Question about Whirlpool Dryers
Whirpool Dryer Electric
What could be the cause when the dryer stops turning?
    Scholar:
  • 112 Answers
Broken belt is probable. If not, check the door switch operation. If that is ok, check voltage out of the timer to the motor.
Posted on Oct 26, 2008
mikedurland
  • 481 Answers
SOURCE: whirpool dryer
once you take the element casing out of the dryer then you will see a screw at the very bottom of the casing where the element goes in. usually a 5/16 hex head screw.1933c22.jpg
Posted on Jul 07, 2008
rickzilla
  • 706 Answers
SOURCE: whirpool electric dryer: heat turns on but no rotation
Your problem could be as simple as a broken drive belt.. or an overtemp switch.... If you've never replaced the drive belt.. then that is in all probability your problem.. If you reach inside the dryer drum and try to rotate it.. does it offer any resistance like it is turning a motor pulley system or is it free to rotate with very little resistance ( would suggest the belt broke).. If the cost to repair exceeds the cost to replace then you'd be better off replacing.. However ..if it is just a drive belt.. then I would just replace that.. Hope that helps...
Posted on Aug 24, 2008
  • 80 Answers
SOURCE: my dryer tumbler will not turn however the light turns on
A couple things to check are, see if there is a broken drum belt and check the switch that starts the dryer. Check your plug also you may not be getting 220 volts. Sometimes the plugs go bad where you only have 110 volts
Posted on Oct 02, 2009
FixinFax
  • 3085 Answers
SOURCE: what is the max dryer vent duct run with 2 90
20 feet with solid pipe
20 feet flex pipe with helper fan
10 feet with flex
Posted on Nov 06, 2009
  • 332 Answers
SOURCE: Dryer is not heating up at all. Whirpool electric
HEATING ELEMENT
Posted on Dec 27, 2010
Cloths dryer Whirpool does not heat the heating element is OK
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 29, 2011 | Dryers
I have a whirpool duet dryer the clothes are not getting dried
heatman101
Jun 25, 2011 | Whirlpool Dryers
I have a whirpool Dryer LGR3634EW3 Gas it spins but in not heating
heatman101./
][p]\=-
Apr 17, 2011 | Whirlpool LGR7646E Dryer
How do I ignite my whirpool gas dryer?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 17, 2010 | Whirlpool LGV4634JQ Gas Dryer
I have a whirpool dryer Model LER 4634 PQ0. The dryer turns but does not heat. What could the problem be?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 07, 2010 | Whirlpool LER4634J Electric Dryer
GEW9878LW Electric Dryer: Whirpool Dryer - Model # GEW9878PWO - Serial # MS4...
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 18, 2010 | Whirlpool GEW9878LW Electric Dryer
Need to get to belt on my whirpool dryer
TAKE FRONT OF DRYER OFF PLACE BELT OVER TUB @ THEN OVER THE PULLEYS MAKING A FIGURE 8 LET ME KNOW IF YOU HAVE ANY PROBLEMS
Apr 30, 2009 | Whirlpool LER4634J Electric Dryer
Whirpool dryer won't heat up
You need to replace the thermal fuse and the timer. A bad timer will over draw a thermal fuse and cause it to blow.
Please remember to unplug the dryer before servicing
Mar 28, 2009 | Whirlpool LER5636P Electric Dryer
Whirpool Senseon stops mid-cycle
there is a thermostat called a thermister on the blower box that will do that(run for few minutes and shut off) get the model number off dryer door or on inside dryer door wall ,go to sears .com click on parts put in model number and it will show you exactly where everything goes,let me know how you do-mike
Oct 02, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
43 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
