Question about LG Jabra A210 Bluetooth Adapter for Headset
Jabra bluetooth adapter A210
How can I connect a bluetooth adapter to the AUX input of an audio amplier.
I tried the Jabra A210 which has a 2.5mm pin with mic, speaker and ground contact. I soldered the mic and ground contact to the amplifier mic input, but no sound comes out. I know for sure the bluetooth adapter works, I tested it with a cellphone first.
Please help.
you have to connect the jabra audio jack to the audio source, to the speaker output of your receiver for example. If jabra detects the source it will work. If you cut the connection, jabra watch for a while if something happend and than stops the transmittion. Hope that helps
Posted on May 05, 2009
Need a CD player to be paired with Cadillac Infotainment system (In Car Audio System) Can I output to a Bluetooth Transmitter to pair with the car system using a portable CD player
If you have a Bluetooth receiver with a 3.5mm adapter and a 3.5mm aux input in your car - you can Bluetooh your device and use the Aux input to accept your audio.
May 01, 2017 | Car Audio & Video
How can I my 2004 Honda Goldwing mic to work with my Garmin Zumo 665 to answer my cellphone? The phone bluetooth connection works fine with the Garmin in my car, but my Honda mic does not work through the...
The microphone input from the Zumo 665 motorcycle mounting cradle is the smaller 2.5mm jack.
Be sure to use this one as some microphone jacks will require a 3.5mm to 2.5mm adapter.
The audio output is the 3.5mm jack.
Be sure not to confuse the two.
It may be necessary to have a custom 5 or 7 pin DIN adapter made to connect between the GW audio system and the Zumo.
It would be best to consult with your local Honda GoldWing dealer for more information on interfacing the GW audio system.
Oct 07, 2011 | Garmin zumo 665 GPS Receiver
The Jabra A210 keeps dropping the connection between the devices.
My solution is to connect the jabra audio jack to the speaker output of my receiver. Jabra need it to detect a source. If the connection to the source is cut, jabra waits around 30 seconds and if nothing happend jabra stop the transmittion. I hope that helps.
Mar 13, 2009 | LG Jabra A210 Bluetooth Adapter for...
Pin Number..,Where do I find the pin number for my Jabra A320S CD-ROM download?
for installation if it asks for pin turn around the cd cover and in bar code sticker u ll find it to connect to the mobile or to bluetooth devices for eg: if u enter 0000 in in ur computer same to be entered in the mobile and u will be paired to the device and u ll be able to use it
Nov 02, 2008 | Jabra A320s Bluetooth Wireless Adapter
Jabra BT620 Microphone dose not work with Soft Phone on My PC
Well, I got the same problem the days before, and after some trying, I've solved.
I'm using the Toshiba bluetooth adapter, too. You see, when you want to make a new connection with your bluetooth device, you may either use the Express Mode or the Custom Mode. Go with the Custom Mode, then, there appears the Jabra BT620. After input the 0000 code, you may select the services from 3 options. There, you can find the headset or hands-free option.
Go with that, than you may have your Jabra BT620 as a microphone!
Sep 09, 2008 | Jabra BT620 BLUETOOTH STEREO HANDS-FREE...
Jabra vbt135z
How do I have to set up my Jabra head set?
Jan 15, 2008 | Jabra BT350 Bluetooth Headset Headset
Won't charge up...
I had the same issue. So what I did was get a small screwdriver, opened the A210 case removed the battery. You will notice orange tape (remove it) then attached to the battery is a small board (the defective part) . Cut away the board, then you will need to solder the wires back to the thin metal film leads. And voila it will now charge, make sure to never let it charge for more than 2 hours. Do this at your own risk. Of course this will void the warranty.
Nov 27, 2007 | LG Jabra A210 Bluetooth Adapter for...
Radio Communications Logo
317 people viewed this question
Top LG Radio Communications Experts
TO Lady
Mohamed Ismail
Mohamed Ismail
Computer Repairing
Computer Repairing
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
