Question about Sharper Image Ultra Groomer SM400 Beard Trimmer
Need blades and charger - Sharper Image Ultra Groomer SM400 Beard Trimmer
Hi, I also have this groomer and I loved it, Used for a long time to trim my beard. I lost the 3mm blade but I have everything else, the blades, the charger, the trimmer of course and even the cleaning brush and the instructions manual. If you are interested let me know, I'm willing to let it go. My email is albertojquintero@yahoo.com
Posted on Aug 31, 2012
Model ar5516. Why is drum not cleaning?
Sir,
Did you prime the cleaning blade with toner when you installed it?, and did you ensure the new cleaning blade did not flip!!!!, re-check the new installed cleaning blade, place a small amount of toner from the toner bottle on the drum along the whole drum. and using your hands at both end of the drum DO NOT TOUCH THE DRUM" turn just a 1/4" CCW (To ensure the cleaning blade is set) then CW to see if the toner is removed. your drum might need to be replaced and or the fuser unit have a example of the copy?
Dec 28, 2015 | Sharp Office Equipment & Supplies
How do I get a charger for the sonic blade cordless carving knife?
try contating where you purchased the knife
you may try contacting
http://chinatvseller.en.hisupplier.com/product-351509-sonic-blade-power-knife.html
to get ome idea on how supplies these items in your local area .
Dec 25, 2014 | Lands Phones
Battery es8003 replacement
Okies heres the answer
Get your battery from here panasonic shaver battery Cost is $17-$20 range USD with free shipping over $45 at that site.
Goto Youtube and watch this video on how to replace it .
Your blades can be found here Panasonic Shaver PartsGenuine replacement parts inner blades outer foils... at around $25 usd and as for the charger you can find it here Panasonic ES8003 Shavers Spares It's a British site and listed at $28 British pounds.
There are probably other places but those are the first i found that seem to have the item in stock right now.
Cheerio
Mar 09, 2014 | Panasonic Linear ES 8003 W Electric Shaver
Having problem with phones battery charger, won't charge sometimes, seems to be a problem with the charger port
Sometimes you will have to buy a new charger. If it is the phone, you may have to rig your battery to the charger itself.
May 24, 2011 | Cell Phones
I need a charger for Black & Decker SZ360 power scissors. My scissors have stopped working and the charger no longer produces electricity.
Hello. Here is the link to B&D service, and their batteries&chargers page. Try their toll free and I'm certain they will be able to assist you in finding a replacement as well as a dealer closest to you.
http://www.blackanddecker.com/Batteries-Chargers.aspx
http://www.blackanddecker.com/Customer-Service.aspx
Feb 08, 2011 | Black & Decker SZ360 Cordless Power...
Blades wont stop till battery goes flat,then rotate again when you try charge it up
First, chopper must be "off" when charging.
If helicopter is powered off and blades move when it's hooked to the charger, then you have an incorrect charger. It's tricky as they all look the same. At one point I had 3 different "syma s107" helis that all used different chargers. Around 7 different Chinese and Taiwanese factories/companies produce the "syma" branded birds, and often with differing but very similar parts. There are at least 3 circuit board designs, different wiring patterns, and a couple batteries.... I've heard of people receiving a charger in the box with their 107 that didn't charge it. NEVER run battery dead. You will ruin it. What charging method are you using? Does it fly normally when charged? Do the blades ever move when it is powered off and not hooked to charger?
Let me know,
thanks PvT
Jan 07, 2011 | SYMA Toys industrial New Syma S107 Mini...
How to replace copier drum Cleaning Blade UCLEZ0069FCZZ
Improper installation may damage the copier. Before disassembly, be sure to disconnect the power cord for safety. 1) Remove the drum cover. (4 Lock Tabs.)
2) Remove the drum fixing plate and the photo conductor drum.
•Dispose the drum fixing plate which was removed.
3) Check the cleaning blade and the red felt for damage.
•If there is damage, go to step 5
•If there is no damage, go to step 12
4) Remove the main charger. (Cleaning the screen grid and the sawteeth.)
5) Remove the cleaning blade.
•Dispose the cleaning blade which was removed.
6) Clean the cleaning section and the waste toner pipe to remove waste toner completely with a vacuum cleaner.
7) Remove the felt and duplex tape completely.
•Be careful not to scratch or bend the sub blade.
8) Attach the cleaning blade.
•Securely insert the plate section of the cleaning blade into the unit and fix it with a screw.
•Do not touch the cleaning blade rubber with your hand.
•When attaching the cleaning blade, press the cleaning blade in the arrow direction and attach.
9) Attach the felt.
•Attach the mocket with slightly pressing section A of the cleaning blade.
•Do not touch the tip of the cleaning blade.
•Do not put the mocket under the cleaning blade.
•Do not put the mocket on the sub blade.
•Do not press the sub blade with the mocket.
10) Attach the main charger.
•Securely set the MC holder on the projection of the process frame.
•Securely insert two projections of the MC holder into the groove in the process frame.
•When attaching the MC holder assembly, be careful not to make contact with the cleaning blade.
11) attach the drum fixing plate and the photoconductor drum. Apply grease to the inside of the photoconductor drum. (Diagram 2)
•Attach the drum from (b). (Prevention against the sub blade edge breakage)
•Attach the drum so that its position with the sub blade shown
12) Attach the detection gear.
•The detection gear is not installed to the drum cartridge package with the main body. Add a new one.
13) Attach the drum cover.
•After attaching the drum cover, do no make a copy
•When attaching the drum cover, engage the detection gear 20T rib with the 30T gear rib, and attach the drum to the process frame.)
14) Important.
•Insure proper drum rotation by rotating the drum counter-clockwise (as viewed from the front)
•If the drum does not rotate with reasonable effort the drum blade may need to be re-positioned or lubricated with a small amount of toner.
Dec 16, 2010 | Sharp Office Equipment & Supplies
Ryobi Circular Saw
unplug saw
new Ryobi have a spindle lock button, it is unobtrusive and you may miss it
739d802.gif If yours does not, secondhand etc, a screwdriver in the blade teeth between the upper and lower guards provides a locking bar enough to undo the arbor bolt
Jul 30, 2008 | Ryobi Multi-Volt Battery Charger
Sharper Image Ultra Groomer SM400 Beard Trimmer Logo
341 people viewed this question
Top Sharper Image Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Sharper Image Health and Beauty Expert? Answer questions, earn points and help others
