Question about Bosch Axxis WTL 5410 Electric Dryer
Where can i buy a lint filter ? thanks - Bosch Axxis WTL 5410 Electric Dryer
Is there a lint trap or lint filter on this washer? It is a kenmore washer model# 11022622100. I seem to remember my old washer having one inside the lip of the tub but I can not find one anywhere.
On most 110 mods there was what they called a lint trap at the bottom of the wash basket.You can;t see it without taking the basket out (ya I know dum) you will need special tool to remove basket.that filter has now been replaced by whirlpool with 4 little plugs and the so called filter is removed.You can clean the old one and unit will be fine..for that job I would say to get a pro as it takes me about 2 mins to open and will save you as a home owner a whole lot of headaches..Hope I helped and Thanks for voting
Just a note that whirlpool made that machine.
Mar 17, 2011 | Washing Machines
Dryer "clean lint filter" message
Hello. Begin by unplugging the plug on the dryer. Then pull out the filter and thoroughly examine the space that the filter slides into looking for any lint. Remove any lint that you find. Put the filter back and lastly plug the dryer back in.
These steps should solve the problem. If not, then the lint sensor has gone bad and should be replaced. If you wish to do that yourself you can go to searspartsdirect.com. Enter the model number of the dryer and then you will see the parts diagrams allowing you to locate that lint sensor, and even order a new one. Joe
Thanks for choosing Fixya!
Mar 07, 2011 | Dryers
I have a Sears Kenmore washer, model # 110.28922791. I bought it approximately 10 years, give or take a year or two. I know it does not have a lint filter but is there any way to clean whatever processes...
HI- Washer really don't have a lint filter so to speak. Some of the front load washers have a filter in the drain pump but that basically just keep the quarters and bobby pins from ruining the pump. Is it possible to have someone extend your standpipe with a larger diameter pipe that you could place a screen into, or place the screen on the drain hose and then put them both into the larger pipe. A plumber should be able to figure something out. It would be about $1000 dollars cheaper than buying a front-loader and probably more effective. Good luck.
Sep 24, 2010 | Washing Machines
My check lint filter light is on, lint filter has been cleaned. is the exhaust line possible clogged? I have a Epix Z series dryer, the lint filter was not cleaned and now the check lint fileter light is...
Hi
Thanks for using FixYa. To start with the first thing you should do is to remove the lint filter and clean the lint out of inside where the lint screen goes. After this unplug the unit for 5-10 minutes and then push & hold the start/pause button for 10-15 seconds and reconnect the unit. If still it won’t work then it’s the sensor that has gone bad and needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 30, 2010 | Maytag EPICz 6.7 Cu. Ft. King-Size...
Does this washer supposed to have a lint filter
No Lint Filter sorry you have a basic design washing machine, Dont replace it though it wont do u any justice just pocketbook pain
Jun 17, 2010 | Kenmore 44932 Front Load Washer
Unable to locate lint filter
You can buy it online at this link below, just choose the color of your dryer..
Let me know if this is what you are looking for. Don't forget to rate me!!
Sep 13, 2009 | Kenmore 63942 Dryer
Where can I get a lint catcher for an Amana Gas Dryer Model No: LGA30AW.
Hi
You can buy a Lint Catcher/filter for your Gas Dryer from this link---
Amana Gas Dryer LGA30AW Lint Filter
Please do rate this solution as FixYa if found helpful and revert for further assistance.
Thanks
Rylee
Apr 28, 2009 | Amana Dryers
Looking for the lint filter
you did not give me a mod # of your washer .... so i will go through the history of the lint filter 1955-1964 the lint filter was on the right side under the lid , twist knob and pull screen out 1965-1986 lint filter was self cleaning mounted under the washer 1987 -today there is no lint filters any more ..... lint filters where used when people hung the clothes out on the line .... today most people use a DRYER that has the lint filter in it .... i hope this helpes ....... if you are going to rate this please rate this 3 or 4 stars , that will keep me in the paid answer department . thanks
Apr 01, 2009 | Washing Machines
Dirty Dryer
its blows dirt lint by the seall more when the vent going out home is pluging up need to desasemble dryer to clean it out
Mar 20, 2008 | Dryers
Avanti W851 Top Load Washer, Self Cleaning Lint Filter
they should be able to order one from any appliance pars store but if not contact avainti here ive worked for them for years most of the time if you contact them they might send you one if not they will get you one http://www.avantiproducts.com/
Jan 30, 2008 | Avanti W851 Top Load Washer
Bosch Axxis WTL 5410 Electric Dryer Logo
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
