recorders
My coby 705 is very fast to low battery what even if it is fully charge, what should i do?
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Sep 09, 2011 | Coby MP-705 Digital Media Player
I just got the mp3 player. ive been charging it but when i disconnect it from my computer it shuts off and wont turn back on. HELP!
Some older computers that have USB ports that limit the output to 5V @ .5 amp current. Depending on your MP3 player, it may not be sufficient to charge the player. This was the spec back then. Since then, new USB specs call for 5V @ 1.0 amp current - a two fold increase in current.
You may have better luck connecting to a powered USB hub instead. If you're only looking to charge the MP3 player, you don't even need to connect it to the computer. The powered hub gets powered by connecting the ac adapter / power supply to a wall outlet - instead from of the computer's power supply via mother board.
The above assumes there is a good, rechargeable battery; a functioning charger & USB port in the MP3 player and of course, a working USB cable. If any of the above is faulty, you'll never get the MP3 Player to accept a charge. You should try different computers, cables and ports if possible.
Sep 07, 2011 | Computers & Internet
I plug my mp3 player into the usb port on my computer and it doesnt turn on to charge like it did before. i tried to turn on my mps player and it acts like there is no power. i just got this mp3 player and...
Hello
Check the connections on both ends to make sure they are attached securely. If the MP3 player is still not recognized, go into the player settings and change the Online Device from Media Device to USB Disk. Use a different USB cord if you have one because it could be broken and not allowing your computer to recognize it.
connect the device to a different USB port on your computer. If the MP3 player is still not charging, plug it into a wall charger. Try charging the Coby device overnight. If it still will not charge, the battery may be bad and you'll need to contact Coby for assistance
Apr 30, 2011 | Coby MP620 MP3 Player
Coby 610-2g mp3 player wont read or turn on
I can help you with you Coby 610 mp3 player.
Replacing the firmware in your mp3 player will let your computer see it again & turn on etc.
Please follow these steps to fix your Coby MP-610 MP3 Player.
I hope that helps.
___________________________
Unfreeze Coby 610
Mar 20, 2010 | Coby MP-610 MP3 Player
Charging problem
You must leave it connected and after charging you will see a message that says charge is full, usually leave it all night, of course it won't take that long, but stop looking at it and let it go.
Dec 28, 2008 | Coby MP-705 Digital Media Player
Mp3 won't turn on
These don't charge. They use a battery.
Jul 01, 2007 | Coby MPC-848 MP3 Player
Coby MP-610  MP3 Player Logo
375 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
