Question about Haier Refrigerators
Refrigerator wont cool after cleaning.
There was ice forming inside the refrigerator, so I turned the temperature to Zero and started to clean. I poured a little bit of warm water to break the ice. After cleaning, I removed the extra water that came out through the back of the refrigerator, and switched the temperature up to 7. After a few days, I checked back and it wasn't cooling at all. Please Help. I bought this refrigerator about a month ago.
Rotu
  • 175 Answers
SOURCE: Refrigerator not cooling properly
You may have a low freon condition in the fridge section. Look to see if you have an ice block building up on the rear wall towards the lower left side. If so, you are low on freon and the ost likely culprit is a leaking evaporater. The best way to tell if you are low on freon for sure is to take out all the shelves, remove the light cover, then the 2 screws holding the fan cover, and then remove the back wall. You wont be able to pull it all the way out cause the cold control is attached to it for the freezer and fridge so be careful. Turn the fridge control all the way up to 10 and wait till the compressor is running. you can tell if the compressor is running by pushing in the little switch on the top of the door frame and seeing if the fan runs(one switch is for lights, the other for fan) if it runs the compressor is on. anyway watch the coils and see if they develop frost all the way from top to bottom. If they dont you are low on freon and are ooking at about a $600 repair. if it does frost all the way you may have a bad cold control or a stalling fan motor up by the condensor on top. The best way to tell this is the next time the fridge feels warm, sheck the frame around the door seal and see if it is hot to the touch. If it is you almost surley have a bad condensor fan motor. Hope you can wade through all tis to find the answers. Good Luck!
Posted on Feb 24, 2007
SOURCE: Sub-Zero 550
Hi!
I had the same problem with my 550...several times the tech came out and used a steam machine to blow out the drain...which didn't solve the problem. Finally, they ordered a refrigerator drain heater from sub-zero (part#4201290) and this finally fixed the problem. Hope this helps...I'm not a tech, just a customer. K
Posted on May 19, 2008
  • 1462 Answers
SOURCE: Correct temperature for freezer & fridge
fridge should be about +4degC and freezer about -18degC
Posted on Sep 25, 2008
abhishek33
  • 1239 Answers
SOURCE: sub zero refrig - ice forming inside
HI This component is a heating element located on the evaporator coil. When the refrigerator or freezer switches to the defrost cycle, the defrost heater is turned on to melt the frost in the compartment. Failure of the defrost heater causes failure to defrost.Test the element with a VOM set to the RX1 scale. To gain access to the heating element, remove the compartment's wall panels. Clip one probe of the VOM to each element terminal. The meter should read between 5 and 20 ohms. If it doesn't, the heating element is faulty and should be replaced. Replace the heater with a new one of the same type and electrical rating. Connect the new heater the same way the old one was connected.
Posted on Oct 12, 2008
Maytag317
  • 1136 Answers
SOURCE: Why extra water line INSIDE my refrigerator
Hi, If you are talking about the tubing behind the crisper drawer, it is there to hold water for the dispenser in the door. The old design was a canister to hold water. Now it is tubing. I hope this helps you.
Vic
Posted on Jul 18, 2009
The Refrigerator's Freezer is not working but the fridge is, what is wrong?
You probably have one compressor that cools the freezer section and the refrigerator section. Usually the freezer gets cooled directly with the cooling coils. A fan blows cool air to the refrigerator section. The air flow to the refrigerator may be modulated with some time of "air door". What you have written says to me, is that the fans and air doors are working but there is enough cold for the refrigerator but not enough for the freezer.
Here is what I would do:
  1. Put a thermometer in the refrigerator and in the freezer.
  2. Be sure the coils underneath or behind the refrigerator are clean. If they are very dirty, clean them.
  3. Keep the doors shut for at least 12 hours and then read the thermometers and write down the temperatures.
  4. Freezer temperature
    1. If the freezer has started freezing again, you fixed it by cleaning the coils
    2. .If the freezer temperature is between 0 deg F and 32 deg F, consider putting the food in a cooler and packing in some dry ice to try and save it.
    3. If the freezer is warmer than 32 deg f, throw away the food.
    4. Doctors and hospitals are pretty expensive. I would throw away the food no matter what the thermometer read.
  5. Look inside the freezer at the cooling coils. See if they are ice coated or not.
    1. If the freezer is above 0 deg F, and the coils are ice covered, the defrost control is not working. Unplug the refrigerator for 12 hours and let the ice melt. (Keep the doors shut.) Then, plug in the refrigerator for 12 hours and check the temperature like in step 3.
    2. If the freezer is above 0 deg F, and the coils are NOT ice covered, the compressor is not working.
  6. Call the service technician. When she comes out show her the temperatures and tell her what you found out about the ice on the coils.
Good luck
Jun 07, 2015 | Refrigerators
I defrosted my refrigerator..after doing that..my refrigerator is working but not cooling efficiently..compressor is working..evaporation tubes are getting cooled but not that much..no ice is formed..what...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 16, 2011 | Refrigerators
I have a Kenmore Elite Model # 795.75546401. Ice forms underneath the freezer drawer and I have to remove it weekly or the drawer wont open. I can not see any access to drain lines in the back or how to...
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:The defrost timerThe defrost thermostat (also called the bi-metal switch)The defrost heaterIf it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problemSelf-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Jan 26, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The freezer is not getting cold enough and Ice is forming inside the refrigerator.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Oct 06, 2010 | Sub-Zero 611 / O Bottom Freezer...
The refrigerator had a blinking message to clean condenser. We vacuumed that and turn the unit totally off and restarted it. The temperature is at 57 degrees inside the refrigerator. What do we do?
Remove shelves and check if there is a small frost or ice buildup on one of the corners of the back panel. If there is - there is likely a problem with the sealed system (freon leaked out)
Oct 13, 2009 | Sub-Zero 695/O Side by Side Refrigerator
Freezer temperature dropping/digital display reading zero +/- 2
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Mar 29, 2009 | GE PSC25NGS Side by Side Refrigerator
You have a freon leak in you evapator. Call an authorized Sub Zero service company it will be coverd by you sealed system warranty..
Oct 12, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Sub zero ice cubes are turning out badly
hold in the alarm button for 10 sec and it will reset...let me know
Jun 26, 2008 | Sub-Zero 650 / O Bottom Freezer...
Re: Kenmore Top Freezer formed ice, main refrigerator area is not cooling Kenmore Top Freezer (Main refrigerator area) is not cooling; This trouble shooting has happened for the past year. Main...
not easy to diagnose. the basic fault is that the defrost system has packed up.
check that there is continuity thro the defrost heater. there may also be a thermal fuse in series with the heater so check that also.
if those ok, then points to a fault in the main module
Jun 22, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
