Question about Dell Studio One 19 (DDDASA1) 18.5 in. PC Desktop
Motherboard short circuit
Is there a way to repair the motherboard after a short circuit
  • Dell Master
  • 32,281 Answers
Not possible, best to buy a new motherboard or a new computer.
Posted on Feb 20, 2012
Ford airbag code 54
94+ AIR BAG DIAGNOSTIC TROUBLE CODES/CLEARING
Code Component/Fault Description
No Air Bag Indicator - Inoperative Indicator Circuit
Continuous Air Bag Indicator - Diagnostic Trouble Code Timed Out, Diagnostic Monitor Disconnected or Inoperative, or No Ignition Voltage to Diagnostic Monitor.
12 Lost Battery Feed
13 Air Bag Circuit Shorted to Ground
14 Primary Crash Sensor Circuit Shorted to Ground
21 Diagnostic Monitor Not Mounted to Vehicle Properly
22 Safing Sensor Output Circuit Shorted to Battery Voltage
23 Memory Clear Circuit Improperly Grounded
24 System Disarm Failure or Internal Diagnostic Monitor Fault
32 Driver Side Air Bag Circuit High Resistance or Open
33 Passenger Side Air Bag Circuit High Resistance or Open
34 Driver Side Air Bag Circuit Low Resistance or Shorted
35 Passenger Side Air Bag Circuit Low Resistance or Shorted
41 RH Radiator Primary Crash Sensor Feed/Return Circuit Open
42 LH Radiator Primary Crash Sensor Feed/Return Circuit Open
44 RH Radiator Primary Crash Sensor Not Mounted to Vehicle Properly
45 LH Radiator Primary Crash Sensor Not Mounted to Vehicle Properly
52 Intermittent or Repaired Lost Battery Feed
53 Intermittent or Repaired Air Bag Circuit Shorted to Ground
54 Intermittent or Repaired Primary Crash Sensor Circuit Shorted to Ground
61 Intermittent or Repaired Diagnostic Monitor Not Mounted to Vehicle Properly
62 Intermittent or Repaired Safing Sensor Output Circuit Shorted to Battery Voltage
63 Intermittent or Repaired Memory Clear Circuit Improperly Grounded
64 Intermittent or Repaired System Disarm Failure or Internal Diagnostic Monitor Fault
72 Intermittent or Repaired Driver Side Air Bag Circuit High Resistance or Open
73 Intermittent or Repaired Passenger Side Air Bag Circuit High Resistance or Open
74 Intermittent or Repaired Driver Side Air Bag Circuit Low Resistance or Shorted
75 Intermittent or Repaired Passenger Side Air Bag Circuit Low Resistance or Shorted
81 Intermittent or Repaired RH Radiator Primary Crash Sensor Feed/Return Circuit Open
82 Intermittent or Repaired LH Radiator Primary Crash Sensor Feed/Return Circuit Open
84 Intermittent or Repaired RH Radiator Primary Crash Sensor Not Mounted to Vehicle
85 Intermittent or Repaired LH Radiator Primary Crash Sensor Not Mounted to Vehicle
Rapid Continuous Flashing of Air Bag Indicator (No Diagnostic Trouble Code) Both Primary Crash Sensors Disconnected Assembly Plant Mode
TROUBLE CODE CLEARING
1. Follow the diagnostic procedures to service the fault condition flashing on the air bag indicator prior to code clearing.
2. Cycle the ignition switch to OFF and then to RUN.
3. Observe air bag indicator prove-out (six ? two seconds) followed by diagnostic trouble code (52-85) flashing completely one time.
4. Locate the Diagnostic "Trouble Code Clear" Connector (grey connector). located underneath the glove compartment, left side (06010) containing Circuits 631 (T/R) and 57 (BK).
5. Use a jumper wire to short Circuit 631 (T/R) to Circuit 57 (BK) or to another good ground. This short must be made after the diagnostic trouble code flashes completely one time, but before the warning light stays on continuously.
6. Hold short until air bag diagnostic monitor tone sounds (approximately five seconds).
7. Release short on Circuit 631 (T/R) to Circuit 57 (BK). This short must be released within 25 seconds after the diagnostic monitor tone sounds.
Diagnostic trouble code is now cleared from memory. Next highest priority diagnostic trouble code stored (if one exists) will begin flashing.
The codes and clearing proceedure above are to be used as a guide, NO claims are implied as to the correctness or accuracy of either.
Sep 11, 2013 | Cars & Trucks
Ga-81865gme not start with push botton power
Motherboard schematic are not available due to trade secret from the manufacture.. Motherboard are not made to be repaired because they are printed circuit in different layers.
Mar 29, 2012 | Gigabyte GA-8I845GVM-RZ Motherboard
My sony PlayStation 2 won't turn on
I believe your PS2 has a short circuit and needs another motherboard. If you can do this yourself, that's great. You can find Motherboards or a PS2 like yours that will not read discs or has Disc Read Errors but will boot up for about $25 on Ebay. If you're not comfortable with Changing out your motherboard, then click on the "Repair directory" at the bottom of this screen. On the Repair Directory Screen, select Video Game Consoles. Choose a good Repair shop.
Aug 15, 2011 | Sony PlayStation 2 (PS2) Console
My nokia 3600slide phone's motherboard is short circuited due to battery fault.nokia care staff are saying that the phone is useless.is there any solution.can the motherboard be changed?plz reply
Supposed to be, it can be repaired without replace the board. Your circuit board / motherboard is can be replace with new one. But the price may be already half of your phone price. Regards,
Jan 20, 2011 | Nokia Cell Phones
When the power supply is connected to motherboard it goes off itself
problem lies in the motherboard there is mosfets on the motherboard which is short and because of short circuit protection power supply goes off itself so either replace the motherboard or repair
Feb 01, 2010 | AOpen FSP200-60SAV (5604200H220) 200-Watt...
Circuit diagram
For just a short advise you may buy that kind of circuit in the computer shop ... Just reply me if my advise is helpful or not?
It's ok???
Jul 02, 2008 | Intel D845GVSR Motherboard
Ps2 light not stayin green
I believe your PS2 has a short circuit and needs another motherboard. If you can do this yourself, great. You can find Motherboards or PS2 like yours that will not read discs but will boot up for about $25 on Ebay. If your not comfortable with Changing out your motherboard, then Click on the "Repair directory" at the bottom of this screen. Once that screen pops up. Clickopn Video Gamer Console Repair. Choose a good Repair shop.
Nov 10, 2007 | Sony PlayStation 2 (PS2) Console
Ps2 slim
Hi ataBringiton,
I believe your PS2 has a short circuit and needs another motherboard. If you can do this yourself, that’s great. You can find Motherboards or PS2 like yours that will not read discs but
will boot up for about $25 on Ebay. If you’re not comfortable with Changing out your motherboard, then click on the "Repair directory" at the bottom of this screen. On the Repair Directory Screen, select Video Game Consoles. Choose a good Repair shop.
Nov 09, 2007 | Sony PlayStation 2 (PS2) Console
Off and on
I believe your PS2 has a short circuit and needs another motherboard. If you know how to replace the motherboard yourself, that’s great. You can find Motherboards or a PS2 like yours that has a DRE or Disc Read Error but will boot up for about $25 on Ebay. If you’re not comfortable with Changing out your motherboard, then click on the "Repair directory" at the bottom of this screen. On the Repair Directory Screen, select Video Game Consoles. Choose a good Repair shop.
Nov 04, 2007 | Sony PlayStation 2 Slimline Console
Short circuit in vcc and ground
Some questions first: Is this the same board mentioned in your other post? If so how did you decide that you have a short on your motherboard?
Jan 30, 2007 | Gigabyte GA-8VD667 Motherboard
Dell Studio One 19 (DDDASA1) 18.5 in. PC Desktop Logo
139 people viewed this question
Alun Cox
