Question about Sony Playstation 3 (PS3) Console
Ps3 menu the menu does not come up it only shows my backround.(or the picture that comes up right after it says sony playstation
    Novelist:
  • 111 Answers
Hi there. if you have PS3 Firmware 2.5 you could be in look. there is a System Restore ability on the PS3 which will allow you to restore your PS3 to a working state. and here is how to do it ! :
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
hope this Helps !
Posted on Oct 27, 2008
Okay basically, i turn on the ps3 , it looks perfectly fine but on the menu , it just shows the backround and there are no options. what happened to it? it was working fine earlier
How to Access Playstation Recovery Menu
1. Turn off Playstation®3.
2. Hold The power button down; The system will turn on and turn off once again.
5. You will be promted to plug in your controller via usb and then hit the PS button
try to recover your unit from here you will lose data depending on options you try son start with rebuilding your file system and try from there good luck ok
Nov 25, 2010 | Sony Playstation 3 (PS3) Console
Home screen shows only backround. No icons
Switch the PS3 off (Red Light). Hold your finger on the power button until the PS3 switches on and off. Take your finger off and hold it in again. It will come on. Hold it until you hear a double beep and take it off immediately. You will then be taken into a recovery menu. It will ask you to connect your controller via USB. Choose option 3 - Restore File System (Do not try any other option as it will erase some or all data on your HDD). It should work after this.
Hope it helps you.
Nov 05, 2009 | Sony Playstation 3 (PS3) Console
The backround screen is there but none of the options or buttons will come up and i can't play games it also won't shut off using the power button on the front just the larger switch in the back the...
hold the power button down when it is red till you hear the quick beeps then select the file restore this will restore your harddrive,,,may have to do it twice....remember hold the power button on the front of the ps3 until a diagnostics menu comes up
Nov 03, 2009 | Sony Playstation 3 (PS3) Console
PS3 shows no pics
You have to go into the "photo" menu and then press triangle while on the usb drive and select display all and it should show yours pictures and/or folders containing pictures.
Jun 20, 2009 | Sony Playstation 3 (PS3) Console
Will not show picture
Make sure your TV is on the right setting. Sometimes TV's have multiple AV settings so you need to find the right one. also make sure all the cables are connected to the correct ports
Feb 08, 2009 | Sony Playstation 3 (PS3) Console
My ps3 has a blank screen
Check out my common PS3 problem and repair guide for tips and suggestions for your problem.
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Jan 31, 2009 | Sony Playstation 3 (PS3) Console
My ps3 won't show anything
hold the reset button to restore your settings do this various times untill you get a screen that has many options read the options and pick the option that says rebuild the hard disk drive. once it gets to 100% sat your settings. then your ps3 shouold be back to normal. the bad thing is that you will lose everything you saved on the ps3 =[
Dec 25, 2008 | Sony Playstation 3 (PS3) Console
No writing on power up
Update to firmware 2.5 if you can , if your already on v2.5 firmware go to the recover menu and select restore ps3 system (search youtube ) or you can remove the hdd and put it in a 2.5" powered hdd enclosure and try to format by your pc or just take out your ps3 hard drive and then turn it on.
Nov 13, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
629 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
