Question about Duracraft Dryers
Duracraft df-1800 how do you take it apart to clean it
2 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: can I take my duracraft drill press chuck apart to clean it?
usually that requires special fixtures to remove the collar and a press, I would recommend cleaning with WD-40 and wiping clean all exposed parts and if you have compressed air try using that also, WEAR safety glasses.
Posted on Feb 07, 2012
I am. Trying to clean a duracraft 1997 but i. Cant get the blade to separate. From the motor
Some of them are not meant to be seperated, if it is, then it should have 2 slots opposite of eachother in the back of the blade where the plastic fan meets the steel rotating bar, or it could just be pressed on and you would have to pull it off with as much equal force all around the circumference of the back of the fan's main part, the entire round part, either way you need at least 3 hands to do the job, so have someone help you or just clean it as good as you can as it is, I don't think it really needs to be that clean aye'? LoL
Nov 16, 2016 | Duracraft Dryers
Can I take my duracraft drill press chuck apart to clean it?
Feb 07, 2012 | Drills
Hi, we have a Duracraft Commercial Grade High Velocity fan. When we turn it on it just hums, fixable? thanks, Nancy
Mine does the same when I try to start it on low. If I start it on hi after it gets going I then can turn it to low and works great. Hope this helps.Also you need to take it apart once a year , remove blades, take it outside and air blow the motor out .
Sep 01, 2011 | Duracraft DS-1600 Fan
I need the instructions for the Duracraft Victorian Mansion Dollhouse Kit VM800 (it has been discointinued)
http://www.ebay.com/sch/i.html?_kw=dura&_kw=craft&_kw=dollhouse&_kw=800&_kw=victorian&_kw=mansion%29&_ipg=
May 21, 2011 | Duracraft Dura-Craft Dollhouse Kit SAN...
Have a Duracraft DT-70. It is dirty and filled with cat hairs and grease on the blades. I can't figure out how to get it apart to clean it.
You will need to take this apart and use a good degeasing spray to remove off al the dirt. Use diesel/kerosene to wash well and clean it dry. Use a good paintt brush to wash off all dirt into the hidden areas.
Wipe dry finally to reset.
Sep 13, 2010 | Duracraft Dryers
No vapor
you need to take a soft toothbrush and some cleaning solution to clean the coils. if the coils are too build up of scale it can reduce the mist or not produce any at all. if that doesn't work there is something internal that is going on and i would check with the manufacturer if your under warranty to get a new one.
Apr 07, 2009 | Duracraft DWM-250 2.5 Gallon Humidifier
Codes
Telewest
C3 40 78 A2 B2 1C 84 F9
2A 09 4D DF CD 33 00 B9
Jul 09, 2008 | StarTech.com StarView SV211K 2-port KVM...
Dryers Logo
60 people viewed this question
Top Duracraft Dryers Experts
richie46
Are you a Duracraft Dryer Expert? Answer questions, earn points and help others
