Question about Epson Stylus Photo RX620 All-In-One InkJet Printer
RX620 cartridge carriage off the guide rail
This is a printer that I purchased on Ebay. I am familiar with its operation as I have had one for years. Aooarently this one had some foreign objects pushed inside, likely by children, as I found a spool of thread in the back--also a lot of loose thread all balled up. I guess the objects somehow unseated the cartridge carriage and now it will not move all the way to the right which is necessary for printing, etc. Question is--how do I get the carriage back on its rails?  It has 2 plastic 'claws' at each back corner that are supposed to be gripping the guide rail.
    Genius:
  • 1,447 Answers
HI-
Unfortunately there is no way because if you will move it manually, it will damage the sensor for the cartridges. Try using a ruler or any flat object that will lock the cartridge cover by pushing it down. if all fails call manufacturer @ 562-276-4382
Hope this helps
Posted on Oct 31, 2008
When i print a document my ip1800 printer give me a massage serivice 5100 error
In this particular printer, this Error is described as Cartridge Home Position error. Try the steps that I am giving you:---- 1.Turn off and unplug the printer from the power supply.
2.Remove any paper.Buy a can of compressed air from an electronics shop or computer store. Use the compressed air (Not a vacuum!!!) to blast out any dust bunnies, paper particles and debris. (Don't do this with the cartridges removed as you're likely to fill the printhead with air!!)Use isopropyl alcohol and a cotton swab (Qtip) to clean the plastic strip that runs the length of the guide rail (the metal rail that the cartridge carriage moves along), it may be contaminated with ink and debris.Remove and reinsert the ink cartridges inside the cartridge carriage to ensure that they're connecting properly.
3.With the power off, carefully slide the print head (carriage) to the center of the guide rail. You should not have to force it! (There will be some light resistance but it should move quite easily by gently pushing on it with your finger.)
4.Close all the access doors, plug it back in, connect your USB cable and turn on the power.As it runs through the initialization, the printer should sense that the carriage is out of position and automatically move it back to where it should be.
Jan 18, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Error message 5100
Thank you, Have a nice day.
Sep 28, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
How do I load an ink cartridge into Epson Stylus Photo R230
Either press the ink button once to move the carriage to the left position, then press it again to move the carriage to the ink change position, Or use the SSC software and select move head to change position. Either should work on that printer.
Aug 23, 2009 | Epson RX620 All-In-One InkJet Photo...
Service error 5100
Try this to get rid of the error:
Service error 5100 is a carriage home position error.
Remove any paper.
Good Luck.
Jul 03, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Erroe code 5100 pixma ip1800
5100 means either the carriage can't move properly from right to left, or the encoder strip behind the carriage assembly has grease or ink on it and needs to be wiped with a Q-tip. Sometimes the cleaning assembly on the right gets stuck in the up position and stops the carriage.
Jul 02, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Error 5100 on pixma ip1800
Remove any paper.
Error 5001 on canon ip1800
Hi there, service error 5100 is a carriage home position error.
Remove any paper.
Hope this helps solve your problem, I've had other people do it and its worked for them.
Feb 21, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Error 5100
Please remember to rate other users who assist you for free :)
Remove any paper.
Good Luck.
Sep 25, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Service error 5100 on my printer
Best Answer - Chosen by Voters Service error 5100 is a carriage home position error.
Remove any paper.
Jul 14, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
RX620 "Ink Cartridges cannot be recognized"
Found the solution at
http://www.fixyourownprinter.com/forums/printer/54833
Try pressing down on the cartridges after inserting them and closing the top of the cartridge carriage. Worked like a champ on my R320 printer!
Cleaning the contacts on the cartridge with a soft tissue may help too.
Mar 21, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson Stylus Photo RX620 All-In-One InkJet Printer Logo
54 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
