Question about Garden
Victa Sabre Edger recoil spring
Hi, My Victa Sabre edger has a broken recoil spring. Any secrets on how to fix it back in. I have the broken piece out and have bent the new end on the spring but try as I might I cannot wind it back into place. Any suggestions ? Pat
  • coongoola
    coongoola Feb 20, 2012
    No the rope is not broken, the SPRING is broken, I need to know how to replace the coil spring. Pat
    Sergeant:
  • 316 Answers
Hello sir, i'm guessing the rope is broken , first you'll need a c-clamp large enough to clamp the spooler, needle-nose pliers,a small tipped screwdriver and a new length of rope.the safest way is to remove the rewind assembly cover leaving the spooler in place in its housing. try to remove the old rope with neddle nose pliers ans small tipped screwdriver.next hand spin the spooler to achieve spring tension until stops back off enough to line holes up, place c-clamp to hold it in place,now try to fish the new rope into the hole in the knot recess,trying to guide it to the exit hole in the cover, ( it's easier to feed the rope if you singe the end of the rope with a bic lighter and form to a point )and with a small knot at the other end,pull the rope all the way until you can seat the knot into the knot recess.next tie a loop knot into the other end of the rope,so the end wont be recoiled all the way into the housing.with tesion on the rope gently remove the c-clamp and let the rope be drawed in.if it draws all the way to the loop knot, check to see if the spooler is full if so,( not too full where rope is binding ) pull the rope about a foot and re clamp the spooler and install the pull handle, if rope is too long you may have to cut to length. if it doesn't draw all the way to the loop knot and the spooler is not full than you may need to add anoyher revolution to the spring tension in the same fashion as described above.there are eisier ways but that evolves removal of the spooler and repacking the reciol spring.( not for the novice ). hope this helps,MrFixIt,thank you.
Posted on Feb 20, 2012
  • 38 Answers
SOURCE: Black and Decker 2 HP Lawn edger
Ditch that old switch, and buy a better quality switch from HomeDepot or RadioShack that will suit your need. I personally ran into that same problem and brought a 2HP GP switch from HomeDepot. It works way better, than that stock swicth. ( It may require a little modification to the body though.)
Posted on May 05, 2010
SOURCE: cannot start ryobi 3043 yw grass edger
Check the spark plug and sheck the gap on it then check the wire
Posted on Oct 19, 2008
h_head
  • 3 Answers
SOURCE: my 25cc string edger will start and run fine in med choke but wil
high speed jet is pluged
Posted on Jan 04, 2009
slohry
  • 87 Answers
SOURCE: need parts for craftsman edger/trimmer 275.796432
Here's a link to sears parts website
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080129x00001
Posted on Apr 10, 2009
  • 376 Answers
SOURCE: Craftsman Edger 536-797520 is leaking gas from the air filter
The needle valve is sticking open. The carb needs cleaning and diaphragm replaced. Probably best taken to a shop unless you have experience with diaphragm carburetors. Dwain
Posted on May 27, 2009
Gas edger I need to know how do I repair a broken pull start rope for model 316772380
What is the make and model please.?
Have you tried looking on youtube.? there are many helpful videos showing you how to do this on many machines. Try searching '[your make and model] and recoil'
Apr 24, 2016 | Garden
What do i do to put new pull cord in husqvarna Lawn edger
Remove pull starter off and wind on the new cord then wind up the spring tension so it recoils.
Aug 31, 2014 | Husqvarna Garden
Starter rope replacement
recoil spring has slipped out of the hole.pull your starter rope out of the wind up mechanism, insert the spring latch on both ends and put back into housing. with a piece of 3/4 square stock or something the will fit mthe hole start to wind the mechanism spring up tight. with apair vishgrips lock it down so it does not move. insert your starter rope anr release the visegrips. the springwii recoil and pull the rope in.cut off excess rope. good luck
Oct 17, 2012 | Little Wonder 6032 10 Inch Pro Lawn Edger,...
Edger blade quit turning on convertible weedwacker
One of 2 things...drive cable broken or clutch spring broken
Sep 10, 2012 | Sears Craftsman Convertible 25cc 2 Cycle...
Starter rope broken on victa mower. how do i rewind. Itwill not recoil once pulled out
It sounds like the recoil spring is broken. Take off the recoil unit and remove the pull plate replace the spring if it requires itl davidson lawn mower tech
Feb 08, 2011 | Garden
After pulling the starter coil, it will not be pulled back into the machine or better said, it will not coil for another attempt at starting.
Sounds as either the recoil spring located under the the recoil housing has either broken or the plastic housing that holds the spring end has broken. you will need to remove the recoil housing to determine the problem. To remove:
1. Remove the drive tube by removing the clamp around the front of the housing and gently pull the drive tube from the engine.
2. Remove the torx or slotted screws holding the recoil assembly on
3. Remove the star washer with a flat screwdriver and gently lift the recoil from the housing.
The spring will be directly. You should be able to see the problem at that point.
Sep 27, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
The pull string wont go back in on the weedeater
Likely the recoil spring has broken (often the end) or the plastic recoil winding in which the spring sets in has broken or worn to the point in which the spring will no longer seat properly. Complete removal is necessary to determine the problem.
May 27, 2010 | Craftsman 25cc Gas Line Trimmer
WeedEater Edger PE550 Starter Rope will not recoil
Order a new recoil spring from your suppier. It comes wound up. Remove the old part first usually four screws on the outside. Make sure the rope is fully wound then insert the new spring and reassamble. If it becomes unwound by mistake its a labourious job to rewind but can be done.
Aug 29, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Can't get the nut off.. is there a secret to blade removal
Hi these are usually the opposite way to which the blade turns but you may have to use a rattle gun to remove this. If you have a look at the thread you should be able to determine which way it comes off. Just remember to fix the blade so it wont turn and take your fingers off.
Aug 03, 2009 | Garden
Pullrope broke on weedeater 550 how do i get it apart to fix it
ther eshoul dbe some bolt holding the pullcord/recoil assenbly to the flywheel/motor. you need to locate and find these bolts first. let me know when you have this apart. you have to unwind the rope and pull it completley out, then buy a new pullcord rope(other rope will just fray and break agai) slip it thru the holes tie a knot wind up the spring and carefu;lly place it back on were it came. let me know if you run into any trouble.
Apr 23, 2009 | Poulan Pe550 Gas Edger
Garden Logo
109 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
