Question about LG Washing Machines
LG - Top Load Washing Machine 6.5kg (WM6038)
This LG - Top Load Washing Machine 6.5kg (WM6038) is saying DE all the time and i don't know why, please help me!!!! and i am renting this product from Radio Rentals and i have also called them waiting for Radio Rentals to get back to me.
SOURCE: Broken washing machine
we also have now gotten the same message and same poor help the company is aware of this problem but sadly, the almost $500 replacement to fix the problem is the same original parts that go wrong in the machine so they haven't upgraded the replacement parts which means you pay to get the new part--WAIT for it to arrive because NO ONE stocks LG parts, and then the new part is not any better than the original. We are selling ours and getting a Kenmore.
Posted on Jan 17, 2008
  • 9 Answers
SOURCE: Error Code CE
check the fuse and do not unbalance your load capacity.
check motor winding if burn and replace
Posted on Feb 19, 2008
drsn
  • 42 Answers
SOURCE: I KEEP GETTING A dE
you will need to replace the door sensor, this error will appear until it has been replaced. it is inside the unit and pretty much hard to get to if your not familiar with workin on it. take it to an LG tech or some one whos familiar with it..........
good luck LG's are very sensitive.
drsn777@hotmail.com for more info.
Posted on Dec 15, 2008
SOURCE: LG washing machine keeps stopping and it says OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Posted on Apr 11, 2009
SOURCE: I have a Whirlpool coin operated top load washing
I hate this
try insert another coin
if not you will have to run a wire through and a frictioned and magnetised coin might help
if you can you will have to dismantle this part in trying to release it
Posted on Sep 27, 2009
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
Machine has filled up with water, has DE on screen, manouvered clothing & turned off twice.u
Hi Carol:
The "DE error code" is indicative of a Door Error. This indicates that the washing machine door is not shutting, locking or opening.
Here is a link to a service manual that should help you diagnose it. Keep in mind that LG models are sometimes difficult to diagnose.
VIsit this link: LG Washine Machine Service Manual
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 11, 2012 | Samsung SW62ASP Top Load Washer
I have a LG topload intellowash WF-T7516LS as soon as i switch on the machine the water fills in and then it just shows dE pls help
dE stands for Door open Error. Your door is not closed properly or the door switch is not activated. Try to press the door firmly. If the error does not go then you will have to check the door latch, notch ( a protruding part which goes inside to latch & activate door switch) & the door switch for any damage. For Top load machines the notch is near the hinges & inside the machine.
Sep 22, 2011 | LG WM-2277HW Front Load Washer
My washing machine LG WFT type showing dE error. understand it is door error. I want to know where the door switch is located.
You're correct- 'de' does stand for Door Error. There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor. Both are behind where the door's latch goes requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 19, 2011 | LG WFT1071TP Top Load Washer
Model WFT65A31EC washing machine. Problem code DE . Door lid open error occurs when door is fully close.
'de' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
John C
May 29, 2011 | LG WFT1071TP Top Load Washer
My washing machine stops working, it shows 'dE' everytime i try to start a cycle, and i dont seem to be able to find out what it is... please help
DE MEAN'S DOOR ERROR,There is a little magnet that detects if the lid is open or closed & this magnet always falls off into the machine then pumped away. (If it gets past the pump with out jamming it).you can't just buy the magnet you have to buy a whole new top & most of the time this cause's the computer to fail as well,So it could end up costing a fortune even up to the amount you could have bought a new one my advice get rid of the samsung & buy a new lg the sooner you do that the sooner you start saving money in washing machine repairs.
Feb 25, 2011 | Samsung SW62ASP Top Load Washer
I have a LG WD - 1049C front loader washing machine showing the DE error have emptied out the washing machine and it still comes up, partner bought a new door latch and installed it but the DE is still...
DE error does mean the door latch,but there are three parts that could cause the error code.If you have changed the door lock already then the main p.c.b/computer board has failed and not registering the door lock but there is a 5-10% chance it's the wiring connecting the two parts together.So basically you need to change the main p.c.b & if that doesn't work it needs to be rewired.unless you know how to use a multi-meter then you could test the wiring for a definate answer.THANKS ECO KIZZA
Feb 18, 2011 | LG WD-1045FH Front Load Washer
De error on my lg washing machine, machine is working fine, now i have a door error which means the door is not closed but it is closed i know there is a way to override the problem
LG WFT70A37ECT Top load washing machine, showing DE error... even door is close still showing this error. that is the solution... really appriciate... thanx
Jun 27, 2010 | LG WM-1480FHD Front Load Washer
LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Sep 11, 2009 | LG Washing Machines
Washing Machines Logo
56 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
