Question about Acer Aspire 3680 Laptop
My laptop's fan isn't working so my laptop shuts down on its own every nw and then which i guess is due to overheating.what should i do to repair this problem?
After several minutes of coling down i rstart the laptop again but then after few minutes it shuts down again.
  • Acer Master
  • 32,281 Answers
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Posted on Feb 20, 2012
2 Suggested Answers
  • 178 Answers
SOURCE: acer aspire overheating & rstarting.
you can replace the fan if you know how to do so but take it to a qualified technician and they will be able to sort it out for you and it should be that expensive
Posted on May 29, 2010
How do you stop a laptop from shutting down?
When the overheating issue is fixed, the laptop will reset. Did you clean the radiator? Is the fan running?
Oct 09, 2014 | Computers & Internet
I recently got a new battery for my HP DV7-1245dx and it still powers off randomly. I trust it isn't a battery issue for it seems to only shut off when in actual use. Please help me with any...
Could be due to the system overheating; does it run hot?
Try using it on a hard flat surface to see if it runs better, allowing better airflow around the machine and check the fan is running, you should be able to hear it.
If it's overheating, it will shut down to prevent heat damage. Overheating can be very destructive to pc components. You'll need to open the case to get to the heatsink, fan and vents. Remove the fan and heatsink and clean. Clean all the vents with vac or compressed air. Apply a little thermal paste to the processor and replace the heatsink and fan.
Mar 29, 2012 | HP Computers & Internet
Computer shuts off at random
It sounds like it's overheating, check your fans make sure all are working, if your fans are all working then your power supply is overheating and should be replaced. If your system is a laptop the battery can overheat also and shut the system down. So you can have different issues dependent on laptop to desktop.
Feb 03, 2012 | Gateway Computers & Internet
My computer shuts down without any warning at all. The problem has occurred 4 times this week when charger is unplugged but power icon still shows me approximately 50% battery. Sometimes computer lets me...
Check you power settings. It is possible that it is set to shut down at 50% battery power.
If it is overheating, that too will cause a shutdown. What is happening at the time of shut down? Are the vents on the laptop being blocked in any way?
Sep 04, 2011 | ASUS Computer International U35jc A1...
Hello Toshiba satellite p35-s6053 shuts down unexpectedly. can u give me some possible solutions
Assuming the battery isn't failing or the power supply isn't bad, the laptops cooling system may be clogged with dust causing overheating and sudden shutdown to prevent damage to the CPU. You may be able to blast the dust out with compressed air but the chunks of dust could actually block up the fan, keeping it from spinning, and make things worse! Best solution is disassembly of the laptop to get better access and do a complete cleaning..
Aug 24, 2011 | Toshiba Satellite P35-S6053 (PSP30U27W001)...
My sony laptop suddenly shut down itself when am playing a game. it shuts with a certain sound
Laptops are very often overheating, so it wouldn't be a surprise if you playing the game makes it even hotter and it just shuts down to protect itself from damage.
You can try using a cooling pad/fan or just make sure the laptop fans can circulate air freely.
Jul 26, 2011 | Computers & Internet
HP Pavilion dv2610us overheating causing laptop to slow down?Is this because my laptop battery died
Overheating is not caused by dead battery. The most common cause of it is a faulty system fan. If the fan has mechanical defect or has degraded performance due to accumulated dusts and particles around it, it will cause overheating. Overheating can cause system to slow down at first, then if you keep using it without minding the overheating problem, your laptop can freeze and shut down on its own.
Here are some tips for overheating issue:
- Use canned air to blow out dust and particles from the system fan.
- Do not operate the laptop in areas where the temperature is high, it will worsen the problem.
- Replace the fan if you notice that it is not working properly as before cause it will further damage the laptop.
Hope this helps.
Jul 09, 2011 | HP Pavilion dv2610us Notebook
I have a model number PT-50LCX64 Panasonic rear projection TV. After turning on the TV about 3 minutes will elapse and TV will automatically turn off by itself.
Probably the fan isn't working or is dirty and needs cleaning. The projector bulb is overheating and shutting down the TV. Clean or replace the fan.
Jul 09, 2011 | Televison & Video
Hi, my HP Compaq Presario has been working great till the 5th of July when it shut down unexpectedly. I instantly turned it on again and shuts down again after booting up. I waited for about an hour, then...
Due to the heavy processing the PC heats up. Excessive heatup beyond usual is alarming and PC shuts down by itself when the processor/ CPU temperature exceeds the safe temperature limit. There are mainly two reasons for heatup.
Heating issue generally occurs due to fan failure, which may damage the system, if not checked and resolved properly. Another most likely cause of overheating is the dust present inside the PC, which clogs the fan and heatsink. As you have mentioned that the fan is not running, most probably the fan has gone dead or it may have stopped working due to clogging with dust and hence it needs cleaning or replacement. To do so, you need to purchase a new fan and disassemble the laptop to replace the fan.
To replace the fan, you have to disassemble the laptop and for that you need to have the laptop repair manual that can be downloaded here.
(I think that you have HP CQ60-419WM Laptop). The repair manual contains all the information as well as graphic illustration about disassembling and replacing the fan. Please refer to Page 4-41 for complete details.
If you are able to work inside such electronics and have some disassembling experience, you may try to do it yourself. However, if you have no experience, it is strongly recommended that you seek professional help from HP authorized repair/ service professional.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 06, 2011 | Computers & Internet
My ASUS laptop F8OL always shutdown when temperature rises on top of my keyboard on the left handside but my ASUS NB Probe did not give a warning and itsays Normal, can you help me out
Your laptop shuts itself down to due to overheating. It does this to prevent damage to your components. This may have been caused by one of a combination of the following reasons:
1. Faulty fan.
2. Dust preventing the fan to supply enough air into the board.
Solution: Clean or replace the Fan.
Cleaning the fan isn't a job for the rookies so I suggest you take your laptop to the computer repair shops and have them service it. Unless you know what you're doing. This procedure can damage your laptop entirely.
Hope this helps.
May 06, 2011 | ASUS Computers & Internet
Acer Aspire 3680 Laptop Logo
157 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
