Question about iiyama Vision Master Pro 510 22" CRT Monitor
Compressed Screen Hi, I have a CRT monitor, just recentley it has been playing up. It would suddenly produce a bright flash down the centre of the screen, then revert back to normal. It has been doing this on and off. Now when it is turned on, there is just a vertical line down the centre of the screen, less than 1 cm wide, it would appeat that all the picture is compressed into there. Any advice on what components could be causing this would be greatly appreciated. Thanks Colin
Hi, I have the same problem with the same iiyama master pro 510 monito.
Did you resolve your problem? Could you give me any advice?
Thanks
Mark
Posted on Mar 10, 2010
If you get a video camera & wave it from left to right while pointing it at the screen you'll just see the image in the flicker
Posted on Jun 08, 2007
My Sony big screen rear projection TV model KP=51HW40 produced 2002 screen flashes red then shuts off. We can turn it back on and it will run for 30-60 minutes and then it repeats red flash. Is this
The Problem you are having is a Cathode to Grid Short in the Red CRT,When it Shorts the screen will Go all Bright Red and shut Down,The Best fix Would Be to Replace the Defective CRT (GUN)
Dec 30, 2011 | Sony Televison & Video
Have owned a iiyama 17" pro crt for a few years,
These were a fine monitor and with the kind of image quality you cannot get on TFT's.
If you know the graphics card you are using is working ok, have checked the VGA cable connection and socket at the monitor and computer and have tested the monitor on another computer, that would rule out any problems as far as connected devices are concerned.
The problem you describe, and it is unusual that it has happened so quickly, points to a failure of the monitor internal board. You may be able to get this repaired at a reasonable cost by seeking the opinion of a TV repairman, who might be able to fix it.
Jul 25, 2011 | iiyama Vision Master Pro 400 (White) 17"...
I have one pro view 17" view sonic monitor CRT with win xp as my OS. when i am working in my computer suddenly the contrast and brightness symbol comes on the screen and begin to increase to maximum...
buttons are not working perfect.therefore pressing automatically. you have to remove the panel after power on the monitor, (it may be dangers therefore get support by electronic technician , he will remove buttons and solder new ones or replace the switch panel.
Jan 18, 2011 | ViewSonic E70fb 17" CRT Monitor
Brightness pop-up window on screen for a long long time
There are a few things that could be wrong; someone could have a remote and be messing you about, a button could be stuck on the monitor so its increasing, the computer could be slow or signals might be getting mixed up. try and figure it out based on what ive said. good-luck!
May 20, 2009 | ViewSonic E70fb 17" CRT Monitor
The setting is programmed into the memory of the monitor. It has been set that way, sort of like a memory button for your car's driver seat. The car remembers your favorite seat position, and the monitor is remembering your favorite brightness settings.
It's been a while since I played with any settings on a CRT monitor, but I'm sure if you give it a few minutes, you will find in the menu how to set up the memory recall feature on your monitor.
good luck.
tony
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Computer Monitor Problem or anything else
Contrast and brightness controls usually come from one chip. You can try looking up the specs of the chip online and then determine which pin of the chip conrols brightness. Usually faulty Electrolytic capacitors act like the simptoms you described. Find the Electrolytic capacitor connect in the brightness circuit and you will most likly fix your problem. The chip that contols the brightness might also be faulty. Good luck.
NSSMS
Jul 21, 2008 | Compaq CV 7500 17" CRT Monitor
Remove dry solder at Vertical IC if problem not solves replace VERTICAL IC and pf104
Darshan
Jul 05, 2008 | LG Studioworks 552V 15" CRT Monitor
Bright line coming in center of screen
Hi Shailendrar , your problem sounds like vertical collapse , the whole picture has collapsed into a thin , very bright centre line ? maybe the result of dry solder joints , does banging on the side of the tv temporarily fix ? if so , the circuit board requires inspection for bad solder joints . Alternately the vertical chip/transistor may be blown , replace as required. Cheers T
Dec 05, 2007 | Philips 19PR19 19" TV
Dim compaq s510 crt colored monitor
Hi, If you are comfortable working with tools, down to component level and know how to work around EHV areas, then it is possible to increase the brightness of any monitor including the Compaq S510. Make sure that the unit is unplug, Open the back cover and locate the FBT. You have to run/power on/attach a running PC to the unit with the cover off. Extreme care must be exercised. If you are not sure, you're better off asking a qualified service professional to do the adjustment. There two plastic slotted adjustables, focus & screen. Adjusting the screen changes the screen voltage going to the CRT. This will make the display go very dark or overly too bright. Adjust to your preference (not necessarily technically correct) The focus may also be adjusted this way. You have to run the unit with the back cover open for a couple of minutes to stabilize the voltages and the heater/CRT/ Adjust after a couple of minutes if necessary. In other monitors, there is a trimpot (small variable resistor) the adjusts the sub-bright. Further improvement maybe achieved by adding a 100uF/250V capacitor across the supply of the 70+VDC of the 3 gun transistors. If you are sure how to go about this, it is best to consult or seek the services of a qualified TV technician who can either show where and how or do the job himself. Hope this be of some help to you. Pls post again how things turn up. Good luck and kind regards.
Jul 31, 2007 | Compaq TFT5004 (Black) 15 in. Flat Panel...
iiyama Vision Master Pro 510 22" CRT Monitor Logo
172 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
