I have problem with samsung sync master 2032MW , no display
No display on the screen. the blue switch on button works fine but no display on screen. Could you help? I took some photos inside
waterppk
  • 42 Answers
SOURCE: samsung sync master 510 monitor display problem
It may be that the LCD monitor will not display all screen resolutions so you may need to change your resolution to match the desired resolution and refresh rate of the LCD. In your case the computer should be outputting:
1024x768 pixels
60 Hz
You can change these settings by right clicking on the desktop and clicking properties and they're under the settings tab. Change the screen resolution by moving the slider to the recommended setting (1024x768)
and
under the advanced button click the "monitor" tab - make sure the screen refresh rate is set to 60 hertz (60 hz)
Posted on Jun 04, 2008
  • 225 Answers
SOURCE: i cant unlock osd of my samsung monitor , sync master 551v
Please try again to turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu. regards
Posted on May 28, 2009
  • 73 Answers
SOURCE: Hi, I am having Samsung LCD sync master 943nwx,
it may simply be a lose connection with the monitor cord. or the monitor cord may to be replaced.
Posted on Jul 12, 2009
  • 1684 Answers
SOURCE: No display on SyncMaster 920NW after reboot from power failure
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. Look in our monitor repair section for step by step repair guide for this model it should be the same power supply as the 930. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 22, 2009
parrotheadpc
  • 2600 Answers
SOURCE: change the display resolution from 1024x768 to1024X1280
go to control panel > dosplay settings > click on the settings tab > click on the advanced button > c.ick on Monitor and tick the box that states "Hide Modes that this monitor cannot display > click the adapter tab > click on button "List all modes" This will list every resolution your monitor is capable of displaying.
Posted on Sep 17, 2009
How do I turn off the Samsung sync-master p2050 monitor?
If it doesn't turn off by holding the power button down for 10 seconds, then it cannot be turned off by the power button alone, like most modern lcd monitors. Most modern monitors goes into standby mode. To completely cut power, you must unplug the power cable.
I've enclosed a link to the install manual for reference.
Samsung SyncMaster P2050 User Manual Page 7
Nov 24, 2014 | Samsung Computers & Internet
Samsung 920nm sync master Black screen
Samsung sync master monitors were well known for bad capacitors, if you have a esr capacitor meter you can check in circuit, if not look for dome shape at the top of the capacitor, a dead give away it is open, also check for poor solder connections in the power supply inverter board area.
Jun 20, 2012 | Samsung Computers & Internet
Samsung syncmaster 275t won't start - what to do?
The Samsung monitor is okay, the problem is a compatability issue between the laptop and monitor. The VGA toDVI is the problem you are converting a analog signal to digital, the signal level degrades when that is attempted. If I understand this the laptop puts out the analog signal "VGA" and the monitor has the DVI input, "digital" The only other suggestion is turn off the laptop screen to see if the monitor will work.
Apr 04, 2012 | Samsung Syncmaster 275T Monitor
The screen is all yellow. i am using samsung sync master 713N. it was working fine but now suddenly all white has turned light-yellow.
It does sound like a bad monitor, but first! hook a spare monitor to the computer, if okay The Samsung SyncMaster is the problem, caused by the master board which is attached behind the LCD display, the video signals are feed to the main board where the colors are balanced. To repair this would not be cost effective "cheaper to buy new" Now! if the video cable from the computer to the monitor can be detached, sub another cable just to be sure. Finally if both monitors show the same issue, the problem is in the video graphics card of the computer.
Jan 21, 2011 | Samsung SyncMaster 713N 17" LCD Monitor
Vertical strip on the screen
You have failing T-CON board which is part of the LCD panel assembly, it will get worst with more lines, new panel will be needed. You can try reseating the ribbon cable on the T-CON board.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 16, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Samsung A707 SYNC. No main screen display
the flex of the phone is bad so change the flex
Dec 22, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Samsung sync master 510 monitor display problem
1024x768 pixels
60 Hz
and
May 21, 2008 | Samsung SyncMaster 510N 15" LCD Monitor
Computers & Internet Logo
117 people viewed this question
David Payne
David Payne
