Question about KitchenAid Microwave Convection Oven
How does the door on a KEHC309JSS05 come off to replace spring
The spring that keeps the door from falling down is broken. How does it come apart for replacement?
3 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Broken torsion spring needs to be replaced
There are indeed two springs that "cross" each other, and they must be both be replaced to ensure full strength.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 25, 2008
SOURCE: Microwave door tension spring
See answer here http://www.fixya.com/support/t265705-microwave_door
in different thread.. Basically have to pry plastic trim ring off inside of door with putty knife (careful, it cracks easily) to get to screws on bottom of door. See second pic. Top screws are easily accessible from inside of door. Spring can easily be replaced by hand once you get adequate access. You'll need a fairly stubby right angle screwdriver (I used a cut-down #2 Phillips bit and small Vice-Grips as a make-do) to get to the screws. Also need Torx (T10, I think) to detach the shock absorber doodads from the door where they attach above the hinges. If you're just starting to take the door apart, be careful when you take out the top 2 screws on the inside-- they hold the inside plastic piece on , but they also hold the whole outer stainless/ glass/ handle piece on. It just slips in at the bottom, so be ready to slide it out when you take these screws out.fea33aa.pngc391898.jpg
Posted on Jan 13, 2009
How do you fix the door tension? when opened it falls down without any resistance
Check for a broken or disconnected spring for the for. Always unplug it before looking inside. Careful!
Feb 28, 2015 | Microwave Ovens
Door will not stay close
Not much data to go on here. The latch on the door has a spring that holds it down in the locked position. when you pull the handle the latch goes up and you pull the door open. You will have to take the door apart and see if the spring broke or the plastic tab that holds the end of the spring is broken.
Feb 25, 2015 | Maytag Appliances Over-the-Range Microwave...
How do i get into door to replace spring smh9207st microwave ?
You must remove & disassemble the door (I know, duh! :) ).
DISCLOSURE--I haven't replaced the spring, BUT, I did disassemble the door to get at the display board and in so doing, did see the spring/latch assembly. So, I can help with getting the door apart, but not the replacement of the spring itself, but from the looks of it, is should be pretty easy.
Total time: 1 -2 hours, 4 ice teas and lunch.
1. UNPLUG THE UNIT.
2. Remove the grill atop the unit; 2 phillips screws. Gently slide the grill to the left to unhook it from the unit. This reveals the screw holding the right side cover.
3. There are wires connecting the door to the MV. Reach inside and find the connector; it will separate with some squeezing.
4. The door will come off easily by lifting up at the hinge (be careful: there are cheap plastic parts around here).
WORK ON A SOMETHING SOFT TO PREVENT SCRATCHING THE FINISH.
5. Lay the door upside down. Remove the screws holding the handle on.
There are 2 plastic pieces between the metal handle and the door glass. They will probably fall to pieces when you take the handle off. Yes...this is the quality of plastic manufacturers use. PRESERVE THESE AS MUCH AS POSSIBLE, EVEN IF THEY ARE BROKEN. If you need to replace them, they are probably available and cheap. Or not...so try and keep them,
Now the door can lay flat.
6. Now you have to get the plastic trip out. Some suggest a thin putty knife, or similar. Get it in-between the trim and the metal on the inside edge of the trim and the plastic of the door on the other side; there are simple tabs that hold it in. You're just gonna have to carefully feel around until you get an edge up. Then another. Once you get it going you'll be OK.
Once the trim is off, you should be able to get to the spring and do the replacement. If not, you may need to remove an additional piece of the inner door, held on by 4 screws and tabs you need to pry at with putty knife/flat screw driver. It was some hard work getting it off without breaking bending stuff and required some finger strength and stuff to prop it open on one edge while I worked on another.
Give the parts a good cleaning. Reassemble in reverse.
Cleaning tip: Scrubbing bubbles works great for cleaning icky kitchen grease, although it can leave a film (but it gets the grease!). Follow up with windex (but use a windex-dampened paper towel on plastic to prevent scratching)
Jul 19, 2014 | Samsung 2.0 cu ft Over-the-Range Microwave...
How to repair kitchen aid door springs
proceed according and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Nov 01, 2013 | KitchenAid Microwave Ovens
I'm unable to open the microwave door on model Sanyo EM-S8586W as it appears the spring is broken. How do I remove the cover so I can replace the spring please?
make this steps and fix it. God bless you
Oct 26, 2013 | Sanyo Microwave Ovens
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Dec 16, 2008 | KitchenAid KEMC377K Convection / Microwave...
The door will not latch
The latch head (with hooklike projections) have a spring to keep it pulled down. If the latch head can be easily pushed up and falls back freely, then the monting tab on the back of the latch head is broken and it will have to be glued or replaced. The new part is better. To get to the door screws inside, you have to remove the choke cover, as shown in the photo. You can order parts for Sharp models from Tritronics at http://www.wehaveparts.com.
Aug 31, 2007 | Sharp R-1480 Microwave Oven
KitchenAid Microwave Convection Oven Logo
70 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
